Jabba Posted March 26, 2015 Share Posted March 26, 2015 This will be my model for this GB, in that it will be a Douglas DC-8 Srs 72F of the Armee De L'air from the Gulf conflict of 1991 time period. I did find a picture of one of these aircraft in my numerous books, but can I find it now. I will be using a Minicraft DC-8 Srs 73 model with the appropriate modifications plus the markings coming from Fdcal. Anyway some pictures. Le model. Les instructions. Le parts. Les decals dans le model et la canopy. Le nouveux (?) decals. One of the first jobs that I will have to do is cut down the fuselage halves to the correct size. After asking this question on the civil aircraft section quite a while ago I got the answer that I should cut out the sections that I have marked. I shall hopefully start tonight. 6 Link to comment Share on other sites More sharing options...
Wez Posted March 26, 2015 Share Posted March 26, 2015 Welcome Jabba, good to see you along for the ride! Interesting subject this, I'm sure you'll do it your usual justice. Wez Link to comment Share on other sites More sharing options...
stevej60 Posted March 26, 2015 Share Posted March 26, 2015 Very interesting choice,looking forward to this. Link to comment Share on other sites More sharing options...
CliffB Posted March 27, 2015 Share Posted March 27, 2015 The L'Armee de L'air scheme looks very attractive and I'm looking forward to being introduced to the Art of Masking! Cliff Link to comment Share on other sites More sharing options...
Graeme H Posted March 27, 2015 Share Posted March 27, 2015 Nice choice Link to comment Share on other sites More sharing options...
snapper_city Posted March 27, 2015 Share Posted March 27, 2015 Nice choice. Link to comment Share on other sites More sharing options...
Jabba Posted March 29, 2015 Author Share Posted March 29, 2015 A quick update, in that the bits that needed chopping out of the fuselage have been chopped out and the fuselage is now all back together again. I managed to do some work on the wings at Hinckley todau and will post piccies later. 4 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted March 30, 2015 Share Posted March 30, 2015 (edited) Good morning Jabba Good job so far .. Edited March 30, 2015 by TEMPESTMK5 Link to comment Share on other sites More sharing options...
TEMPESTMK5 Posted March 30, 2015 Share Posted March 30, 2015 Your build reminds me of a some fliyng hours in one of these aircraft back in the time when I served in the Armée de l'air ... Regards Patrice Link to comment Share on other sites More sharing options...
jean Posted April 4, 2015 Share Posted April 4, 2015 Hi Jabba, You have started mightily well. Unlike Patrice I never flew on these aircraft, but I have seen them many times do touch and go at Evreux air base while I was crawling around in the half-frozen mud... They were impressive to watch and looked good in their un-warlike paint schemes. Have fun. JR Link to comment Share on other sites More sharing options...
Jabba Posted April 4, 2015 Author Share Posted April 4, 2015 (edited) Thanks for the kind comments, it is always good to hear from people who have either worked on, flown on or seen the aircraft that I am building, having only seen one from a distance whilst sitting in a gun pit at KKMC in Feb 1991. A quick update. The fuselage has now been joined together, filled and sanded down. I have also glued the wings together added the wing tips, filled and done all the sanding down. I shall hopefully fit the wings tonight which are a very snug fit, and it does actually say this in the instructions. I have left off the glazed and nose parts from the fuselage, because as the cockpit windows are supplied as decals on the new sheet, I thought that I could build the whole model and then determine the weight to be added before fitting these parts. Anyway some piccies. The fuselage. The wings. The wings and fuselage almost together. Edited April 4, 2015 by Jabba 2 Link to comment Share on other sites More sharing options...
ForestFan Posted April 4, 2015 Share Posted April 4, 2015 Nice start, I don't think I'd be brave enough to hack away like this! FF Link to comment Share on other sites More sharing options...
Jabba Posted April 5, 2015 Author Share Posted April 5, 2015 Nice start, I don't think I'd be brave enough to hack away like this! FF The cut lines were engraved on the inside of the fuselages, and apart from the first cut I made using a saw rather than a scalpel with a curved baled it was resumably fairly simple. The first one I started to go slightly wrong so stopped and used a scalpel, The hard part was getting them all to line up again. 2 Link to comment Share on other sites More sharing options...
Wez Posted April 7, 2015 Share Posted April 7, 2015 Regardless that there are scribed marks on the inside of the moulding, I'd always worry about getting things square again, but then it should be easy for a tradesman of your calibre! Bravo for having the courage to do it though, it's an interesting subject. Wez Link to comment Share on other sites More sharing options...
Jabba Posted April 10, 2015 Author Share Posted April 10, 2015 Regardless that there are scribed marks on the inside of the moulding, I'd always worry about getting things square again, but then it should be easy for a tradesman of your calibre! Bravo for having the courage to do it though, it's an interesting subject. Wez Thanks for the vote of confidence, but I always hated metalwork with a passion. Much easier just changing parts. A slight progress report but with no piccies at the moment. I have built up all the engines and temporarily fitted them to wings, and the tailplanes to the fuselage so that I see how much weight has to be fitted top the nose area. The fit of the engines and tailplane is so good that I will fit them after I have painted them and the rest of the model. Link to comment Share on other sites More sharing options...
Max Headroom Posted April 10, 2015 Share Posted April 10, 2015 Tres bon! This is a bit different. Trevor Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted April 11, 2015 Share Posted April 11, 2015 Nice progress Jabba, I suppose I should start my A340-200, lots of cutting as well for me. Link to comment Share on other sites More sharing options...
Jabba Posted April 15, 2015 Author Share Posted April 15, 2015 Just a very small update. Although these pictures show the model altogether, it is not quite what it seems. The wings and fuselage are glued together, but the engines and tailplanes are fitted is that I can get the weight correct so that it does not end up a tail sitter. As you can see most of it is a good fit without any glue, apart from the left hand outer engine. Since these photos were taken the canopy and nose parts have been glued on and filled. A little sanding is now required and then to paint. 5 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted April 17, 2015 Share Posted April 17, 2015 Some seriously excellent work on reducing the fuselage! Link to comment Share on other sites More sharing options...
Jabba Posted April 20, 2015 Author Share Posted April 20, 2015 Thanks for all the kind words. This is a small update of where I am at the moment. I have removed the engines and tailplanes, and then sprayed most of the fuselage, plus the areas where the roundel goes white. I have photocopied the decal sheet and some templates given by Fdcal to be cut out and act as masks whilst I paint the rest of the fuselage and some of the wing area Lt Grey. Does anyone have a suggestion as to what Lt Grey to use, as I am thinking Lt A/C Grey? Some Photos. 1 Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted April 20, 2015 Share Posted April 20, 2015 The colour looks darker than the usual Boeing grey for airliners. Pity the instructions aren't more specific. There is a good walk around here which may help you decide on the grey. Nice to see this one progressing Jabba Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted April 21, 2015 Share Posted April 21, 2015 Nice work Jabba Link to comment Share on other sites More sharing options...
Jabba Posted April 26, 2015 Author Share Posted April 26, 2015 I am having a spot of trouble at the moment. I have copied the decals several times so that I can cut out the markings required to act as stencils and have spares left over. The decal sheet instructions tell you that when you have the stencils in place to apply a mixture of milk and water (1 part to 2 mix) over the stencil and it will stick to the model. I have done this but the stencils do not stick, and just fall off even if I leave the model flat. The stencils will stick for a few minutes then fall off or lift up at the edges where I have used tape on the upper edges to hold them in place. Does anyone have any suggestions as to what I maybe doing wrong, knows a better solution or different method of applying the stencils. Link to comment Share on other sites More sharing options...
Romeo Alpha Yankee Posted April 26, 2015 Share Posted April 26, 2015 So Jabba, are these stencils decals? Laser printed I assume? Have you tried Microsol/Microset decal setting solution or similar? Another option would be to use something like Future to help bind them to the paint. Link to comment Share on other sites More sharing options...
Jabba Posted April 27, 2015 Author Share Posted April 27, 2015 Sorry I have written the wrong thing. I should have said that I have copied the decals onto paper to act as a mask whilst I am painting the grey. The instructions say to make a sloution of milk and water to be put onto this mask and it should stick the mask down, but it has not. Link to comment Share on other sites More sharing options...
