LorenSharp Posted June 24, 2021 Posted June 24, 2021 For my entry I have a 1/48 Sanger Bristol Beaufort. Yes I'm foolish enough to do not only another vac but a Sanger vac to boot. Although I must say this is a whole lot better than the an Oxford I've been struggling through of late on the anything but injection GB. Decently moulded white vac plastic All kinds of neato white metal(that I won't use for the most part) I'll print out or scratch build extra parts I need. I doubt I'll do a full interior, but the cockpit and forward nose do scream out for some added extra bits. I hope I don't damage the clear plastic like I did on the Oxford. I think I'll prep new vac masters just in case. I am waiting on my decals but they will be in long before I finish this up. I'm going to do Mk1A from No.2 Torpedo Training Squadron Unit based at Castle Kennedy Scotland in late 1943. So I hope you'll follow along on my little quest. If you have and comments, suggestions, or questions, shout 'em out. Now to begin..... 9
rob85 Posted June 24, 2021 Posted June 24, 2021 Your mad! Looking forward to you building it though, great choice… for you not me it would be a plane crash for me. Rob 1
LorenSharp Posted June 24, 2021 Author Posted June 24, 2021 Thats a given Rob😜 I just hope I don't crash and burn with it, unlike the Oxford that's giving me screaming fits here right before completion and the end of the GB. Some days its enough to make a grown man weep. The Beaufort may have a slow start,, but we'll see how it evolves and what it evolve into.....cue creepy organ music. 2
Troy Smith Posted June 24, 2021 Posted June 24, 2021 6 hours ago, LorenSharp said: If you have and comments, suggestions, or questions, shout 'em out. Pick up a cheap Tamiya Beaufighter and raid it for bits, IIRC you could basically use the entire wing/engines/UC and some other parts. May make it less of a slog. Shame Sanger have never really upped their game, and still knock out rather poor kits, though this may well be an old Contrail mould in origin. Still, look on the bright side, when you finish, Airfix will announce that due to the success of their 72nd kit they are going to do it in 48th 1
LorenSharp Posted June 24, 2021 Author Posted June 24, 2021 7 minutes ago, Troy Smith said: Pick up a cheap Tamiya Beaufighter and raid it for bits, IIRC you could basically use the entire wing/engines/UC and some other parts. May make it less of a slog. Shame Sanger have never really upped their game, and still knock out rather poor kits, though this may well be an old Contrail mould in origin. Still, look on the bright side, when you finish, Airfix will announce that due to the success of their 72nd kit they are going to do it in 48th The Oxbox is definitely an old Contrail kit. and boy it was old too. The Beaufort, is actually a LOT better IT at least has the ribbing detail on the rudder and whatnot I'll have a better handle on it when I separate the parts from the plastic. A good portion of the white metal I'll probably print out because its easier. 2
tonyot Posted June 26, 2021 Posted June 26, 2021 (edited) I`ve built one of these and was let down by the clear parts,...... the canopy and nose glazing just did not look like the real thing. I also scrapped an old Tamiya Beaufighter and used the tail, wheels, outer wings and undercarriage along with the engines with the cowlings sanded down to replicate the Beauforts. Good luck,.... you`ll need it! Here is my attempt,..... but I`m looking forward to the forthcoming ICM kit for sure; Cheers Tony Edited June 26, 2021 by tonyot 4
LorenSharp Posted June 27, 2021 Author Posted June 27, 2021 I've managed to make a little progress, though not much. Life has a way of mucking up the works at the least opportune time. Having to replace part of roof on house and discovering previous work done not only incorrect but water damage and age far more extensive and naturally expensive as well. Oh Joy, Oh Rapture. So I have managed to get both sheets panel lines re-scribed. @tomprobert used a method on his B-52H build of scribing the panel lines before separating the parts from the plastic. I will have to say the is one of the DOH! moments. why I didn't do this before, but definitely will do from now on because it makes life so much easier. The plastic is completely rigid and doesn't want to move all around. So thank you Tom! And of course while at it, I'm experimenting with applying rivets with a ponce wheel. I've tried it before in small areas but this time I'm doing both the wings and the fuselage. They are hard to see even with using black chalk powder rubbed in to bring out what has been done and what hasn't. Next step will be to begine the separating of the parts from the plastic. 7
tomprobert Posted June 27, 2021 Posted June 27, 2021 Glad to be able to pass on that little Pearl of wisdom - it certainly does make scribing so much easier! Lookin’ good by the way... Tom 1
LorenSharp Posted June 27, 2021 Author Posted June 27, 2021 It's early yet and just getting started. I have plenty of time to mess it up.
JOCKNEY Posted June 28, 2021 Posted June 28, 2021 Deep in the stash I have the Contrail version of this. A couple of times I've been tempted to open it and look at the contents only to chicken out, and reach for a large single malt to calm my nerves. Really looking forward to following this one, best of luck. Cheers Pat 1
LorenSharp Posted June 28, 2021 Author Posted June 28, 2021 Thanks Pat. So far, though I may jinx myself ,its coming along a whole lot better than anticipated. I've finished all the re-scribing ,riveting. and separating from the plastic sheeting. Opened up all the ports and have got a fair handle on what is going to be built from card stock and what's probably going to be printed. Now its just a matter of getting down to the gritty nitty. In between sweating like a politician on election day with the minor heatwave going on at present. 33c feeling like 39c with the humidity at 55% and dew point 23c. You don't walk outside. You swim. But I'll take that over shoveling snow any day of the week. 2
Rabbit Leader Posted June 29, 2021 Posted June 29, 2021 Well well well, what have we here? You know that as soon as you finish it the ICM kit will hit the shelves. Then again, how rewarding will it be when you get this finished and can show it off to all of us! We wish you the best of luck and looks like you’ve made a cracking start so far. Cheers.. Dave 1
LorenSharp Posted June 29, 2021 Author Posted June 29, 2021 Thanks Dave, I'll have a progress report for everyone soon. Interior and bomb bay work has commenced. 1
JOCKNEY Posted July 13, 2021 Posted July 13, 2021 Right come on, we've all been waiting patiently for 2 weeks to see what's happening. Have you finished it ? cheers Pat 1 1
LorenSharp Posted July 13, 2021 Author Posted July 13, 2021 1 hour ago, JOCKNEY said: Right come on, we've all been waiting patiently for 2 weeks to see what's happening. Have you finished it ? cheers Pat Patience,my young Scottish Padewan, Patience. All will be revealed in due course. The last 2 weeks have been consumed with finishing up one GB,(Barely) and equipment breakdowns from heat and awaiting replacements this week in the constantly delayed Post. Have no fear, Smith is here and I'll have an update very soon. 2
LorenSharp Posted July 19, 2021 Author Posted July 19, 2021 As @JOCKNEY had eloquently pointed out it has been a bit since my last update. Having fro the most part gotten all the riveting done I tried an idea mentioned by @billn53 ,who in turn got it from @Rob K.,namely using clear uv resin to make odd shaped windows. Using clear packing tape to cover the outside port hole.,I used an eyedropper to put just enough resin to fill the area. it took a few tries as the resin had a tendency to leak out before I could use a UV light to cure it. Not perfect but it's definitely better than punching out clear disks and trying to attach them to the fuselage without getting excess glue or worse, finger prints on the plastic from the glue. Although upon reflection I probably should have done this AFTER I had painted the interior, Oh well.. Moving on., I made bulkheads and flooring. added framing in the cockpit area and Nav/Bombardier station in the nose. I'm not going to trick out the radio compartment as it won't really be seen except though gangway from the cockpit, and then just barely. then worked on the Bombay modifying it for torpedo use. I'll get these painted up and by then I'll have the seats, instrument panel and other bits printed up then I can finally seal up the fuselage and get it squared away so the wings can bet worked on and added. So with luck the next update won't be too long. So until next time Be safe, Stay healthy ,and model on. 9
billn53 Posted July 19, 2021 Posted July 19, 2021 That UV resin trick for making small windows is getting around… 1
AdrianMF Posted July 20, 2021 Posted July 20, 2021 Another vac! I’m hoping you will add a couple of wing spars stuck to the floor and sticking out of the sides before you close up. Looking forward to this one. Regards, Adrian
Rob K. Posted July 20, 2021 Posted July 20, 2021 11 hours ago, billn53 said: That UV resin trick for making small windows is getting around… Good to see, I had another go after a bad fitting small top nose window on my b-17. Used the packing tape, but couldn’t get the adhesive off with the goo remover. Than had another go and this time using the glossy non adhesive side to hold the glue in place (small patch held by Tamiya tape). Result: Clear as day up to the point where it is difficult to see if there is a window at all from some angles👍 1
Rob K. Posted July 20, 2021 Posted July 20, 2021 12 hours ago, billn53 said: That UV resin trick for making small windows is getting around… Good to see, I had another go after a bad fitting small top nose window on my b-17. Used the packing tape, but couldn’t get the adhesive of with the goo remover. Than had another go and this time using the glossy non adhesive side to hold the glue in place (small patch held by Tamiya tape). Result: Clear as day up to the point where it is difficult to see if there is a window at all from some angles👍 Amazing work on the Beaufort by the way. Will follow this. 1
LorenSharp Posted July 20, 2021 Author Posted July 20, 2021 3 hours ago, AdrianMF said: Another vac! I’m hoping you will add a couple of wing spars stuck to the floor and sticking out of the sides before you close up. Looking forward to this one. Regards, Adrian That's kinda what I had in mind. Because of the bombbay being open a spar all the way through wouldnt work. So I'm making a set of spar "slats" that will be epoxied in holes on either side where the wing attaches rather than use CA for strength. 1 hour ago, Rob K. said: Good to see, I had another go after a bad fitting small top nose window on my b-17. Used the packing tape, but couldn’t get the adhesive of with the goo remover. Than had another go and this time using the glossy non adhesive side to hold the glue in place (small patch held by Tamiya tape). Result: Clear as day up to the point where it is difficult to see if there is a window at all from some angles👍 Amazing work on the Beaufort by the way. Will follow this. Thanks Rob, I had the same problem on my first try. Couldn't get the stick surface off no matter what I used. Took a small piece of tape and placed the smooth side down and held it in place with another piece of tape. The one thing to watch out for is making sure there is a tight seal with the tape. Otherwise the resin will ooze out before it can be cured. One glass still managed to fog over slightly, but the others perfectly clear. Not sure why, but acceptable for the present. 2
rob85 Posted July 20, 2021 Posted July 20, 2021 This is looking good, the ribbing on the internals definitely puts my wonky work to shame on my B17. Really bringing this flat plastic to life. Rob
LorenSharp Posted July 20, 2021 Author Posted July 20, 2021 Your B-17 interior is far from wonky Rob. I've built the Revell/Monogram B-17 in multiple variations over the years. If aany thing your build has given me enough ideas I'm seriously considering taking my "G" version I did many years back and doing a full restoration on it and bringing it up to snuff.
LorenSharp Posted August 17, 2021 Author Posted August 17, 2021 Moving along now that I have a Shelf of Doom project finished, The ribbing to the Starboard side of the beaufort is done along with some gauges and leavers. From there completing the finishing touches to the cockpit and Navigators station. I added thin rod for the leavers. The instrument pane, pilots seat cockpit tub I had previously printed out. Simple thread for panel wiring. Gave everything a light wash to bring out details. MAde the seat belts out of tamiya masking tape with hardware from my spares box 3
LorenSharp Posted August 17, 2021 Author Posted August 17, 2021 Carefully cemented both sides together I had an accident earlier in the build when I cut out for the windows on the starboard side. At the time I though that it might be a mistake as the plastic was held on with VERY thin and narrow pieces that if not careful would break. Well Yep, it broke off and part of the frame when "Gone with the Wind". I'll have to study Not only re-attach securely, but making sure it matches the interior framing.. In the mean time, I've filled the seam top and bottom Once I get these sanded down I' finish adding the rudder and Horizontal Stabilizers. Something else I've got to check references on the nose glass. the very end is flattened rather than pointed. It may be necessary to make a copy with MIlliput and correct the shape so I can Vac a new nose. The rear turret looks like it make have to be redone as well, but we'll see. BUt so far it's coming together better than some vacs I've done recently. 3
