Rich F Posted April 1, 2008 Share Posted April 1, 2008 (edited) I've decided to pull this one off the shelf and blow the dust off it. Its a Resin Protojets 1/72 Lightning T.4 which i picked up on ebay last year. Quite a nice kit actually even if the surface detail is a bit heavy in places. I did'nt really like the T.4's rounded tail so I'm going to convert it to a T.5, I've pinched the tail from a old Airfix F.3 kit which looks about right . The only other thing to do for the conversion is to extend the cable ducting thats runs along the sides of the lower fuselage. Shes definetly going to be a LTF bird just not sure which one yet Right, best get my razor saw & CA out... Cheers Rich Edited October 19, 2010 by Rich F Link to comment Share on other sites More sharing options...
Gary West Posted April 1, 2008 Share Posted April 1, 2008 That looks a fine little kit Rich - either scheme, she'll look good I'm sure. Have fun! Link to comment Share on other sites More sharing options...
dswoofie Posted April 1, 2008 Share Posted April 1, 2008 Looks like quite a nice kit. If it was me, I'd pick the grey/green one from those 2 that you've got there... Look forward to seeing this one take shape. Good luck on the first resin kit, not been brave enough myself yet! Karl. Link to comment Share on other sites More sharing options...
Rich F Posted April 10, 2008 Author Share Posted April 10, 2008 Just a quick update, not much progress really, works been a bit manic lately. Anyway after having a good look at the fuselage i decided that the panel lines looked a bit, well crap, sorta like trenches (Matchbox springs to mind), so I've filled em with Mr Surfacer 500 and Mr Disolved Putty. This will then be sanded flat and rescribed. I'll also add a few access hatches to make it look more like the real thing. I left the wings alone as they didn't look to bad, here I've added some hatches, filler caps etc. The tail that i nicked from a Airfix F.3 has been rescribed & rivetted, the plastic was really soft so had to go carefully with this. Right off to sand the fuselage back to the Resin, deep joy. Cheers Rich Link to comment Share on other sites More sharing options...
Rich F Posted June 20, 2008 Author Share Posted June 20, 2008 After a long break from modelling (must be over a month now! ) i've finally got some motivation to move on with this baby again. I've got the the 2 fuselage halves together, filled, rescribed and sanded, a few air scoops added. Because this kit was a T.4 and mines a T.5 I have had to add the cable ducting running along the lower fuselage, this was done with a bit of plastic rod sanded to a semi-circle. Obviously the tail has also been replaced aswell. I then moved onto the cockpit and detailed the behind the seats, not too acurate as you probably wont be able to see that much anyway. I've got the ejector seats painted and weathered, this is one my favourite bits and always seems to get going with the rest of the kit Finally did a bit of detailing in the undercarriage bays, these were totally devoid of any detail so i added some mesh and a few bits of styrene to liven it up a bit. Hopefully i can get this finished soon... Anybody got any tips on attaching vac-formed canopies to resin? Cheers Rich Link to comment Share on other sites More sharing options...
Dads203 Posted June 20, 2008 Share Posted June 20, 2008 Nice Job Rich. looking good in the office Dan Link to comment Share on other sites More sharing options...
Gary West Posted June 21, 2008 Share Posted June 21, 2008 Like your work Rich Link to comment Share on other sites More sharing options...
F-32 Posted June 21, 2008 Share Posted June 21, 2008 Sweet build so far, looking forward to another update. Link to comment Share on other sites More sharing options...
Azgaron Posted June 22, 2008 Share Posted June 22, 2008 Looking great so far, Rich! Nice looking seats! Cheers, Azgaron Link to comment Share on other sites More sharing options...
Mike Posted June 22, 2008 Share Posted June 22, 2008 Anybody got any tips on attaching vac-formed canopies to resin? Yeah - Gator Glue, or G-S Hypo Cement - it's a watchmaker's glue, and dries clear, but doesn't attack plastic or resin. It's also removable with a little bit of scratching at it, so mistakes can be corrected. I think Ali @ AtoZee sells the Gator Glue. Not yet tried mine for attaching canopies Link to comment Share on other sites More sharing options...
Rich F Posted June 22, 2008 Author Share Posted June 22, 2008 Yeah - Gator Glue, or G-S Hypo Cement - it's a watchmaker's glue, and dries clear, but doesn't attack plastic or resin. It's also removable with a little bit of scratching at it, so mistakes can be corrected.I think Ali @ AtoZee sells the Gator Glue. Not yet tried mine for attaching canopies Thanks Mike, I'll give it a try! Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted June 22, 2008 Share Posted June 22, 2008 Nice Rich, never seen a resin kit, love the seats. Link to comment Share on other sites More sharing options...
Rich F Posted August 10, 2010 Author Share Posted August 10, 2010 (edited) I thought I'd revisit this one after finishing my F-4G for the Gulf war GB and before starting the Bucc GB. I've got the undercarriage complete all bar the main wheels, as these need some help from the Flightpath P.E set which I'll add once the tyres are painted. Next up was the construction of the boarding ladder, this was a little difficult to say the least, all in all 37 separate parts to this baby, it took me about 8 hours and a lot of effing and blinding! I had to stray from the suggested build process, for my sanity if nothing else. Still, top marks to David Parkins for a great little P.E set. I've got as far as adding the forward canopy, I used aeroclubs vacform rendition as i thought the kit one was a little too 'clunky' , this took a little chopping and whittling to get the correct shape to fair into the resin of the kit. I then dipped it in Klear to protect it and give it that trademark shine. Once dry i tacked it in place with a couple of spots of CA then filled in the offending gaps with Vallejo's plastic putty. I then sanded this back as much as i dared. Anyway this is how she looks now, I've wiped some black oil paint into the panel lines so you can see them more clearly. Just got a few more little bits like the pylon adaptors to fill and sand, missles and a few vents and intakes to finish off and shes ready for some paint. Cheers Rich Edited August 10, 2010 by Rich F Link to comment Share on other sites More sharing options...
Dads203 Posted August 10, 2010 Share Posted August 10, 2010 Amazing work Rich, looks the business that fella. Can't wait to see it finished. Link to comment Share on other sites More sharing options...
atdb27 Posted August 10, 2010 Share Posted August 10, 2010 I like this build. I served on LTF in the early days (when it formed up basically) We had some mix of finishes on T'birds. XS417 all over NMF XS452 Green upper NMF lower (ex RAF Akrotiri stn hack! Pink Flamingo) XS457 as per your posted pic XS458 Grey upper NMF lower Adrian Link to comment Share on other sites More sharing options...
Doctor Strop Posted August 10, 2010 Share Posted August 10, 2010 Stunning work so far. I hope my 1:48 Mk1A turns out at lease half as good. Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted August 11, 2010 Share Posted August 11, 2010 Nice work Link to comment Share on other sites More sharing options...
AnonymousAA72 Posted August 11, 2010 Share Posted August 11, 2010 Nice to see the T5 back on the A1 Radar scope.............looking good Rich, some excellent detail work there!!!! Link to comment Share on other sites More sharing options...
atdb27 Posted August 11, 2010 Share Posted August 11, 2010 Just noticed that you have the upper fuselage letter boxes open! For a Static a/c no engines running these would be closed/flush. A bit like the mistake Airfix made with their 48th scale Jaguar intakes. Adrian Link to comment Share on other sites More sharing options...
goon Posted August 12, 2010 Share Posted August 12, 2010 This looks beautiful, even in the bare resin! Link to comment Share on other sites More sharing options...
Rich F Posted August 12, 2010 Author Share Posted August 12, 2010 Thanks guys for the kind comments. Just noticed that you have the upper fuselage letter boxes open!For a Static a/c no engines running these would be closed/flush. A bit like the mistake Airfix made with their 48th scale Jaguar intakes. Adrian Hi Adrian, thanks for pointing that out, I'll get em closed up right away! Rich Link to comment Share on other sites More sharing options...
kev67 Posted August 12, 2010 Share Posted August 12, 2010 You are doing a great job keep it up, resin is not the best material at times but I am sure you will get an excellent result Link to comment Share on other sites More sharing options...
Rich F Posted October 7, 2010 Author Share Posted October 7, 2010 Managed to get a bit more done on this although my mojo did disappear for a while. All the painting done now, first coat on was humbrol primer then humbrol satin black was applied to the NMF areas. Then on to the Dark Sea Grey and Dark Green which were Xtracolor, at this point i added a couple of drops of black and did a spot of post shading. The NMF were various shades of Alclad, all applied with my trusty Badger 150. On to the pics... Next up decalling. Rich Link to comment Share on other sites More sharing options...
Darth Vader Posted October 7, 2010 Share Posted October 7, 2010 Fantastic job there Rich ! the paint looks spot on. Link to comment Share on other sites More sharing options...
Tim T Posted October 7, 2010 Share Posted October 7, 2010 Beautiful. How can you not love a Lightning? Great work. Link to comment Share on other sites More sharing options...
