The Tomohawk Kid Posted November 11, 2018 Posted November 11, 2018 (edited) 14 hours ago, alancmlaird said: If anyone is doing an early Comet, can I have your spare bit of fuselage please? I want to do a BEA 4B! 😘 Assuming Mach 2 have moulded the fuselage to the correct length, you don't need to anything with it. It is the wings that will need major surgery to convert it into a 4B. Tommo Edited November 11, 2018 by The Tomohawk Kid
pinky coffeeboat Posted November 11, 2018 Posted November 11, 2018 I was excited by it and headed straight over to their stand yesterday, looked at it for a moment and moved on. Jeff 1
ivand Posted November 11, 2018 Posted November 11, 2018 Enquiring minds want to know why you moved on. 🤔 1
pinky coffeeboat Posted November 11, 2018 Posted November 11, 2018 There were a few issues I saw, from the ridiculously small engine exhausts, to the engine faces being too close to the intake, the shape of the wing/engine fairing and others. I do love the Comet and if I wasn't being too picky I could build it, but those issues mentioned just jar in my mind and would be always visible to me. Jeff 1 1
ivand Posted November 11, 2018 Posted November 11, 2018 Thank you. I think it's about time someone did a kit review. 😉 1 1
Vulcanicity Posted November 11, 2018 Posted November 11, 2018 (edited) That looks good enough to tempt me, even though it isn't the much more elegant and shelf-space friendly Comet 2... Now if only I had a job and some spare money... Edited November 11, 2018 by Vulcanicity
Dave Fleming Posted November 11, 2018 Posted November 11, 2018 On 11/8/2018 at 8:20 PM, The Tomohawk Kid said: It was DH who conducted the trials with Comet 2, to South America not BOAC. Therefore there is no BOAC livery for Comet 2. Interestingly the Eastern seaboard of Canada was right at the limit of the Comet 4Cs range dependant on prevailing weather conditions, so the adverstised non-stop transatlanic flights to New York by Comet, more often than not had to refuel in Gander. Thommo. https://abpic.co.uk/pictures/view/1507662 On 11/8/2018 at 8:27 PM, Graham Boak said: Were these trials done in bare metal? I doubt it. The 2X had a civil scheme based on BOAC styling without the blue tail or company name: I suggest that G-AMXA was similar and likely 'XB too. It would suprise me if BOAC was prepared to miss on the publicity of the long flights and the display at Farnborough, but you can guarantee that DH would make their point.
Kevin Callahan Posted November 12, 2018 Posted November 12, 2018 (edited) On 11/10/2018 at 6:23 AM, AMB said: ...and the white outline to the fuselage roundel. Cockpit windows don't look quite straight either, but I'm sure that could be corrected. A 'must have' for me, as I have flown on all five of the RAF's Comet C.4s. Never mind the cockpit windows, look at the passenger windows down the side. Unless that cheatline on the Dan-Air version is wonky, they are all over the place. I wasn't planning to use Mach 2's clear side windows anyway (Kristal Kleer instead) but straightening out the line of windows will take some doing. Still won't prevent me from getting an injection molded Comet though... Edited November 12, 2018 by Kevin Callahan
Learstang Posted November 12, 2018 Posted November 12, 2018 I suspect I shall be buying one also. And yes, I do have a few Mach 2 kits so I realise they're not the easiest to build, but I will find it hard (impossible?) to pass up an IM 1/72nd scale Comet. Regards, Jason
Dave Fleming Posted November 12, 2018 Posted November 12, 2018 3 hours ago, Kevin Callahan said: Never mind the cockpit windows, look at the passenger windows down the side. Unless that cheatline on the Dan-Air version is wonky, they are all over the place. I wasn't planning to use Mach 2's clear side windows anyway (Kristal Kleer instead) but straightening out the line of windows will take some doing. Still won't prevent me from getting an injection molded Comet though... Are the windows decals?
bentwaters81tfw Posted November 12, 2018 Posted November 12, 2018 1 minute ago, Dave Fleming said: Are the windows decals? No they are glazed.
ivand Posted November 12, 2018 Posted November 12, 2018 Mind you, you could always fill in the holes and use decals for the windows instead. That would certainly be easier than reshaping them.
Kevin Callahan Posted November 12, 2018 Posted November 12, 2018 1 hour ago, ivand said: Mind you, you could always fill in the holes and use decals for the windows instead. That would certainly be easier than reshaping them. To be honest, that might be the best way to go if the windows are truly misaligned and it isn't just a trick of the camera or something. Not a big fan of decal windows, but a Mach 2 kit likely won't be in the front row of my display case anyway.
Julien Posted November 12, 2018 Posted November 12, 2018 Looking at the kit at Telford the cabin windows on both sides do suffer from some alignment issues, not really a problem for most modellers who were buying the kit as they seemed to be selling well. Julien
ivand Posted November 12, 2018 Posted November 12, 2018 Well, it's not as if Mach2 is a first time offender in this regard: Mach2 Jetstar on ARC Oh, well, I reckon some would call it "real craftsmanship, all done by hand"! 🙄 (Still, I would also like one of those Comets!)
tonyot Posted November 12, 2018 Posted November 12, 2018 I bought the RAF version and it looks very good for a Mach 2 kit,...... although when examining it closely later I discovered that one of the crimped in jet pipes has a moulding flaw and is solid with the hole filled in at full depth with plastic,....... so I`m a bit stumped about what to do with it,..... might have to plank all four of them up? Cheers Tony
Dave Fleming Posted November 13, 2018 Posted November 13, 2018 3 hours ago, tonyot said: I bought the RAF version and it looks very good for a Mach 2 kit,...... although when examining it closely later I discovered that one of the crimped in jet pipes has a moulding flaw and is solid with the hole filled in at full depth with plastic,....... so I`m a bit stumped about what to do with it,..... might have to plank all four of them up? Cheers Tony Yeah, they used exhaust covers I'm sure 1
The Tomohawk Kid Posted November 13, 2018 Posted November 13, 2018 (edited) Anyone willing to share a few sprue shots? Tommo. Edited November 13, 2018 by The Tomohawk Kid 3
Geoff_B Posted November 13, 2018 Posted November 13, 2018 14 hours ago, tonyot said: I bought the RAF version and it looks very good for a Mach 2 kit,...... although when examining it closely later I discovered that one of the crimped in jet pipes has a moulding flaw and is solid with the hole filled in at full depth with plastic,....... so I`m a bit stumped about what to do with it,..... might have to plank all four of them up? Cheers Tony Air-Graphics are supposed to be doing Resin update sets for the Comet, no idea what they will be as yet but the exhausts sound like they should be a contender 1
The Tomohawk Kid Posted November 13, 2018 Posted November 13, 2018 (edited) 4 hours ago, Geoff_B said: Air-Graphics are supposed to be doing Resin update sets for the Comet, no idea what they will be as yet but the exhausts sound like they should be a contender One has to be careful with AM accessories, as it won't take to many (particulary resin) to push the kit into the same price bracket as the Welsh 1/72 range of Comet kits. Tommo. Edited November 13, 2018 by The Tomohawk Kid
tonyot Posted November 13, 2018 Posted November 13, 2018 5 hours ago, Geoff_B said: Air-Graphics are supposed to be doing Resin update sets for the Comet, no idea what they will be as yet but the exhausts sound like they should be a contender Cheers Geoff,...... sure sounds like a plan to me!!! Tony
kev67 Posted November 13, 2018 Posted November 13, 2018 Its nice to see Mach2 bringing out model kits that modellers are craving for, such as the Britannia and Argosy and now the Comet, and I take my hat off to Didier, but I looked at the Comet on his stand and not being an expert, but the wings looked wrong and as mentioned the windows were all over the place, all these surely could of been corrected before it was released 1
pinky coffeeboat Posted November 14, 2018 Posted November 14, 2018 ^ And that is exactly how I feel. Jeff
Giorgio N Posted November 14, 2018 Posted November 14, 2018 I was initially very excited by the news of an affordable 1/72 Comet (IMHO £55 is a very good price for such a subject) and I was ready to take a dive in the feared Mach 2 experience to have this model in my collection, but the comments regarding the windows alignment are colling my initial reaction. Guess I'll wait and see how other modellers solve the problem before committing myself
