Quote
5 minutes ago, longshanks said:
Shaping up nicely Matey.....
A thought re dust would it be better to use the paper wet?
Kev
I did wet the sandpaper at the start but ran out of spit and could  not be bothered to keep taking the face mask off Mrs Beefy said I had to leave it on You look better that way she said  :shrug:
beefy
Quote
22 hours ago, longshanks said:
Not for us to argue with SWMBO
How very true
Quote
On 5/9/2017 at 7:50 PM, robgizlu said:
I like the pic Beefy - cant be too careful?
Well it did say make sure you are wearing these in the instruction booklet  :book:
Any way small update the deck has finally done as it is told and stuck down  :D
Marked out the plastic card and roughly cut it to shape and stuck that in place it is starting to work now
Also made a start on the bandstand supports
And a few bit dry fitted
Beefy
On ‎5‎/‎8‎/‎2017 at 8:28 PM, beefy66 said:
Yes Andy I have the same problem I was told about working with resin so I take no chances and make sure I wear my PPE just like I do at work
Warning you may get a fright at the next photo  :wink:
You have been warned
Beefy in his modelling PPE
Keith mate,
I thought that dressing up like that was our little secret :lalala:
Keith
Quote
It was untill you have just gone and told everybody  :P
Beefy
Quote
On 5/13/2017 at 1:24 PM, robgizlu said:
Nice job on the transom
Rob
Well a bit more work done on getting the hull and deck tidy I have drilled out the holes for the exhaust ports but have managed to lose one to the carpet monster
so will look to making a one from plastic card and rod with my punch and die set  :idea:
Also attached the bandstand base and side brace plates
beefy
  • 3 weeks later...
Well a bit busy keeping you lot entertained on another build so this has been waiting in the wings so to speak not much done but will be adding some crew and a few other bits
These are what I purchased at the Northern Model show last weekend
These will not all be used on this build but will come in handy for other builds
beefy
Small amount done tonight scratch built the exhaust port that the carpet monster got  :doh:
maybe just a bit to big  :hmmm:
beefy
  • 2 months later...
Well been a bit busy with another build but have found some time to get back on to this as some of you might have thought I had forgot about it
Started building up the the forward gun but have had a small accident I have broken the muzzle so any help full advice from those of you who have the dark art of scratch building in your blood  :idea:
beefy
Is it the flash eliminator (cone) you've bust?
If it is...
Cocktail stick/sharp pencil. Shouldn't need release agent unless you flood with superglue
Wrap paper around tightly (cone shape).
Let super glue soak into paper
et voila .... a cone to be cut to size
HTH
Kev
If it is...
HTH
Kev
Yes that is what I have bust
and thanks for the tip you make it sound soo easy  :book:
beefy
Thanks again for your help Kev  :yes:
Did not quite get the origami right with the paper rolling after about 10 attempts never did try roll your own smokes or smoking at all for that matter
But I did remember a friend from my local club made me a rolling tool with a point on it and tried to make to replacement cone with tin foil
Does not look to bad what do you think it is only dry fitted to the 2 pounder barrel at the minute
Just needs to be glued and straightened I think  :idea:
beefy
After seeing the great work andrewa has made of his MTB build I thought I had better get my finger out with this one
Well heavy handed Harry has been at it again while trying to separate the outer shield for the bridge I have managed to break it into umteen bit's and I have lost some parts to the carpet monster which is strange as there is no carpet in the garage were my desk is  :think:
So got some thin plastic strip and made up the missing bits lesson to myself try and be a bit more patient with this thing
beefy
12 minutes ago, longshanks said:
See you can scratch build...........
Another lesson learnt in the great jungle of modelling
:penguin:
Kev
Not quite up to some peoples standards but I suppose I have to start some where i think it has something to do with hanging around you lot on here for to long  :smile:
beefy
