su27rules Posted May 22, 2016 Share Posted May 22, 2016 Fantastic!! 1 Link to comment Share on other sites More sharing options...
Will Vale Posted May 23, 2016 Share Posted May 23, 2016 Lovely stuff, that green is really rich. 1 Link to comment Share on other sites More sharing options...
Andy Moore Posted May 23, 2016 Author Share Posted May 23, 2016 Lovely stuff, that green is really rich. Thanks Will. The green is Gunze H26 Bright Green, which I guess is pretty close to Tamiya Park Green. I wasn't really sure about the colour, but I didn't want the whole thing to be yellow. It clashes a bit with the X-Wing, but hopefully it'll look better once all the base is painted up Andy Link to comment Share on other sites More sharing options...
ScanmanDan Posted May 23, 2016 Share Posted May 23, 2016 Oh, Andy. I so like your work. I'm always inspired to try to do more with my builds after I see what you are doing. Your layout of bits is quite interesting. Did you think about the overall colour composition or did it just come about naturally? I like how the yellow primer on the X-Wing works with the yellow on the support equipment . How you have touches of green gear in the equipment bay and on top of the big wheeled unit. Do you purposely limit your colour choices or jut work by eye? I'm very intrigued to see what colours you use in your ground work to tie it all together, warm or cool greys? Browns? and which accent colour you go with if you do any painted markings. As always thanks for sharing your inspiring work. Dan 1 Link to comment Share on other sites More sharing options...
GazB Posted May 23, 2016 Share Posted May 23, 2016 What materials do you use when constructing a base, Andy? I'm considering doing a few for some of my recent works Gaz 1 Link to comment Share on other sites More sharing options...
Andy Moore Posted May 23, 2016 Author Share Posted May 23, 2016 Oh, Andy. I so like your work. I'm always inspired to try to do more with my builds after I see what you are doing. Your layout of bits is quite interesting. Did you think about the overall colour composition or did it just come about naturally? I like how the yellow primer on the X-Wing works with the yellow on the support equipment . How you have touches of green gear in the equipment bay and on top of the big wheeled unit. Do you purposely limit your colour choices or jut work by eye? I'm very intrigued to see what colours you use in your ground work to tie it all together, warm or cool greys? Browns? and which accent colour you go with if you do any painted markings. As always thanks for sharing your inspiring work. Dan Thanks Dan. I'd like to say there was some grand plan when I do things like this, but really I just go with gut instinct, and hope for the best. When I painted the bay interiors in yellow I hadn't even thought about any ground equipment. I went with the yellow on the accessories because it had looked alright on the support cradle I made for the Snowspeeder, and when I painted the tanks in green, I just picked the colour because I thought it might contrast well with the yellow. I'd forgotten that there was a similar colour on the X-Wing. The groundwork is meant to be concrete so it'll be a pale grey. I'd normally do concrete in a warm grey tone but here I think I'll try a cooler tone to blend the concrete areas with the snow landscape at the side, and also to offset all the warmer red and yellow tones in the rest of the diorama. I'll probably go with a pale cool blue for the ground markings for the same reason. I'm still not sure how it's all going to look at the end. There's a lot of very intense colours going on here, which is something I'm not used to dealing with. What materials do you use when constructing a base, Andy? I'm considering doing a few for some of my recent works Gaz I usually use photo frames for bases as they're cheap and come in a variery of colours and sizes. In this case I removed the glass from the photo frame, then hot-glued a piece of 5mm MDF into the aperture. The hardstanding area is a piece of 0.5 plasicard, which I'll glue strait on to the MDF. I'll make the landscaping from Das clay, then figure something out for the snow on top. Andy 1 Link to comment Share on other sites More sharing options...
TomCZ Posted May 23, 2016 Share Posted May 23, 2016 great build AFV - perfect, sci-fi - perfect, anything else you build Andy ? 1 Link to comment Share on other sites More sharing options...
GazB Posted May 23, 2016 Share Posted May 23, 2016 I usually use photo frames for bases as they're cheap and come in a variery of colours and sizes. In this case I removed the glass from the photo frame, then hot-glued a piece of 5mm MDF into the aperture. The hardstanding area is a piece of 0.5 plasicard, which I'll glue strait on to the MDF. I'll make the landscaping from Das clay, then figure something out for the snow on top. Andy Cheers Gaz 1 Link to comment Share on other sites More sharing options...
Andy Moore Posted May 23, 2016 Author Share Posted May 23, 2016 great build AFV - perfect, sci-fi - perfect, anything else you build Andy ? Just the usual. Some armour, some aircraft, some sci-fi... the occasional pig with a teapot on it's head You know, regular stuff Andy 6 1 Link to comment Share on other sites More sharing options...
Will Vale Posted May 23, 2016 Share Posted May 23, 2016 Gracie! Don't forget da Orks: Deff Dread by Andy Moore, on Flickr If anyone hasn't already spent time browsing Andy's photostream on Flickr, you should. Pages and pages of awesomeness Will 3 Link to comment Share on other sites More sharing options...
Richard E Posted May 23, 2016 Share Posted May 23, 2016 If anyone hasn't already spent time browsing Andy's photostream on Flickr, you should. Pages and pages of awesomeness :)Will Models, CGI renderings (?) and photography - a cross section of a genuine talent Andy 1 Link to comment Share on other sites More sharing options...
baldrik1978 Posted May 24, 2016 Share Posted May 24, 2016 (edited) Are there any words that I can type or say that will truly get across how amazing your work is. You've done it again, made everyone jealous with your amazing skills. Such a shame that the movies now use CGI for a lot of the ships because with your amazing skills you would be working on the movies I have no doubts about that Edited May 26, 2016 by baldrik1978 1 Link to comment Share on other sites More sharing options...
Tango 1 Posted May 24, 2016 Share Posted May 24, 2016 Andy, amazing work! The x wing, droid, ground equipment-all top notch! Thanks for sharing all your idea's with us. I was wondering how you made your bases, that is something I would like to try myself. As always, it is a real pleasure to see your work. 1 Link to comment Share on other sites More sharing options...
Hunter Rose Posted May 24, 2016 Share Posted May 24, 2016 Steps and generator look lovely! 1 Link to comment Share on other sites More sharing options...
Andy Moore Posted May 27, 2016 Author Share Posted May 27, 2016 If anyone hasn't already spent time browsing Andy's photostream on Flickr, you should. Pages and pages of awesomeness Will And don't forget to check out Mr Vale's portfolio while you're there. I seem to have been busy with everything under the sun for the last few days, but I've finally got a bit more work done on the base. As a recap, I started with a 9" square photo frame into which I glued a piece of 5mm MDF The hardstanding area is a piece of 2mm plasticard. As Will pointed out earlier in the build, the hardstanding needed turning slightly to improve the composition. This required a couple of fillets of plasticard to fill in the corners, but I think it will look better like this Next thing was to make up the revetment wall section that will go down the back edge of the base. The basic construction was just styrene sheet with bulkheads inside to give it some strength And this is how it will sit on the base The wall was then detailed up with some ribbed styrene panels, and various other bits and pieces I'll be painting the hardstanding area and the wall separately then, when they're done, I'll add the groundwork at the back of the base. To start with I've pre-shaded the hardstanding, then I'll start getting some paint on later Andy 12 Link to comment Share on other sites More sharing options...
Nigel Heath Posted May 27, 2016 Share Posted May 27, 2016 Love that revetment, the base is going to look great. 1 Link to comment Share on other sites More sharing options...
Hockeyboy76 Posted May 27, 2016 Share Posted May 27, 2016 Agreed, another fantastic build Andy. 1 Link to comment Share on other sites More sharing options...
R0ver Posted May 27, 2016 Share Posted May 27, 2016 Wow! Your skills are ridiculously good. Something to aspire to, but first & foremost drool over. 2 Link to comment Share on other sites More sharing options...
Richard E Posted May 27, 2016 Share Posted May 27, 2016 Welcome back, I was starting to get withdrawal symptoms 1 Link to comment Share on other sites More sharing options...
ScanmanDan Posted May 28, 2016 Share Posted May 28, 2016 (edited) Your base is coming together well. I'm hanging out for the paint . Andy you must have an interesting collection of bit and pieces because you seem to come up with just the right widget to add that neat detail to your builds. That bulkhead door is killer. Dan Edited May 28, 2016 by ScanmanDan 1 Link to comment Share on other sites More sharing options...
Tango 1 Posted May 28, 2016 Share Posted May 28, 2016 I'm loving this!!! Thanks for showing us how it's done Andy! 1 Link to comment Share on other sites More sharing options...
Caerbannog Posted May 28, 2016 Share Posted May 28, 2016 Your builds are just great - this one is another highlight. René 1 Link to comment Share on other sites More sharing options...
Andy Moore Posted June 1, 2016 Author Share Posted June 1, 2016 Thanks everyone. Sorry for the lack of updates. Hopefully it should speed up a bit now. The base and revetment wall have both had a grey base coat over the pre-shading. These were mostly mixed from different Tamiya greys, with white added to lighten them. The revetment was intentionally darker, and had a little aluminium mixed in with the grey as I wanted it to look more like a metal structure than the concrete on the hardstanding. Both the hardstanding and the wall have had mottled over-sprays in paler tones to give them a more weathered look To try and get a more mottled, concrete-y look to the base, I sponged some masking fluid on in as random a fashion as I could The base then had a patchy spray with a darker grey tone. Some areas had more coverage than others, again to make the whole effect as random as possible The effect of the sponge masking inevitably looks a little obvious in places, so I'll probably do a second (and maybe third) round of masking and spraying, which should make the effect subtler but more complex at the same time (hopefully). Since I'd got a bit of the darker grey left over, I speckled it over the surface to give some finer detail, then thinned it and brush painted some corners and along panel lines to add more shading, and knock back some of the contrast from the masked shading That's helped it look a little more natural, but it'll still need the second layer of masked shading to blend it together better. At the end, I'll give it all a thin mist coat of pale grey to further blend and soften the effects as, being 1/72, I don't want the textures to be too strong, or it'll all look out of scale. Hopefully I should get some of that done tonight Andy 10 Link to comment Share on other sites More sharing options...
Nigel Heath Posted June 1, 2016 Share Posted June 1, 2016 Some great tips on base painting there. 1 Link to comment Share on other sites More sharing options...
Will Vale Posted June 1, 2016 Share Posted June 1, 2016 Looks good, the colours are great! I think you should mask half the panels with tape before the next round of masking fluid, so you get some blotches that don't cross the expansion gaps. That would help it look like separate concrete pours. My 2p, Will 2 Link to comment Share on other sites More sharing options...
