You know the scenario -  1:72 joystick attached to runner in such a way that pressing down with a hobby knife/scalpel will exert enough force to snap the part instead of cutting it free.
What tool would you use instead ?  Vaguely recall from the Airfix tv show that they were using what looked like very narrow bladed shears or something.
Tricky bits I use a razor saw. Top one is RB, bottom Tamiya.
Razor Saws
Ray
My approach would be to hold the part firmly between finger and thumb and use a razor saw - like @Ray_W suggested. I have the Tamiya set of p.e. saws:
A suggestion, a hot wire or knife,  one of those thing that used to used for carving expanded polystrene, or a pin mounted in a soldering iron are in a similar vein.
Not tried it but should not stress the part, though heat could distort part if too close.
Thanks all for the good and numerous suggestions.
Looking into various nippers and saws.
I will sometimes use a rotary tool with a fine cutting blade and cut the sprue "frame". That way I can take out the piece still attached and then I go in with nippers while holding the small part between my fingers. The sprue flies off without damage to the part.
I think dynamite might shift it. I've never tried it but there is an outside chance that the blast might deform the house a little. 🤣
I'm sorry Troy, I can never resist the gift of a joke.
Completely agree @Ray_W's suggestion of a saw. The JLC saw is my 1st choice to remove fine parts or anywhere else I need to cut the sprue cleanly without any chance of collateral damage. A mitre box is also available.
Razor Saws
Ray
As Crocodile Dundee almost said, "That's not a Tamiya saw...
y4mZlQGPXYOuH7R7Q78dfXbNSBHzodCtJ3hBust3
..THIS is a Tamiya saw." 😆
I use this. It's a bit of broken CMK razor saw in a pin vise.
Chris
For the last year I've used a pair of Modelcraft side cutters which prior to that I never knew existed and they've been a revelation.  Clean and accurate cuts with no collateral damage or pressure causing parts to depart the scene in  a parabolic arc the way they used to.
https://smile.amazon.co.uk/gp/product/B001AE5ZTQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Sometimes I find it best to cut away the rest of the sprue nearby, so as to allow straight access to the part in question
