Enzo the Magnificent Posted November 3, 2023 Share Posted November 3, 2023 2 minutes ago, jackroadkill said: You're still not coming, sweetheart. That's probably best. It will give everyone a chance to talk about me behind my back which is, of course, the polite way of doing things. 2 Link to comment Share on other sites More sharing options...
UberDaveToo Posted November 6, 2023 Share Posted November 6, 2023 Where do I vote? Link to comment Share on other sites More sharing options...
81-er Posted November 6, 2023 Share Posted November 6, 2023 In the Bunfight poll, we're listed as WW2 Axis & Allied Twins James Link to comment Share on other sites More sharing options...
Zephyr91 Posted November 6, 2023 Share Posted November 6, 2023 OK, newbie question. Can I do one model in 2 group builds? My intended for this is an old Airfix Henschel Hs129. But it's also a perfect fit for the Classic Airfix GB as well? Rob Link to comment Share on other sites More sharing options...
81-er Posted November 6, 2023 Share Posted November 6, 2023 14 minutes ago, Zephyr91 said: OK, newbie question. Can I do one model in 2 group builds? My intended for this is an old Airfix Henschel Hs129. But it's also a perfect fit for the Classic Airfix GB as well? Rob I'm going to throw this one over to @Enzo the Magnificent as the sage and learned master of the group builds James 1 Link to comment Share on other sites More sharing options...
Corsairfoxfouruncle Posted November 6, 2023 Share Posted November 6, 2023 1 hour ago, Zephyr91 said: OK, newbie question. Can I do one model in 2 group builds? My intended for this is an old Airfix Henschel Hs129. But it's also a perfect fit for the Classic Airfix GB as well? Rob 1 hour ago, 81-er said: I'm going to throw this one over to @Enzo the Magnificent as the sage and learned master of the group builds James I will submit this as it’s been asked more than once. Maybe Enzo could place this thread into a FAQ section ? Dennis 1 1 Link to comment Share on other sites More sharing options...
81-er Posted November 7, 2023 Share Posted November 7, 2023 Thanks Dennis I thought I'd seen that thread before, but I couldn't remember where to find it James 1 Link to comment Share on other sites More sharing options...
Zephyr91 Posted November 7, 2023 Share Posted November 7, 2023 13 hours ago, Corsairfoxfouruncle said: I will submit this as it’s been asked more than once. Maybe Enzo could place this thread into a FAQ section ? Dennis Thanks Dennis. Got it. Hadn't thought of the logistics of both maintaining double wips but also that it would only be possible if the GBs were running at the same time. I'll keep things simple (fits with my brain size!) and not double up. cheers Rob 2 Link to comment Share on other sites More sharing options...
vppelt68 Posted November 10, 2023 Author Share Posted November 10, 2023 ...and then suddenly, out of the blue, came this announcement from Airfix which means I must build a Reichverteidigung Me 410 in this GB. Thank you, Airfix 5 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted November 10, 2023 Share Posted November 10, 2023 4 hours ago, vppelt68 said: ...and then suddenly, out of the blue, came this announcement from Airfix which means I must build a Reichverteidigung Me 410 in this GB. Thank you, Airfix I was intending to build the Italeri Me410, but I'll go for the Airfix one instead. I wonder if I can convert it to an Me 210... 1 Link to comment Share on other sites More sharing options...
vppelt68 Posted November 10, 2023 Author Share Posted November 10, 2023 11 minutes ago, Enzo the Magnificent said: I was intending to build the Italeri Me410, but I'll go for the Airfix one instead. I wonder if I can convert it to an Me 210... Just read the Airfix workbench feature on this. Quoting that: "If you know where to look, despite the similarities shared by the two aircraft, it isn't difficult to differentiate between a Messerschmitt Me 410 and its predecessor and with it, identifying an effective combat aircraft from an extremely flawed one. Looking at a side profile of the aircraft, the Me 410 has a slightly taller and noticeably longer fuselage, with lengthened, more refined engine nacelles housing the new and more powerful Daimler Benz DB 603 engines. These modifications alone gave the aircraft a more elegant appearance, if also highlighting its potential as an effective combat aircraft. The instability issues which blighted its predecessor were rectified by redesigning the wing shape and incorporating automatic leading edge slat technology, to give the aircraft much better low speed handling qualities. The wing of the Me 210 featured two different leading edge sweep angles, with a 6 degree sweep inboard of the engines and 12.6 degree sweep outboard, however, the Me 410 wing design did away with this, maintaining a constant 5.5 degree sweep across the length of the leading edge." If you want to backdate it, tell us in advance so I know to get enough to watch it! 1 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted November 10, 2023 Share Posted November 10, 2023 29 minutes ago, vppelt68 said: If you want to backdate it, tell us in advance so I know to get enough to watch it! That all sounds perfectly feasible. 1 Link to comment Share on other sites More sharing options...
JOCKNEY Posted November 10, 2023 Share Posted November 10, 2023 1 hour ago, Enzo the Magnificent said: I was intending to build the Italeri Me410, but I'll go for the Airfix one instead. I wonder if I can convert it to an Me 210... Just crash it, that's what happened to most of the 210 's 6 Link to comment Share on other sites More sharing options...
vppelt68 Posted November 10, 2023 Author Share Posted November 10, 2023 30 minutes ago, JOCKNEY said: Just crash it, that's what happened to most of the 210 's Ach, ein Messerchmitt Sternzerstörer? Link to comment Share on other sites More sharing options...
81-er Posted November 10, 2023 Share Posted November 10, 2023 Having seen both the only surviving 410 on public display AND the new Airfix model up close I can confirm that it's a very, very good model indeed! James 2 1 Link to comment Share on other sites More sharing options...
franky boy Posted November 10, 2023 Share Posted November 10, 2023 2 minutes ago, 81-er said: Having seen both the only surviving 410 on public display AND the new Airfix model up close I can confirm that it's a very, very good model indeed! James Where does the surviving 410 live James? Link to comment Share on other sites More sharing options...
vppelt68 Posted November 10, 2023 Author Share Posted November 10, 2023 Just now, 81-er said: Having seen both the only surviving 410 on public display AND the new Airfix model up close I can confirm that it's a very, very good model indeed! James Oh dear, since I took a look at that Xtradecal sheet I'm now afraid this won't end with just the one I ordered today 1 Link to comment Share on other sites More sharing options...
81-er Posted November 10, 2023 Share Posted November 10, 2023 20 minutes ago, franky boy said: Where does the surviving 410 live James? Cosford, which is handily just down the road from Telford, so I popped in for a look on my way up. The only other one is in storage in the US. 20 minutes ago, vppelt68 said: Oh dear, since I took a look at that Xtradecal sheet I'm now afraid this won't end with just the one I ordered today I'm amazed that you only ordered one to start with I'm also slightly surprised that having LIDAR scanned the Cosford example, it's not in the kit schemes. There's an aircraft with the same codes, but it's the big gun-armed one and has a different Werk No. to the Cosford example (I took photos while I was there). James 2 Link to comment Share on other sites More sharing options...
PeterB Posted November 14, 2023 Share Posted November 14, 2023 As a matter of interest, would the He 177 be considered acceptable for this GB - it has two engine nacelles but the engines are of course made up of two "bolted together", but then the "double block" engine was considered to be a single unit? Pete Link to comment Share on other sites More sharing options...
Graham Boak Posted November 14, 2023 Share Posted November 14, 2023 The two "bolted together" could not operate individually, so the He.177 has to count as a twin. Much as the Manchester was powered by two Vultures, each of which was made up of two Kestrels "bolted together". The term does hide a considerable amount of engineering in both cases. 1 Link to comment Share on other sites More sharing options...
81-er Posted November 14, 2023 Share Posted November 14, 2023 Hi @PeterB, this one was raised earlier, and it was agreed to set the eligiblity conditions as any aircraft using two propellers or two jet engines, so you can indeed build an He-177 James (also reminded he has an He-177 in the stash) 1 Link to comment Share on other sites More sharing options...
PeterB Posted November 14, 2023 Share Posted November 14, 2023 (edited) So that gives me a B-25, Hs 129 and He 177 as possible builds, though the 177 may go in the Classic Airfix GB! Pete Edited November 14, 2023 by PeterB 5 Link to comment Share on other sites More sharing options...
vppelt68 Posted November 15, 2023 Author Share Posted November 15, 2023 @Enzo the Magnificent please re-move this one to the Future GB:s, maybe this and the Allied Twins threads should, if they only could, be merged? Thanks a million anyway for herding us 😸 😼 Link to comment Share on other sites More sharing options...
Enzo the Magnificent Posted November 15, 2023 Share Posted November 15, 2023 2 minutes ago, vppelt68 said: @Enzo the Magnificent please re-move this one to the Future GB:s, maybe this and the Allied Twins threads should, if they only could, be merged? Thanks a million anyway for herding us 😸 😼 There is already a combined thread in Future GBs but I'll see what I can do about merging all three threads. 3 Link to comment Share on other sites More sharing options...
vppelt68 Posted November 15, 2023 Author Share Posted November 15, 2023 Thanks Enzo! It must feel great to have The Power! I'm amazed that the Forum software can handle this kind of merging of threads, not bad at all @Mike - well done! V-P 1 Link to comment Share on other sites More sharing options...
