I am going to do this for my next build, Sword's 1/48 Lightning T.5.
This is a commission build, and I have been asked to build XS452 "Pink Flamingo", based at RAF Akrotiri in 1975
The aftermarket supplied is as follows:-
NeOmega resin cockpit set
QMT canopy mask
QMT resin FOD cover
Master Models metal pitot
Xtradecal set X48152
I'll also be using the Daco Publications Uncovering the Lightning book, for reference.
48162763351_02c7b6ce03_z.jpgF887D36B-E1FD-4014-9D03-2197EE6A09CD by ian gaskell, on Flickr
48162763831_35d3387e59_z.jpg447D2224-91E9-43A7-8B7E-DD7C523FE28D by ian gaskell, on Flickr
48162836227_ac4d81153f_z.jpg2BF6BEEF-92EF-4AE4-8212-17452BA67745 by ian gaskell, on Flickr
48265149751_abe1a31c7e.jpgIMG_0415 by ian gaskell, on Flickr
48265221097_22ae1a8710_z.jpgIMG_0416 by ian gaskell, on Flickr
Cool Another Lightning! This is almost like Christmas. Can never have too many Lightnings.😀
plenty of goodies and a lovely paint scheme!
Nice scheme, looking forward to following this. Particularly interested to see how the cockpit set fits as I was thinking of doing this myself.
Edited by Fido996
There will definitely be some work needed. The resin set is really designed to fit in NeOmega’s resin T.5 conversion set, for the Airfix kit.
A test fit shows that the inside of the fuselage halves, where the cockpit fits, will need the locating points removing.
There are also bits for the conversion sets vac-form canopy, which are redundant for he kit.
1/48 Sword EE/BAC Lightning T.5
A bit of scratch building inside the canopy.
Then masking, and painting, including the canopy glass seals on the main canopy.
Detail highlighted with some dry-brushing.
Nosecone also done. Black based, with some pre-shading, then painted Olive green. Light green Aquarelle watercolour pencil used to add scratches.
48265181432_30cbfedcaf_z.jpgDSC_4155 by ian gaskell, on Flickr
48265109281_dfb9aa1626_z.jpgDSC_4156 by ian gaskell, on Flickr
48265180312_5daf580be1_z.jpgDSC_4157 by ian gaskell, on Flickr
48265179812_4017bcc6fb_z.jpgDSC_4160 by ian gaskell, on Flickr
48265179202_0d82aa4f60_z.jpgDSC_4161 by ian gaskell, on Flickr
  • Like 9
I like that detailing on that canopy. THought for a second you have perfected the anti-radiation effect on the clear part.
Mind blowing scratch detail on that canopy. Fantastic stuff!
  • 3 weeks later...
Latest WIP update.
Due to a new job, with different hours (made redundant from my last job), I've less time at the bench now.
Cockpit and seats finished.
This is QMT’s lovely resin set.
Finished in Hataka Orange Line lacquer, and Blue Line acrylic paints.
48425627117_ab47a890c0_z.jpg063F2B54-C7B7-4D82-A745-6B93980FF23B by ian gaskell, on Flickr
48425628567_ec3dc4d9a8_z.jpg13CA70D8-010F-4D27-A504-A29C2F7F41C1 by ian gaskell, on Flickr
48425487481_03e6fac866_z.jpg97C5B4CB-564E-4AE5-9D98-205605316A2F by ian gaskell, on Flickr
48425488611_b15c9131ff_z.jpg45918B25-5CF4-4EA5-B815-7FCE5D016F4F by ian gaskell, on Flickr
48425489116_3c71930198_z.jpg5EA04440-47DD-4A3D-A537-1C8431CEBA33 by ian gaskell, on Flickr
48425627412_5737f5b1e6_z.jpg1E120F40-2DB4-4C6D-A22C-257393828BC5 by ian gaskell, on Flickr
48425488926_27ecd012eb_z.jpg105CA8BF-8826-4FE9-B002-25DE55C939E9 by ian gaskell, on Flickr
48425487201_e28a45cc25_z.jpg8E9C29A2-93A5-4228-86ED-F5598839D2DD by ian gaskell, on Flickr
48425626657_7acbdb5183_z.jpgE2CF526C-F846-4D67-9341-11AA1337BE93 by ian gaskell, on Flickr
  • Like 10
very very very nice pit!
need this QMT set... saying that for quite some tinme now.... :banghead:  and still have not done a Lightning.... although I have 4!!! (2 single seaters and 2 twoseater...)
Ian, is that the Q.M.T cockpit set? Thought you had mentioned it was from NeOmega... :hmmm:
It's awesome, nevertheless.
Highly recommended, Werner. The level of detail is real crisp. The best resin cast I've seen in years.
Unc2
Fantastic job on the cockpit 👏👏👏
What are the Hataka lacquer paints like to work with? Can they be sprayed straight from the bottle or do they need thinning?
Alan
Unc2
Thanks Unc.
Yes, original request was to use the NeOmega pit. The chap I’m building for then contacted me, and asked if minded using the QMT one instead, which he then supplied. Have to say, I’m pleasantly surprised at the level of detail.
Alan
Thank you Alan.
The Hataka paints are very good. Best to use their own lacquer thinners. Mix to 50:50, and spray in light coats, building up the colour. Gives a good hard finish. They are not as smelly as some other lacquer/enamel paints.
Cockpit successfully installed, into the fuselage. Just a bit of sanding to get a good fit, then a small amount of filler to finish off.
Also started to add some rivet detail too.
48457084487_e044614aeb_z.jpg730BA785-8382-4725-99D4-21838870A07F by ian gaskell, on Flickr
48457083912_9401c1c4c1_z.jpgEC297098-7CBE-4E6D-81B0-19EBFC6EE693 by ian gaskell, on Flickr
48456927091_8a7ab70ddd_z.jpg623E1789-9F94-4045-8C1C-AE6616954A32 by ian gaskell, on Flickr
Edited by Wee Beastie
Incorrect description
  • 1 month later...
Apologies for the long gap between updates. My new job, and subsequent change in working hours, means I am maximising my bench time, rather than spending a loads of time on updates.
So, after applying the black primer, I painted the white spine panel, and the pink tail. I mad my own pink mix, to match the pink in the decals. These were masked off, and the main metal colour airbrushed on. This is Vallejo Metal Colours acrylic Dark Aluminium.
Then a lot of time masking, and spraying, random panels and hatches, with various shades of Metal Colours.
Decals went on well. This was followed by a light, very thinned, Gunmetal Grey post shading carried out.
Now I am up to starting a panel-line wash.
48631965562_4ef1916d6e_z.jpgDSC_4217 by ian gaskell, on Flickr
48631965202_775db416b2_z.jpgDSC_4219 by ian gaskell, on Flickr
48631963602_395a8254bb_z.jpgDSC_4223 by ian gaskell, on Flickr
48699167633_faae2abe0b_z.jpgEE9ABEC8-6FE3-45D7-936A-F2C53918AACF by ian gaskell, on Flickr
48699508151_62e3941278_z.jpgE5C28A91-A517-4E1B-82F4-6970C41730FC by ian gaskell, on Flickr
48768922957_2c7eb98fa4_z.jpgDSC_5179 by ian gaskell, on Flickr
48768720646_cef888cdf6_z.jpgDSC_5184 by ian gaskell, on Flickr
  • Like 10
