This model is going to be one of the two Sea Kings that collided during Op Telic. For those people who do not like this tough, as I was on HMS Ark Royal at the time and felt the mood on the ship at that time. It will be a combination of the Revell kit with some of the parts from the Airfix kit. I will also be using the Airwaves deflated radome, and decals from the kits and other various sources. I may also attempt to fold the blades.
I don't see what can be wrong with tribute builds. I intend to do a SHAR1 of Lt Steve Holmes who we lost in the Med when I was with 800sqn on Invincible. Will certainly be watching this build.
A big thank you to all those who gave their support when I saud that this build was going to be a tribute. Although it may not look it, some modelling has actually been done to the Sea King. I have got rid of a lot of things that the instructions tell you to do, especially the cabin floor. Although most of the insides will not be seen as the cabin door will be shut, I still like to get this done as some might be seen through the square window.
This shows a comparison between the Airfix and Revell inflatable radomes. The Airfix one is on the right, which is much bigger than the Revell one. I will be using the Airwaves deflated set, but which radome is actually correct?
To be honest not much has been done to this project due to the fact that i had to get another model ready for a competition at my club meeting tomorrow (see RFI). I have managed to get the inside of the fuselage and the instrument panels painted and some of it fixed to the flooring. Hopefull this week I will be able to concentrate a bit more on this one, getting a bit more build up and put together.
will hopefully get the cockpit and the rear section stuck into the side of one of the fuselage halves and then stuck together. Photos will follow in due course.
Quick note about colour, the RN machines are two shades of grey not one - the undersides are listed as "Flint" which is actually our old friend "Barley" Grey now Camouflage Grey.
Edited by Jonathan Mock
I thought that this might be the case as the Airfix kit instructions say so, but I was not quite sure so thanks for clearing that up.
How does the old kit look please Jabba?
Have one in the stash so will be watching with interest
It is still the same old kit with the extras for the AEW version.
Does that mean it still has all the rivets
Oh yes that is why I using the Revell kit for the main bits, adding some the smaller Airfix bits as they seem a bit better.
The first couple of photos show the flight deck and cabin before I did a bit of weathering on them. These have now been stuck to the fuselage as you can see in the third photo. I have also added the box affair that the radome is fixed to and, hopefully tonight I shall have it glued together, and the rest of the construction can then follow. I doubt that I shall have this one finished before the end of the GB, but I will keep on putting in updates until it is.
looking good mate is this the last one for the GB?
Oh yes, but there are plenty models in the loft that need building on this theme.
The fuselage and the undecarriage sponsons are now together. I have added a few of the ECM bits from the Airfix kit as they seem to be a bit more accurate, in my opinion. I have got the front piece glued to the windscreen and will hopefully add that in the not too distant future. I know that this will not be completed in time for the end of the Gb, but I will keep on adding updates here, unless told otherwise.
The build still goes on and all is togther now and ready for painting. I am a little undecided about folding the rotor blades as the kits rotors don't look like the real thing, without a lot of modification. I shall have to have look at this properly before i go ahead and decide what to do.
I have now moved this to the Iarcraft In Progress section, but I will post pictures of the finished model also in this section.
Latecomer to this thread, but I think the idea of a tribute model is a terrific one. And, your work is looking great so far!
