Colin W Posted May 21, 2012 Share Posted May 21, 2012 Hi I have to spray a 1/48 Hercules in Light Aircraft Grey so to get a good finish I reckon a spray bomb is the way to go. Does anyone have a recommendation for which Halfords grey is closest to RAF light Aircraft Grey? Many thanks Colin Link to comment Share on other sites More sharing options...
cuprar Posted May 21, 2012 Share Posted May 21, 2012 Their grey primer is quiet light Link to comment Share on other sites More sharing options...
Flankerman Posted May 21, 2012 Share Posted May 21, 2012 I used Halfords Ford Polar Grey on my An-22...... ... and Il-76.... Halfords Grey Plastic Primer is darker - as used on my Beriev Be-10 ...... ... and Il-38.... Ken Link to comment Share on other sites More sharing options...
Iain Ogilvie Posted May 21, 2012 Share Posted May 21, 2012 Just to add - I've found their grey primer can vary quite a bit in colour... Iain Link to comment Share on other sites More sharing options...
canberra kid Posted May 22, 2012 Share Posted May 22, 2012 I've had a look through all the colour books 1,000's of paints and I've not found a match for LAG, there is a chance I could have missed it if it was there as I was going bog eyed my the time I got to the end. I thought Ford dove grey may be OK but it's a quite a brown cast to it. Ford Polar Grey is more like Medium sea grey and the primer tends to be more like dark sea/ ocean grey. I wish there was a good match but as yet no car/van manufacturer dose a vehicle in Light Aircraft grey John Link to comment Share on other sites More sharing options...
pigsty Posted May 22, 2012 Share Posted May 22, 2012 I wish there was a good match but as yet no car/van manufacturer dose a vehicle in Light Aircraft grey What about Herbie? Would an old VW grey be close enough? Link to comment Share on other sites More sharing options...
Selwyn Posted May 22, 2012 Share Posted May 22, 2012 Their grey primer is quiet light The grey primer is a actually a great match for Medium sea grey! Selwyn Link to comment Share on other sites More sharing options...
Scimitar F1 Posted May 22, 2012 Share Posted May 22, 2012 I think they do a match service that you can try as well as doing BS colours. Try taking in a bit of plasticard painted with your favourite enamel. Will Link to comment Share on other sites More sharing options...
viscount806x Posted May 22, 2012 Share Posted May 22, 2012 HiI have to spray a 1/48 Hercules in Light Aircraft Grey so to get a good finish I reckon a spray bomb is the way to go. Does anyone have a recommendation for which Halfords grey is closest to RAF light Aircraft Grey? Many thanks Colin Have a look at Halfords rattle can 'Racking Grey' which is usually shelved to one side of the actual car colour paints. I've used this for Viscount props recently and it is a nice light gloss grey but not sure how close to LAG, depends what you are comparing it to really. Some of the modelling paints can be a bit off the actual clour. Link to comment Share on other sites More sharing options...
canberra kid Posted May 23, 2012 Share Posted May 23, 2012 Have a look at Halfords rattle can 'Racking Grey' which is usually shelved to one side of the actual car colour paints. I've used this for Viscount props recently and it is a nice light gloss grey but not sure how close to LAG, depends what you are comparing it to really. Some of the modelling paints can be a bit off the actual clour. Thanks for the heads up on that, I've not seen that one I'll take a look today. John Link to comment Share on other sites More sharing options...
The wooksta V2.0 Posted May 23, 2012 Share Posted May 23, 2012 The grey primer is a actually a great match for Medium sea grey!Selwyn It was up until about 6 years ago, now it's closer to Ocean Grey but not quite blue enough! The number of models I've sprayed and then resprayed again because I've not noticed a thin coat because of the primer is quite high! I was told some years back by Geoff B that Halfords will mix the colour if you give them the FS number. Don't know if they still do that and it's apparently twice the price of a standard can. I'm still miffed that they discontinued Fiat Azure Blue, because it was an almost bang on match for Extra Dark Sea Grey! Few that I found over the years in the Halfords range: Rover Sand Glow = RAF Mid Stone Fiat Broom Yellow = RAF Trainer Yellow Gloss Aluminium = ideal for 72nd RAF types in silver Link to comment Share on other sites More sharing options...
Colin W Posted May 23, 2012 Author Share Posted May 23, 2012 Cheers Guys My Local Halfords doesn't have the racking grey or VW so I've got a can of Ford Polar grey and will give that a shot. Thanks Wooksta for sharing your previous experience. Colin Link to comment Share on other sites More sharing options...
Flankerman Posted May 23, 2012 Share Posted May 23, 2012 I just called into my local Halfords to pick up a can of 'Racking Grey' - but it is their enamels range (blue cans), not acrylic. Ken Link to comment Share on other sites More sharing options...
canberra kid Posted May 23, 2012 Share Posted May 23, 2012 I just called into my local Halfords to pick up a can of 'Racking Grey' - but it is their enamels range (blue cans), not acrylic.Ken Me too, I've just given it a try out and although it's not a BS match as it's slightly lighter than LAG it's a good light grey and as far as I'm concerned it'll do for me, as they say "it close enough for government work" it dose say Enamels but it drys very quickly with a very nice gloss finish. I also see they now do "Camouflage colours" they look close to, Dark Green, Dark Earth, Black and a much darker brown. these are described as ultra mat but the colours look good. the price is £7.99 but if it's a colour you use a lot its good value. John Link to comment Share on other sites More sharing options...
bentwaters81tfw Posted May 23, 2012 Share Posted May 23, 2012 I bought some Polar Grey intending to use it for Barley/Camoflage Grey. Is it close enough do you think? Link to comment Share on other sites More sharing options...
lancfan Posted May 23, 2012 Share Posted May 23, 2012 It was up until about 6 years ago, now it's closer to Ocean Grey but not quite blue enough! The number of models I've sprayed and then resprayed again because I've not noticed a thin coat because of the primer is quite high!I was told some years back by Geoff B that Halfords will mix the colour if you give them the FS number. Don't know if they still do that and it's apparently twice the price of a standard can. I'm still miffed that they discontinued Fiat Azure Blue, because it was an almost bang on match for Extra Dark Sea Grey! Few that I found over the years in the Halfords range: Rover Sand Glow = RAF Mid Stone Fiat Broom Yellow = RAF Trainer Yellow Gloss Aluminium = ideal for 72nd RAF types in silver If you can get the Fiat paint code for that Azure blue shade Halfords can pull the mixing instructions from their terminal and mix it for you. -and BL Beaver was a good match for Dark Earth as I remember. David. Link to comment Share on other sites More sharing options...
viscount806x Posted May 23, 2012 Share Posted May 23, 2012 Thanks for the heads up on that, I've not seen that one I'll take a look today.John It's in a smaller can with a blue body and quite a bit cheaper than the car colours. Looking at the actual colour, it is extremely close to Xtracrylic LAG but again, is that correct? Link to comment Share on other sites More sharing options...
