18 hours ago, mark.au said:
A little delicate seam work on that nose ahead I think.  Nice job on the fettling though, paint on the weekend?
Thanks Mark,
I'm going to need to be very careful with the nose seam,
If the night shift goes OK I might try and get some paint done.
Not promising anything. :whistle:
I got woken early this morning and did a little sanding.
There's still work to do as I can feel a few less than smooth transitions.
I've also popped the canopy as the windscreen part needs repositioned.
Alistair
  • Like 10
Nice progress, Alistair, definitely Meteor-shaped now :) Looking forward to paint!
Mark
PS mine arrived today :whistle: I'm going to save it for the Recce GB
Mark
Thanks Mark,
In regard to the kit I think that if you are careful with the placement of the wheel well parts and shave a bit off the port side of the cockpit it will all go together with less bother than I've had.
One thing i missed mentioning there are raised ejection pin marks at the wing root end of the lower wing parts that need shaved back to get a fit on the leading edges.
Hope that helps,
Alistair
  • Thanks 3
4 minutes ago, AliGauld said:
Thanks Mark,
Hope that helps,
Alistair
Thanks, Alistair, that's brilliant info - I just need to make a note of that or I'll forget it long before I get to build mine! :D
Mark
Ooooooo getting woken up early on nights was never good, always felt it at around 0400 hrs !!!
Looking good Alistair , getting there with the fettling.
Chris
Page 4 already? Well, I have to say the cockpit looks terrific and this is shaping up nicely.  I think I'm getting intrigued by this kit... 🤔
Chris
Thanks Chris,
Some more sanding today which showed up a couple of pinholes that need sorting.
Getting there.
Thanks very much,
It's a lovely kit that needs a bit of care and attention but still a fun build.
Alistair
A light sanding this morning to get the pinholes sorted and then ot for a lick of paint.
Still a little work to do here.
And here.
I'm happy with the rest though.
Thanks for looking,
Alistair
Coat of primer is looking good, Alistair, this is really coming together beautifully! Great progress.
All the best,
Mark
All the best,
Mark
Thanks Mark,
Next up after fixing those dissolved putty lumps trying to get the nose on and the seam cleaned up without wrecking all the detail.
Alistair
Just now, AliGauld said:
Thanks Mark,
Alistair
You'll ace it, my friend! Looks like there are a few things to watch out for in this kit.....
Mark
Mark
Thanks Mark,
I appreciate your confidence.
There are a few things you need to be careful with but it's going OK so far.
Alistair
6 minutes ago, bigbadbadge said:
Scrubbing up very well Alistair,  looking good.
Looking forward to seeing  the paint going on.
Chris
Thanks Chris,
Still a little work to do but paint is certainly closer.
Alistair
Clear bits masked and then the two halves of the nose cone glued together.
I've fitted the bulkhead and nose wheel parts into the fuselage as that seemed to be more logical.
I'll deal with the seams tomorrow when all that stuff is dry.
On a dry fit the nose cone is a pretty good fit. :penguin:
Thanks for looking,
Alistair
The cone seams were dealt with :fingerscrossed: and the nose cone glued on.
All the previous work appears to have helped as there will only be a smear of PPP needed to clean the join up.
I'll star on that once the glue has properly cured.
Then it will be time for some recribing.
Thanks for looking,
Alistair
The Meteor looks great with its schnozz in place, Alistair :) the further along you get, the more eager I am to have a bash at mine!
Mark
I haven't looked in for a few days and it's really come along well!  The problem areas you highlighted didn't look too bad, and it seems that you've fixed them up (just looking at the pictures, I'm not sure you actually mentioned it).  It's a bummer having to glue the nose cones halves together, but I guess it was unavoidable for Airfix since you have to put the clear parts in.
Looks great so far!
Looks great so far!
Thanks vey much,
I think I've got the small issues fixed.
The nose cone in two parts is a little more difficult but as you say i don't think Airfix had any option as the clear pieces are set back slightly from the outside surface and couldn't easily have been fitted from the outside.
Mark
Thanks Mark,
It's a fun build and not too taxing if you take care with the early placements.
Guess who didn't and it has given me a little extra work. :blush:
Alistair
1 minute ago, Samuraiwarrior said:
Hi Alistair,
Coming along very nicely. Looking forward to the colour being applied, which will really bring it to life.
Kevin
Thanks so much,
I was hoping to get some colour on this weekend but stuff and things.
I'm looking forward to getting some PRU Blue on the underside at least.
Alistair
Alas, I'm a past master at not reading the instructions.....
32 minutes ago, bigbadbadge said:
Looking great Alistair,  I like the front wheel leg assembly and with the nose on it is looking splendid.
Chris
Thanks Chris,
I'll need to be careful from now on as the delicate bottom leg sticks out below the fuselage.
The instructions call for the nose leg to be fitted to it when you build the assembly but I've left it off as i know I'd break it clean off at some point in time.
A man after my own heart.
Who needs instructions anyway.
Alistair
Alistair,
Shaping up very nicely! Looking forward to this faded paint job,
Roger
