If the instructions tell you to paint them metallic, I tend to do as I'm told, then use a dark wash to bring out the detail on the fins and other areas.  For other colours, just sub the metallic for that colour :)
I've really got to do a few more jets :tired:
The why is simple: to make the cooling fins more visible in a model. The contrast between the metallic fins and the dark recesses will make the former "pop" instead of disappearing in the little room inside a scale model cowling.
Regarding the two techniques, it's a matter of taste and which one each modeller finds easier. Personally I prefer a metallic coat followed by a wash. Working in 1/72 I generally paint the engine parts in their colours and then apply a dark wash to the whole engine, essier for me than trying to drybrush each cylinder. However I've seen others using the drybrush technique and achieving great result
Also, whose engines? American, British, German, Japanese? Different countries did different things at different times.
Chris
Another thing to think about is whether you have a one-piece engine, or fourteen separate cylinders and a crankcase.  Dry-brushing is a lot harder with a one-piece because you have to get the brush between the front row cylinders to do the back row - and even if it's just one row, your efforts will stand out better on the tops than down the sides.  Normally that's not too great a problem within a cowling.  But for an even effect all over, a wash is likely to be easier.  I've just used neat Tamiya Smoke (X19) over some Mr Metal Stainless on a couple of BMW 801s and it's just the effect I wanted.
The best way to answer your own question is to do what all scale modellers should do all the time - find contemporary reference pics and follow them.
Most of the radials I have worked on have had aluminium cylinders/heads/rocker boxes in natural cast finish, usually with bake black enamel baffles and push rod covers. However there are  engines with black painted cylinders, and/or cylinder heads.
As already mentioned it also depends on the country of origin and the manufacturer so it is really a question that is in the 'how long is a piece of string category?'
So, these are Wright R-2600's for a B-25:
This is a P&W R-1830 on a C-47:
And apparently, so is this:
This is a Bristol Mercury:
A Bristol Hercules. All Bristol engines were basically the same,
Chris
Nice pair of Bristols: Note how the barrels are only half painted on the Mercury. This was my first thought when reading the OP.
  • Haha 2
In any case the problem for the modeller is the same, no matter if the finned area of the cylinder was left unpainted or was painted: how to make such areas recognisable, particularly in the smaller scales. And the solutions are the same: wash or drybrushing. The only difference would be in the colour used for the cylinder. Even on an engine with these painted black, I would use a dark grey for the cylinders and then apply a black wash to achieve the needed contrast. Similar with drybrushing, a black base coat followed by grey to highlight the cooling fins
What about a gloss or semi-gloss paint with a flat black wash?
Chris
Chris
You mean having the same colour overall and using a wash of the same colour but matt ? Not sure this would give enough contrast, might be worth a try but I doubt it would replicate the effect
The other aspect is the difference in appearance between a brand new clean engine from an exhibition in museum and the worn one from a heavily exploited machine on a front line at war...
J-W
  • 1 month later...
There's a third option I've used from time to time to highlight raised detail, and I tend to prefer this over dry brushing (but not over a wash): That is, "prime" the whole part in a hard wearing metallic enamel instead of a regular primer. Then spray the whole part with the second colour, black or whatever, using a softer acrylic paint. Then gently sand the raised detail back to the metal finish.
Personally I am happier with the results I get from that than from dry brushing. I feel like I have more control and get a more consistent finish, and it's faster (if I ignore time wasted waiting for it to dry). I haven't tried it on a radial engine but I expect it will give the same access challenges as dry brushing.
EDIT: That would give a purpose prepared look but I'd use a wash if I wanted a used look. Also, I see I've just replied to a thread that is 3 months old! Oops.
Edited by kiseca
