I use this stuff, not sure if you can get any more but take any bandage and carefully remove
a few strands from it and you can you use that as well.
HTH
Dan
I'm currently making one of these. It's just a horrible OOB cross breed. No PE or extras so I'm not expecting it to look that good.
It's my first bit of armour though and I'm fairly enjoying it! Any tips you can pass on are well appreciated. I think weathering will be the biggest struggle for me.
Edited by DAG058
Thank you chaps, DAG058, the weathering is the best bit fella. Looking forward to seeing some of your builds.
Right, the scrim has been added to the netting, will look better under a coat of primer, still needs some titivation to get it looking right.
Dan
That's a fine bit of camo Dan.
Like the use of scrim around the barrel.
Lovely job :thumbsup2:
Cheers foxy :coolio:
Great build Dan, did you have any issues on fitting upper to lower hulls, when I test fit mine at the front, the rear is about 25 - 35mm out. I suspect this is just normal resin warping? If you did, how did you fix it?
Chris
Chris
Hi Chris, I had the same issue and I sorted it with the Mrs hairdryer. Just warmed up the upper hull and taped it to the Tamiya lower hull to cool down, it was
relatively easy but don't over do the heat, it can go south quickly. One other way is hot water, as hot as your fingers can stand to flex it back into shape and then set the position with cold water. This is probably the best way TBH.
Good luck with your build and I'm looking forward to seeing it on the forum fella.
Regards
Dan
Like your scrim very ingenious method.
Looking forward to seeing it in war paint
Roger
..and how many calories are in that scrim net, Dan? :hmmm:
Hi All.
Mike, I don't think it would do you any good eating the cam on the barrel mate.
Primer time, turret is the first up as I have to modify the track skirt brackets on the side.
I'm going to try something different with the preshading, hopefully it will work :-)
Regards
Dan
Can't believe the effect you managed with that scrim, Dan. I've never managed to get it to look as good.
Only thing is you seem to have left the fume extractor uncovered. I did this but found it was a mistake!
We can sort that no problem :winkgrin:
Might be worth checking reference pics, Dan!
Thanks Matt, So when are we going to see an update on your build ?
Dan
Here we are, Fume extractor is now camed up :-)
The lower hull is currently drying off after a prime, I've found loads of pin holes on the rear
engine bulkhead that will require filling with Mr surfacer but we are very close to getting the base colours on.
Dan
Preshade time, Tamiya XF-1 and Tamiya XF-2 just roughly sprayed over the tank.
Leave this dry and then onto Tamiya NATO Green lightened with a bit of buff
Regards
Dan
Thank you guys, I should be getting the basic green and black cam on today, I might add a dark brown first to the pre shading
Around the running gear .
Regards
Dan
Dan
Only just back from holiday, and the stuff I needed to get on arrived two days before we left when we had Sunray's mother over from NZ to contend with, and packing to do. Trying to get mojo for the tank going again, as Sunray Minor has just been given a 1:76 Cromwell this could be sooner rather than later, I hope!
