NAVY870
Ask all your Sea Fury questions here
With the release of the Airfix Sea Fury I thought it might be useful to park all the info in one thread.
I'll assist with technical information and info more specific to the Royal Australian Navies operation.
And of course this thing will make an appearance or three
To get things started here's a couple of shots of a NOS Mark 4E gyro gunsight as fitted to the Sea Fury. This is the bit Airfix missed
I'd like to finish my first Airfix Sea Fury in Canandian Navy colours but I'm unsure of the interior colours for the wheel wells, doors, legs and engine cowling? All the photos on line are different (possibly because they're restored examples)?
I was going to go with first my instincts and paint them the same as the lighter grey of the camouflage colours? Would this be correct? Thanks for any help in advance.
Interior of the engine cowl would probably be Hawker yellow
An example of it on the cannon spouts off our aircraft
From what I've seen RCN aircraft had the gear wells, gear legs and door painted in the underside colour.
Top topic Steve. Thanks for taking time to do this.
A quick question re Hawker yellow - how does it compare to Sky hue and tone wise?
And - landing gear. Your Fury (how jealous am I of that sentence!! LOL) seems to have EDSG legs - which I've seen on a few other pics too ( or at least "dark" legs) - but was it a RAN feature?
Jonners
Judging by the RN Historic Flight’s FB11 (yes, I know that assessing colours from modern restored airframes is fraught with risk), Hawker Yellow is not at all like Sky - it lacks the green tint.  More like a buff / tan  colour.
If you look in the BM walkrounds section you will find some detail shots I took of an FB11 under deep restoration (to Flight, I assume) at Duxford.  That shows the colour clearly.
Scroll down below the T20; the 8th photo down shows Sky & Hawker Yellow adjacent to one another around the wing root radiator
Edited by Ex-FAAWAFU
Think i`ll be sticking with the recommended Humbrol 74 for that colour, seems a reasonable match given the different lighting conditions.
     Mylo
Cheers - thanks for that - I was looking at those pics the other day too! DOH!
Having seen the cannon tunnels though I may have to see if I can include them in the model ( I know I know...)
Jonners
Markings question for WJ236, one of Airfix kit's in-box selections.  I saw a single picture of this a/c years ago as cover art for a book on the Sea Fury that I should have bought.  It's been the one I want to do ever since and I want to do her justice.  Regarding the underwing serial codes, the kit markings are in Sky but the picture I remember seems to show these codes in a much lighter color that the under surface.  How then to do we know that the original serials were repainted in "fresh Sky" instead of white, or even very pale grey?
Thanks, Jim
Humbrol 74 is pretty close to Hawker yellow.
I did discuss with Airfix and supply them with references.
Jonners
Our aircraft has had the main gear legs changed out at some stage, possibly when it was with the CSIRO.
The legs should be sky, whats on ours looks like some type of primer.
Did the oblique camera port behind the wing root always go on the left side, or could it also be installed on the right side?
Larry
Larry
From AP.4018B Volume 1 Sea Fury FB.11 General & Technical
"9. Provision is made for carrying vertical
and oblique camera's for photographic &
reconnaissance duties. The mountings per
mit either 5 in; 8 in;14 in or 20 in cameras
to be used. The oblique camera can be mounted
in either side of the monocoque. The camera
controls are mounted in the cockpit"
Great info, thanks. I have never seen a photo of a Sea Fury carrying a vertical camera, that would be interesting to build.
Larry
Apart from an OOP "Final Connections" 1/48 Bristol Centaurus does anyone one else make one of these engines? I'm guessing CMK or Vector might bring one out in the near future
54 minutes ago, Max Headroom said:
If going for total accuracy, then this won't do. The Hercules is a 14 cylinder engine while the Centaurus is 18 cylinders.
Chris
Oops. I seem to always mix up the two :blush:
Trevor
The panel behind the exhaust steel one is moulded closed in the kit but in many photographs is shown open like the one attached.
How did it work? Was it a simple hinge or did it slide inside?
Thanks.
Richard
Hawker_Sea_Fury_T20_VX281_120-VL_(G-RNHF
Thanks.
Richard
Its the cooling air outlet
Its chain driven and controlled via a thermostat.
I've got pics somewhere
From my (limited, museum) experience: for the mains, wheel wells are grey over Hawker yellow; gear legs are painted silver; gear doors are chromate green(?  it's the same shade as inside the intakes) inside.  Tail wheel is a mish-mash: well is grey inside, doors and retraction struts are yellow chromate inside; the upper strut is chromate green while the lower portion is a heavily chipped silver paint over chromate yellow.
The same green can be seen inside the engine cowling.
Again though, this is a museum aircraft, so YMMV.
Hi - So here's my conundrum.
Landing light under the port wing - any pics anywhere? ( online I've found nothing).
I'm talking about the single lamp, not the double light installation under the starboard one.
cheers for any help
Jonners
cheers for any help
Jonners
Maybe I missed it but when I saw the sprue shots did Airfix miss the window for the other double light in the starboard wing?
We have a Sea Fury here in Alberta at the museum in Calgary so that is a good thing if I need to go get some detail shots. It has the two light feature.
