perdu Posted December 1, 2023 Author Share Posted December 1, 2023 I need to provide a rotorhead gear suitably sized to compliment Alan's wonderful resin and no, the thing in the kit is nowhere near good enough fettling begins I ned a suitably tapered tube to which can be affixed the composition of struts doodahs and whizzits that comprises the beautiful piece of rotating sculpture Above are: A tapered tube made from the Evergreen Rod & Tube set, apply warmness and gently pull a length into a smooth taper. A length of Aeroclub slim tube to become the base rod on the gearbox. A length of 0.030" Evergreen rod to centralise the mixture and provide the core of the unit. These items are now sitting in my Hand grip tool awaiting inspiration Tested concepts offered to you exclusively, herewith one pylon test fitted on the model. Come back in a while, I've to work out how to make the basic spider with additional rubbery feet... Happy days... 15 Link to comment Share on other sites More sharing options...
giemme Posted December 1, 2023 Share Posted December 1, 2023 Ingenious! Ciao 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted December 1, 2023 Share Posted December 1, 2023 4 minutes ago, giemme said: Ingenious! Ciao Cosa ha detto! T. 2 Link to comment Share on other sites More sharing options...
giemme Posted December 1, 2023 Share Posted December 1, 2023 4 minutes ago, Terry1954 said: Cosa ha detto! Brilliant Terry, but if you really want to sound Italian, you should instead write "Idem" Ciao 4 Link to comment Share on other sites More sharing options...
perdu Posted December 1, 2023 Author Share Posted December 1, 2023 You two! Get a room. 😝 4 Link to comment Share on other sites More sharing options...
perdu Posted December 4, 2023 Author Share Posted December 4, 2023 And here in this room I have been playing with white plastic, black plastic and Albion Alloys tubes and rods. Because sadly this Isn't 1/72 scale I'm sad to say, this rotor head is one of Alan's wonderful 1/48 scale parts, but having it to hand has allowed me to work to a guide. Very rare for me when I have some scratchbuilding to do and very welcome for that reason. Alan's rotor head has the later hydraulic blade dampers fitted, now I have to decide if I'm going to copy that or fit the fixed rod rubber (Silentbloc?) blade dampers instead. Hydraulic version And the fixed rubber block type Decisions huh? I can decide later, off for an audiology appointment... 12 Link to comment Share on other sites More sharing options...
giemme Posted December 4, 2023 Share Posted December 4, 2023 So you are going to build a 1/48 version, right? Top job on the blades and rotor! Ciao 1 3 Link to comment Share on other sites More sharing options...
Chewbacca Posted December 4, 2023 Share Posted December 4, 2023 Only just found this thread. Superb work and as others have said, are we sure it's 1/72? To go right back to page 1 though when most of the discussion was about Lynx, BERP stands for British Experimental Rotor Programme/Profile. In essence what it does is to reduce the onset of the leading blade tip approaching the speed of sound which in turn provides increased lift and permits higher maximum speeds. I went to a fascinating lecture a few years ago given by one of the designers at Westlands and he took us through the maths behind it, but don't ask me to try to remember that! I sold my soul and returned to General Service in 1992 and to the best of my knowledge there were no operational Lynx flying with BERP blades then. I think the first ones started appearing around 1994. Distraction over, back to the Scout 🙂 3 1 Link to comment Share on other sites More sharing options...
perdu Posted December 4, 2023 Author Share Posted December 4, 2023 I expect the imperative to return to G.S was inexorable so I promise not to think badly of you sir. This seems a good time to mention there are still Lynxes in the pattern, but the Scout and possibly her sister are way up the 'list' for now. I have still not decided upon the blade damper question's answer, tomorrow will be the day of destiny, OK? Today a tadlet of paint helps define the situation. It became obvious that the Nimbus was situated too close to the rotor MGB and the gap at the rear for the drive shaft extension being too big, just because, off it came... Except for the damper this new 1mm further back look seems poifeckt so I'm leaving it here. Obviously shifting the engine meant other displacements which were ready to be replaced too, oil cooler unit here and other displaced pipes tomorrow. Sorry Ian, it seems I wobbled. A fresh batch of acetate is on order for tomorrow, then I can begin making windows and correcting mis-shapes. Busy days a'coming 11 2 Link to comment Share on other sites More sharing options...
perdu Posted December 4, 2023 Author Share Posted December 4, 2023 It was decided, hydraulic blade dampers Awaiting oil reservoirs for each damper cylinder We will see tomorrow whether these pots are big enough or even (and probably) too dumbned big... ciao 11 Link to comment Share on other sites More sharing options...
perdu Posted December 8, 2023 Author Share Posted December 8, 2023 Yup they were too big so newer smaller damper reservoirs were put on instead Resulting in busy but not obtrusive, much more to my taste in scratchbuilding. Underneath, the (harmonic?) dampers and other control links are in place too. No that isnt the final colour of the blades but basically a discloser ready for finalising later The airframe has had a coat of RAF Dark Green ready for the Dark earth when it arrives, I'm giving Hataka paints a thorough test these days and so far I kinda like the stuff. The new RAF Dark Earth should arrive within a day or so Today I've been working on the tail rotor, just needs to be trimmed now and have the pitch change gear added. You possibly noticed, no engine! I decided to take it off rather than get paint all over it and it is only attached by the few pipe ends, engine throttle control rods and four mounting points so its easy to refit it. 17 Link to comment Share on other sites More sharing options...
Brandy Posted December 9, 2023 Share Posted December 9, 2023 Love the rotor head Bill. Wobbling excused! Ian 2 1 Link to comment Share on other sites More sharing options...
Terry1954 Posted December 9, 2023 Share Posted December 9, 2023 I'm with Ian. Beautiful work on that rotor head. I was wondering whether you had used Fusion or maybe Blender ................... then I realised it was probably Billder! Great stuff. T. 5 Link to comment Share on other sites More sharing options...
AdrianMF Posted December 9, 2023 Share Posted December 9, 2023 Wondrous stuff Bill. The rotor head is a thing of beauty sublime complexity. Regards, Adrian 3 1 Link to comment Share on other sites More sharing options...
perdu Posted December 10, 2023 Author Share Posted December 10, 2023 Getting a bit more like now Hataka Dark Earth arrived yesterday and gets an early run out on the Scout, I like it a lot. I brushed it using the Army Painter Wet Palette and it behaved very well. I'm still finalising the airframe I will be modelling and having put a lot of pieces into the tail rotor I think I will paint it red, white and black rather then the later black and white flicker pattern to let it catch the eye on the table Choice then as to whether it will be early scheme with white serials and the RAF style fin flash too or later with black serials and lettering and no fin flash. It does seem odd having RAF type markings on an army aircraft... Adieu 12 Link to comment Share on other sites More sharing options...
perdu Posted December 10, 2023 Author Share Posted December 10, 2023 The counterweights and pitch change machinery on the tail rotor, the inner counterweights have not yet been 'bobbled' with Cockpit Glue blobs I ought to admit working this small has gotten almost beyond me, is this a warning I'll have to work bigger I wonder. Does the dreaded 48th scale sit quietly sniggering in the corner awaiting catching me in its claws I wonder? Anyway I aint'nt there yet. 10 Link to comment Share on other sites More sharing options...
giemme Posted December 10, 2023 Share Posted December 10, 2023 You're still doing good at 1/72, Bill - in fact, excellent! But 1/48 is tempting, isn't it? Ciao 2 1 Link to comment Share on other sites More sharing options...
AdrianMF Posted December 10, 2023 Share Posted December 10, 2023 1 hour ago, perdu said: dreaded 48th scale sit quietly sniggering in the corner Not on the evidence of this build! You might have to do bigger pictures for us lot though... Regards, Adrian 6 Link to comment Share on other sites More sharing options...
perdu Posted December 11, 2023 Author Share Posted December 11, 2023 OK it seems that the most important collecting pieces and getting ready for assembly work is complete so in the next few days I will begin closing up and some decalising too. The dark earth coat is good enough for me and the seats and rear doors are ready to go in the proper places. And inside the rear doors some of the basic structure has been added, a rare departure for me 'cos I usually just leave inside them bare. Yes the Hataka paint will be easily removed with a pointy stick from the runaway pieces and the substructure of the doors will be appended after the exterior colour is finalised. I'll be happy enough with that Adieu 16 Link to comment Share on other sites More sharing options...
giemme Posted December 11, 2023 Share Posted December 11, 2023 Well, you should be! Ciao 1 1 Link to comment Share on other sites More sharing options...
alxzinbox Posted December 11, 2023 Share Posted December 11, 2023 Stellar work so far Perdu! Those hydraulic lines complete the resin engine. Great job 1 Link to comment Share on other sites More sharing options...
perdu Posted December 13, 2023 Author Share Posted December 13, 2023 I sometimes wonder if I would be happier if somebody stole my hard drive and all the photographs in it Before whenever I have built a Scout I've been happy enough to just stick the bulgy windows in place and move on, but... I keep researching these little beasties and saving photos, like that one above with the insides of the bulges. This one All that stuff inside, how can I leave it out? I dont think I can, thanks to OCD ness So I had to stick a lower edge to the doors And phoney up some innards For me this is enough, for you? I am going to tidy up the Medium Sea Grey on the lower lip too of course. 11 Link to comment Share on other sites More sharing options...
Terry1954 Posted December 13, 2023 Share Posted December 13, 2023 Excellent innard details in those two doors Bill. OCD ness has its uses! Terry 1 4 Link to comment Share on other sites More sharing options...
hendie Posted December 13, 2023 Share Posted December 13, 2023 I agree completely. Bills innards are indeed a wonder to behold. 4 Link to comment Share on other sites More sharing options...
Hamden Posted December 14, 2023 Share Posted December 14, 2023 Stunning engineering on those two rear doors Bill as we expect with your work Stay safe Roger 1 1 Link to comment Share on other sites More sharing options...
