Dads203 Posted August 10, 2014 Author Posted August 10, 2014 Thank you chaps for the comments, Back to the PE side now, front splash guard fitted and some resin track guard brackets on the sides. A bit more mud on the back side of the road wheels. Please enjoy and pass comment as fit. Regards Dan 2
Dads203 Posted August 10, 2014 Author Posted August 10, 2014 Side skirt fitting, some adjustment required but looks good, Resin bolts are by Calibre 35. More padlocks Some static grass added to the mud. Enjoy Dan 3
longshanks Posted August 10, 2014 Posted August 10, 2014 Wow! The detail is really coming together now, your positvely flying along Love the muck - you always was a mucky bugger . . . . Where do the padlocks come from Cheers Kev
Dads203 Posted August 10, 2014 Author Posted August 10, 2014 Wow! The detail is really coming together now, your positvely flying along Love the muck - you always was a mucky bugger . . . . Where do the padlocks come from Cheers Kev Cheers Kev, The padlocks came with the conversion, I think Accurate Armour sell them separately though. Cheers Dan
Dads203 Posted August 10, 2014 Author Posted August 10, 2014 Right, I'll leave you with these photo's for the night. Have a pleasant evening folks Dan 2
C&WR Posted August 11, 2014 Posted August 11, 2014 This is looking better and better, Dan. Those skirt plates really are the bizzo. Nick's post was interesting. However with regard to this the Skins did things differently: ...Callsign boards were call sign boards and remained on all the time in fact most of them were painted directly onto the vehicle. Different units though, had different ways of applying them and as the years went by the colours mostly changed to Black and Green colouring instead of yellow... Yes we had the yellow and black callsign boards, but the callsigns were also painted on in black on the vehicle itself. We used to take the boards off on exercise, IIRC. 1
Guest Posted August 12, 2014 Posted August 12, 2014 I hated those plates so ,,,,,,, heavy Looking good
Dads203 Posted August 12, 2014 Author Posted August 12, 2014 Thanks chaps, I've been adding the turret tiedowns, small and fiddly work but I think it's worth going the extra mile. More to follow Dan 1
Dads203 Posted August 12, 2014 Author Posted August 12, 2014 Commander hatch and fitting now in place. And the NBC pack handle along with the Clansman antenna base. Cheers Dan 2
longshanks Posted August 12, 2014 Posted August 12, 2014 Love the skirts ! Hows the eye brows ;o) Kev
Hamden Posted August 13, 2014 Posted August 13, 2014 Very nice attention to detail is stunning! Roger 1
Dads203 Posted August 13, 2014 Author Posted August 13, 2014 Cheers for the comments chaps, Little bit more done, I've finished the tiedowns on the turret roof and started to add the wing nuts to the clansman antenna bases, only done one as its very tricky to do. The whip antenna is carbon rod by Accurate Armour. Cheers Dan 1
Dads203 Posted August 13, 2014 Author Posted August 13, 2014 Second antenna pot done, just needs a trim one the glue is dry. Cheers folks Dan 3
longshanks Posted August 13, 2014 Posted August 13, 2014 The devil is in the detail ;o) I can smell paint in the wings Kev
C&WR Posted August 14, 2014 Posted August 14, 2014 Cracking stuff, Dan. I'll be referring to your winky pot stand when I start up on mine again!
Dads203 Posted August 14, 2014 Author Posted August 14, 2014 Thanks chaps, The kit is now very heavy with the tracks on so just as well the suspension parts are quite beefy! I have my replacement blowtorch so can get back to work on the soldering of the side skirts, the old one I have had for about 15 years or so and it kept flairing up in my face, I reckon one of seals had perished on the regulator and the tip would go out and engulf the whole torch in flames... I threw it in the bin. Kev the eyebrows are okay, just ! So the left hand side has been started. 2
C&WR Posted August 15, 2014 Posted August 15, 2014 Soldering with a blowtorch? That's proper manly, I use an iron 1
Dads203 Posted August 15, 2014 Author Posted August 15, 2014 Soldering with a blowtorch? That's proper manly, I use an iron It's only a small gas torch :-) I've used the same one for years and they work well with liquid solder. Cheers Dan 1
Dads203 Posted August 16, 2014 Author Posted August 16, 2014 The last few PE bits added before primer, should go on this weekend More static grass added to the running gear on the area that will be missing a side skirt. Turret is ready for primer now but I'll be adding the scrim on the gun barrel first. Cheers Dan 1
Dads203 Posted August 16, 2014 Author Posted August 16, 2014 Cam for the main gun is done, just need to wait for it to dry and i'll add the garnish from mixed herbs. Used water and PVA mix to glue it to the barrel, once dry it will get a bit if a trim up. Dan 1
DAG058 Posted August 16, 2014 Posted August 16, 2014 (edited) What did you use for the cam net? The mud and grass looks great too, what are they made from? Edited August 16, 2014 by DAG058
