Crossiant Oliver Posted April 4, 2016 Posted April 4, 2016 Recently I got the old Frog 1/72 Vultee Vengeance set from my local hobby store. I brought it to our second house in Palm Desert (We live in Los Angeles but go there every time my school has a 3-day weekend) to build there and paint at home. Somehow on the ride there one of the propeller blades fell off and I have not been able to find it. Do you guys know where I can find a replacement Vultee Vengeance propeller? From searching it up I found some people that have replacements like Ozmods and Pete's hangar, but Ozmods has a 1/48 version of it (looking for 1/72) and Pete's hangar doesn't have it. Does anyone else know where I can find a 1/72 Vultee Vengeance propeller? Comments would be nice/
Charlie Hugo Posted April 4, 2016 Posted April 4, 2016 (edited) If you know what propeller was fitted you may be able to find it in the Aeroclub range of white metal propellers Try here http://www.joesmodels.com/AEROCLUB_72_PROPELLERS.htm Edited April 4, 2016 by Charlie Hugo
Black Knight Posted April 4, 2016 Posted April 4, 2016 Until someone gives more exact info on the prop; It looks like a paddle blade Hamilton Standard as used on CV Corsair F4U-1 and some B-17s. So if you can get one from a kit of either of those you'll not be too far off.
brewerjerry Posted April 4, 2016 Posted April 4, 2016 Hi One option maybe to do away with all the props and fit a clear plastic disc to simulate a spinning props this place sends a free sample of what they do http://www.propblur.com cheers jerry
stevehnz Posted April 4, 2016 Posted April 4, 2016 After having a wee cruise thru the googlesphere, I'm pretty certain that Black Knight is correct, the Vengeance turned a Hamilton Standard prop, very like in fact the one on a Grumman Avenger, not surprising since they both had a Wright R-2600 motor. An outfit called Pete's hanger listed a correction set of cowl & prop or seperate white metal prop for the Frog kit, probably hard to find now, but stated as a 12' diameter. Try John Adams (Aeroclub) on here or maybe Quickboost do one or someone has a spare Avenger prop in their spares box. Steve.
ejboyd5 Posted April 4, 2016 Posted April 4, 2016 Only one blade? Make a new one from scrap plastic and be done with it.
ben_m Posted April 4, 2016 Posted April 4, 2016 If you have some plasticine/modelling clay you could try making mould and casting a replacement from epoxy glue using an impression of one of the other blades? You might even be able to integrate the rest of the prop into the mould (maybe with a hole drilled where the blade will attach?) and cast the epoxy blade straight onto the remainder of the prop?
G.E.SAUNDERS Posted April 5, 2016 Posted April 5, 2016 hi , try scratch makin' a Propeller ,.... now that's modellin' ! Or look on eBay the FROG Vengeance kits are plentyful ! cheery "modellin' ' mumbas ! Geoff
Crossiant Oliver Posted April 11, 2016 Author Posted April 11, 2016 Also I have the airfix Wildcat unbuilt and I was wondering if it's the same propeller as the Vengeance
Work In Progress Posted April 11, 2016 Posted April 11, 2016 No, Wildcat props are much smaller diameter
NAVY870 Posted April 11, 2016 Posted April 11, 2016 You have a spare one? Correct, if you'd like to message me so we can arrange. Cheers
ND417 Posted February 4, 2020 Posted February 4, 2020 Hi all I'm literally in the same boat with this kit - except for me it's the wheels. I've lost one half of a wheel and to be fair they're not the best looking - was thinking of replacing them but can't work out which will be best fit as there are no aftermarket wheels for the Vengeance - thinking P-47 or P-38? (Need dust covers). Anyone know the diameter of the real Vengeance wheels? Any charts I can find only cover the usual WW2 types so can't see which is closest. Thanks in advance - sorry for re-opening an old chat.
gingerbob Posted February 4, 2020 Posted February 4, 2020 Good guess- from an interchangeability chart I have, it appears that A-35 Vengeance main wheels/tires are the same as P-38's mains.
JWM Posted February 4, 2020 Posted February 4, 2020 AFAIR Tamiya 1/72 Corsair has two props in box. Am I right? The Academy B 17 has two sets of props as weel but smaller diameter. But the advice with making a cast in resin is perhaps the best one. I will advice use of silicon ribber for form and then epoxy glue for casting J-W
Ed Russell Posted February 5, 2020 Posted February 5, 2020 On 4/4/2016 at 12:04 PM, Crossiant Oliver said: Pete's hangar, but Ozmods has a 1/48 version of it (looking for 1/72) and Pete's hangar doesn't have it. On 4/4/2016 at 11:16 PM, stevehnz said: Pete's hanger listed a correction set of cowl & prop or seperate white metal prop for the Frog kit, probably hard to find now, but stated as a 12' diameter. Pete's Hangar was demolished on his demise and the masters for his casting were dispersed. The Vengeance upgrade is one of his best efforts - many of the others aren't really worth having. @Crossiant Oliver - it would be a nice easy way to learn casting. 1
Work In Progress Posted February 5, 2020 Posted February 5, 2020 This was four years ago. I'm sure he's found a prop off an Avenger or B-25 since then. 1
ND417 Posted February 5, 2020 Posted February 5, 2020 Hi all thanks for the responses - especially gingerbob for confirming my wheel issue. cheers 1
72modeler Posted February 5, 2020 Posted February 5, 2020 Here's a Flickr photo that shows the main gear strut/wheel of a Vengeance taken at the assembly plant- you can get a good idea of relative size; the Vengeance wheel and tire looked to be more suited to a multi-engined aircraft like an A-20 or B-25, but maybe in consideration of the flying fields from which it would operate. Mike Here'
Ed Russell Posted February 5, 2020 Posted February 5, 2020 12 hours ago, Work In Progress said: This was four years ago. I'm sure he's found a prop off an Avenger or B-25 since then. Hmmm.... maybe. Some modellers are pretty slow. it wouldn't be the only plane on the Shelf of Neglect with just a small part to go!
