Shelliecool Posted December 1, 2019 Author Posted December 1, 2019 With all the preshading complete, the time came to add some colour. I masked up the camo sections and started to mix up some Vallejo white acrylic. Along with red, white is one of my least favourite colours to airbrush! However, I mixed up a ratio of 5:1 and began spraying a light coat. All went well, and it sprayed evenly and settled down. Untill I reached the underside of the tail plane, and there the paint left several marks (I'm guessing there is something on the plastic). I will let it dry and try not to panic about it, hopefully I will be able to spray over it.......that or sand it down! 9
dogsbody Posted December 2, 2019 Posted December 2, 2019 Just daub some red on it later, to look like repairs to the fabric. Chris 3
Greg Law Posted December 2, 2019 Posted December 2, 2019 I wouldn't be too worried about those spots. It will just look like weathering when you are finished. 2 1
Shelliecool Posted December 29, 2019 Author Posted December 29, 2019 Back at the build after a long christmas break, and lucky to have received a couple of kits under my tree (most notably.....if in size more than anything an Airfix Victor!). Before my break I airbrushed another coat of white, which covered the marks on the tail. This I then sealed in, and masked up the top of the aircraft ready for some Vallejo Dark Earth. Today I set up the airbrush, mixed some Dark Earth and began spraying the build. I'm really happy with the way the paint has settled and the light grey preshading underneath. A happy restart to the build. 9
Shelliecool Posted January 4, 2020 Author Posted January 4, 2020 Since my last post I have given the Wellington another light coat of Dark Earth, this again settled well and I left it to dry before adding highlights. Then I mixed a little white into the Dark Earth, and carefully airbrushed some highlights onto the panels. I have done this sparingly, and was careful to make sure they are not too much lighter. Next I plan to unmask and then seal it in before starting the Dark Green. 8
Shelliecool Posted January 10, 2020 Author Posted January 10, 2020 Once the varnish was dry I masked up the Dark Earth sections, and set to work with the Dark Green. This airbrushed evenly and has settled well, I am now 2 light coats down and pretty happy with it. Next I plan to airbrush some highlights on the green and seal it in with Quick shine varnish. 9
Hamden Posted January 10, 2020 Posted January 10, 2020 Looking good can't wait to see the reveal when the masking comes off! Roger 1 1
Shelliecool Posted January 10, 2020 Author Posted January 10, 2020 1 hour ago, Hamden said: Looking good can't wait to see the reveal when the masking comes off! Roger Fingers crossed it hasn't bled 🤞🤞🤞 1
Col. Posted January 11, 2020 Posted January 11, 2020 Nice painwork so far Shellie. Hope that Yak-38 lurking on the sideline is going to get resurrected sometime as well. 1
Shelliecool Posted January 12, 2020 Author Posted January 12, 2020 12 hours ago, Col. said: Nice painwork so far Shellie. Hope that Yak-38 lurking on the sideline is going to get resurrected sometime as well. Thank you, the Yak is my paint tester. I spray that and half a Chinook to test my mix. Thanks, Michelle 1 1
bigbadbadge Posted January 12, 2020 Posted January 12, 2020 This is looking very nice indeed. Lovely paint and effects too. I have this kit in the stash and am grateful for the heads up on the issues, I also have the Revell (ex MPM) mk II on the go at the moment. All the best Chris 1
Col. Posted January 12, 2020 Posted January 12, 2020 (edited) 43 minutes ago, Shelliecool said: Thank you, the Yak is my paint tester. I spray that and half a Chinook to test my mix. Thanks, Michelle Aww, poor neglected Yak Will just have to build my own one some time instead. Is there a story behind the the two paint mules? Edited January 12, 2020 by Col. 1
Shelliecool Posted January 12, 2020 Author Posted January 12, 2020 7 hours ago, Col. said: Aww, poor neglected Yak Will just have to build my own one some time instead. Is there a story behind the the two paint mules? The Chinook kit was given toe with most parts missing, so instead of putting it in a cupboard I decided to use it for airbrushing practice. The Yak was used to practice the hairspray technique. I spray them a little every time I airbrush, so really they are quite loved😁. 1 1
Shelliecool Posted January 12, 2020 Author Posted January 12, 2020 Last night I mixed a little white into the Dark Green and airbrushed some highlights (the lighting makes it look more obvious than it actually is). I have left this to dry and will unmask it and seal it in later. 8
Shelliecool Posted January 18, 2020 Author Posted January 18, 2020 With the paint dry, time came to unmask the aircraft. I was relieved to find the paint hadn't bled under the tape and am rather happy with the look of the build so far. I then sealed in the paintwork with a coat of Quick shine varnish. On to the undercarriage and props. 8
bigbadbadge Posted January 19, 2020 Posted January 19, 2020 Oh wow, looking stunning, great paint work. 1
Shelliecool Posted February 8, 2020 Author Posted February 8, 2020 Since my last post I have been working on the undercarriage. This I imagined would be pretty straightforward, however, it doesn't fit very well (or at all into the wheel bays!). With a lot of fiddling around, trying to hold the main strut in place, while making the brace fit (which it doesn't!), I finally got them in place. Once the glue had set I removed them for painting, airbrushing them Vallejo silver. I then constructed the wheels and airbrushed the hubs silver. Getting there slowly. 5
Shelliecool Posted February 19, 2020 Author Posted February 19, 2020 Since my last post i have spent time airbrushing the tyres on all 3 wheels. The paint settled well but the seam line is still visible😒. Because of this I will sand them down again and repeat the process, hopefully to better effect. I have also airbrush the landing gear doors, inside dark sea grey and outside white.... Thankfully this was pretty straight forward. 5
Shelliecool Posted February 23, 2020 Author Posted February 23, 2020 I have been working away on the seams that were visible on the wheels. This took a lot of sanding, and some filler, and yet more sanding🙄. Finally, I was ready to reapply some colour, and thankfully it has worked! Next I plan to add some weathering and build the undercarriage. 7
Shelliecool Posted March 1, 2020 Author Posted March 1, 2020 Since my last post I have carefully applied the decals to the build. There are very few of these, they are however nice quality. I bedded them in with some micro sol, and left them to dry. Once they are dry I will seal them in and add a dirt wash. 9
Back in the Saddle Posted March 1, 2020 Posted March 1, 2020 That looks rather good! I'm tempted to add a Wellington to my stash (which is not nearly big enough yet...!) and am torn between this kit and the new tool Airfix offering. I think Airfix will win, but I do like this one too. 1
dogsbody Posted March 1, 2020 Posted March 1, 2020 2 hours ago, Back in the Saddle said: That looks rather good! I'm tempted to add a Wellington to my stash (which is not nearly big enough yet...!) and am torn between this kit and the new tool Airfix offering. I think Airfix will win, but I do like this one too. That is the new tool Airfix kit. It's the second release with new nose parts. Chris 1
