Peter Marshall Posted May 25, 2018 Posted May 25, 2018 Finally got around to starting. Nice Hurricane to celebrate the 100 years of the RAF Work starts with the cockpit just for a change. This feels like a limited run kit, but the fit isn't terrible mix of PE, Resin and Plastic Then on with the resin seat and belts Peter 2
Peter Marshall Posted May 26, 2018 Author Posted May 26, 2018 Today's work, finishing off the cockpit and closing up the fuselage Peter 3
Peter Marshall Posted May 28, 2018 Author Posted May 28, 2018 Last couple of days work mainly filling the wings. The fit is pretty agricultural, but I can see why the did it, to allow easily for different wings. The Resin wheel wells and light mounts both needed a lot of sanding to fit. Then added the radiator and the volkes filter - again needed some filling. Typical limited run kit. Peter 6
Robert Stuart Posted May 29, 2018 Posted May 29, 2018 This is looking good Peter, and you are building fast (faster than I can)
monsjmse Posted May 31, 2018 Posted May 31, 2018 Nice work on the Hurricane. I love the pile o' modelling stuff in the background. I have some of the Hobbyzone drawers too, but my desk is still a mess - I just can't help it.
Peter Marshall Posted June 2, 2018 Author Posted June 2, 2018 Today's work - first finished off the wings, by adding the landing lights, navigation lights and cannons Then as a bit of a change from all the filling / sanding I decided to make up the prop and weathering it down Peter 7
monsjmse Posted June 2, 2018 Posted June 2, 2018 I love the weathering on the prop blades Peter . Was that done with chipping fluid, or did you scratch the top layer off with a tooth pick?
Troy Smith Posted June 2, 2018 Posted June 2, 2018 Hi Peter Impressive work, but the blades are a compressed wood composite, Jablo, and prop blades just don't weather like that either. https://en.m.wikipedia.org/wiki/Hawker_Hurricane_variants#/media/File%3APilot_6_Sqn_RAF_with_Hurricane_IID_at_Shandur_c1942.jpg They have brass sheathing on the leading edge. There is a great colour shot of a Spitfire XIV showing brass showing. The yellow tips are 4 inch, can't remember what that is in 1/32nd. Here's a second line desert finish Hurricane, which may help with how they weather HTH T 3
Peter Marshall Posted June 5, 2018 Author Posted June 5, 2018 Cheers Troy - i'll sort it at the weekend, but I had some fun doing it that way (which is sort of the point) On 6/2/2018 at 8:34 PM, monsjmse said: I love the weathering on the prop blades Peter . Was that done with chipping fluid, or did you scratch the top layer off with a tooth pick? Even though it's wrong , Alclad Aluminium base, AK Worn Effects fluid, then the tamiya black / yellow. Attack with wet stiff brush, then some pigments and oils over the top to tone it down.
Kallisti Posted June 5, 2018 Posted June 5, 2018 For a limited run kit this isn't bad. I built it for my 'Clang!' diorama last year and I've got the IID kit ready for another build at some point 4
Peter Marshall Posted June 9, 2018 Author Posted June 9, 2018 Right today's work - first started by re-doing the prop Then fitted the windscreen and gunsight Masked up the wheel wells with blutak Then on with a coat of black primer Peter 5
Peter Marshall Posted June 10, 2018 Author Posted June 10, 2018 Today - Paint ! . Combination of Hataka Laquers for the main colours and Lifecolor for the Italian Cammo Peter 9
Peter Marshall Posted June 16, 2018 Author Posted June 16, 2018 Today's work - put the decals on, then another clear coat over the top Peter 5
Peter Marshall Posted June 23, 2018 Author Posted June 23, 2018 Today's work - a lot of oil weathering, and adding the wheels. You may notice that the exhausts are missing - that's because I lost one, so the other is in some RTV so I could copy it. Of course when I was tidying up at the end of the session i found it, typical. Peter 8
stevej60 Posted June 23, 2018 Posted June 23, 2018 It's looking superb Peter,some first class modelling on view here!
spitfire Posted June 24, 2018 Posted June 24, 2018 This is looking great, but must resist, 2018 is the year of Japanese subjects so the Fly Hurricanes will remain in the stash. Nice job Cheers Dennis
Corsairfoxfouruncle Posted June 26, 2018 Posted June 26, 2018 Mice Hurricane ... I have a set of decals for one of these in 1/48th. Now if i can find a hurricane ?
