SpasmoTrout Posted July 16, 2016 Posted July 16, 2016 (edited) Airfix 1/72 BE2c and Skunkworks 1/72 MQ-9 Reaper, both in 39 Squadron RAF markings. The BE2c is as flown by William Leefe Robinson VC in 1916 when 39 RFC were a home defence squadron, and the MQ-9 is as flown by 39 Squadron currently, also from the UK, but with a very different mandate. The Reaper is surprisingly massive. The MQ-9 isn't my best work - the lack of interior means it really goes together quickly. A little too quickly in fact and it's a bit of a mess. Luckily, there are two kits in the box, so I'll crack on with the other at some point. The BE2c is a very complicated kit for it's size IMO. My first attempt at rigging a biplane and second attempt at a WW1 aircraft. I'd give it another go though. The rigging is Uschi van der Rosten Rig That Thing Superfine, and is held on with superglue and swear words. Both brush painted with a combination of Tamiya, Gunze and Humbrol colours. Thanks for looking. Spasmo. Edited July 16, 2016 by SpasmoTrout 27
Seahawk Posted July 16, 2016 Posted July 16, 2016 The BE2c is a very complicated kit for it's size IMO. My first attempt at rigging a biplane and second attempt at a WW1 aircraft. I'd give it another go though. I think you should: that rigging looks truly excellent.
azureglo Posted July 16, 2016 Posted July 16, 2016 Nice work, especially rigging the Be2C, biplanes fill many of us with fear and loathing. The idea of the 100 years is very simple but makes a great point: if you haven't seen it already try and watch Andrew Niccol's " Good Kill" about a Reaper "pilot" at work. Flying and warfare certainly has moved on from the heady days of chaps in dope & linen contraptions, relying as much on faith as their engines. A 1
DennisTheBear Posted July 16, 2016 Posted July 16, 2016 Oh, like them! I've had a vague concept of something similar for an RAAF squadron but just haven't got around to turning it into an actual idea yet. Nicely done with the rigging, too. Dennis
SpasmoTrout Posted July 17, 2016 Author Posted July 17, 2016 I have to confess to 'cheating' with the rigging... I glued it to the tops and bottoms of the struts before I attached the wings. Seemed to work pretty well, although you can just make out one of the lines on the port wing has gone a bit slack. Also, my advice to anyone else making on would be to attach the control wires to the elevators as the very last thing - if you do it too early it's almost impossible to move the thing around! Hats off to biplane modellers - I have a new respect for them, and I can see the attraction as well now!
rholland Posted July 18, 2016 Posted July 18, 2016 Two excellent models, well done. My uncle flew Marylands with 39 Sqn, how about a Maryland in between those two? Richard in NZ 2
Brandy Posted July 21, 2016 Posted July 21, 2016 Nicely done! Certainly an impressive first attempt at rigging...it gets easier with practice (doesn't everything?)! Ian
GrimReaper09 Posted September 25, 2019 Posted September 25, 2019 I've got both these kits along with a Canberra PR9, a Meteor NF13 and a Martin Marauder to get through in my quest to build every airframe 39 Sqn has flown. I hope mine come out even half as good as those! not sure my skills will be up to rigging sadly!
warhawk Posted September 25, 2019 Posted September 25, 2019 The rigging looks nice and tidy. Good job on it!
Meatbox8 Posted September 26, 2019 Posted September 26, 2019 Both look great. What a contrast. Comparing the two shows how big the Reaper is (I do wish the RAF would give it better name though). Would be intersting to see a Canberra PR.9 amongst them. I have the BE in my stash. Hope it turns out as good as yours.
