shortCummins Posted August 24, 2022 Author Share Posted August 24, 2022 16 hours ago, Pete in Lincs said: Delicious delicate bits. Pause now to readjust your eyesight ha ha without an optivisor I'd stick my fingers together even more often rgds John(shortCummins) Link to comment Share on other sites More sharing options...
Biggles87 Posted August 24, 2022 Share Posted August 24, 2022 Optivisor! That’s a good idea, I’ve got one somewhere, I really must start using it. Excellent cockpit detail as usual, you’ve put more wiring into the radio deck than I did on my 1/32 version. John 🇺🇦 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 24, 2022 Author Share Posted August 24, 2022 1 hour ago, Biggles87 said: Optivisor! That’s a good idea, I’ve got one somewhere, I really must start using it. Excellent cockpit detail as usual, you’ve put more wiring into the radio deck than I did on my 1/32 version. John 🇺🇦 thanks John I'm not convinced that much of it will be seen although there's quite a lot of "glass" so maybe it will be seen? rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 24, 2022 Author Share Posted August 24, 2022 The cockpit glass had their Montex masks applied and painted with some Xtreme Metal AK480 dark aluminium. these Xtreme metal paints cover really well even with no black base, the view from the "inside"... Fitting the machine guns to the upper cowl was far more trouble than it should have been!?, either the holes for them to poke through are too small or the gun barrels are too large, either way it took quite a bit of scraping, the barrels are too small to sand, to get them to fit. However once fitted the top cowl was attached to the front of the airframe. I fitted the painted gun site… …and then fixed the front and rear “glass” to the airframe. The hole was cut out in the wood decal. Next I’ll be building and adding the wings. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 11 Link to comment Share on other sites More sharing options...
mark.au Posted August 24, 2022 Share Posted August 24, 2022 Progressing really well John. Those wood decals are an interesting option, I’ve filed that away for future consideration. I’m looking forward to your paint treatment, these naked birds do look very impressive when you’ve done them. 2 Link to comment Share on other sites More sharing options...
81-er Posted August 24, 2022 Share Posted August 24, 2022 Great progress, John, she's shaping up very nicely. James 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 24, 2022 Author Share Posted August 24, 2022 57 minutes ago, mark.au said: Progressing really well John. Those wood decals are an interesting option, I’ve filed that away for future consideration. I’m looking forward to your paint treatment, these naked birds do look very impressive when you’ve done them. thanks Mark there's a couple of "makes" of wood decals, AK & Uschi van der Rosten, the AK version has a "solid" background, the Uschi ones have a "transparent" background. This means that with the Uschi version you can change the background/base colour of the wood, this becomes useful when/if you want to accentuate the wood panels, you'll see better what I mean later in the build 👍 54 minutes ago, 81-er said: Great progress, John, she's shaping up very nicely. James thanks James so far everything's taken far longer than "normal", at least it appears that way to me hopefully once the assembly is complete the "paint" will move along quicker? rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 24, 2022 Author Share Posted August 24, 2022 The fit of the upper and lower wing parts is very good… …and the fit of the wings to the fuselage is also very good. Lower cowl nailed in place. The radiator assemble covers the “step” toward the rear of the airframe that I’d smoothed. Flaps fitted. Next I’ll prepare the airframe for paint. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 10 Link to comment Share on other sites More sharing options...
Pete in Lincs Posted August 24, 2022 Share Posted August 24, 2022 It's virtually racing along. A lot faster than my builds! 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 25, 2022 Author Share Posted August 25, 2022 18 hours ago, Pete in Lincs said: It's virtually racing along. A lot faster than my builds! you know it's funny but I'd been thinking that this was going quite slowly however I've just realised that I'm very close to paint and as their will be little to no weathering there really isn't too long, baring accidents, (fingers crossed) before I can start thinking about my next build? rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 25, 2022 Author Share Posted August 25, 2022 I “tacked” the centre glass in place with some liquid mask. There were a few small gaps that I filled with some liquid putty. I’m not going to add the bombs and bomb racks so I filled the mounting holes with some stretched sprue... ...after sanding the stretched sprue flush the panel lines and rivet detail was repaired. Next I’ll be starting the paint. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 11 Link to comment Share on other sites More sharing options...
Biggles87 Posted August 25, 2022 Share Posted August 25, 2022 It looks like the worst fit was at the front end of the nose to wing join, if I remember rightly the 1/32 version was the same. I’m sure you’ll be able to beat it into submission. John. 🇺🇦 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 26, 2022 Author Share Posted August 26, 2022 22 hours ago, Biggles87 said: It looks like the worst fit was at the front end of the nose to wing join, if I remember rightly the 1/32 version was the same. I’m sure you’ll be able to beat it into submission. John. 🇺🇦 thanks John it doesn't look too bad however I'll only really know when I apply some black primer, fingers crossed there won't be too much work required? rgds John(shortCummins) Link to comment Share on other sites More sharing options...
shortCummins Posted August 26, 2022 Author Share Posted August 26, 2022 Different primer(s) are needed for the wood/linen areas and metal parts, white for the wood/linen and black for the metal. To try and minimise the amount of masking I’ve decided to prime and paint the wood/linen parts before applying the black primer as the black will easily cover the lighter colours? The whole airframe washed over with some isopropyl wipes and then the wood and linen areas given a coat of Stynylrez white primer. MRP-256 doped linen was used for the “base” linen colour. MRP-259 pale wood was used for the “base” wood colour. Next I’ll be applying the “metal” paint. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 13 Link to comment Share on other sites More sharing options...
Dunny Posted August 26, 2022 Share Posted August 26, 2022 Lovely work John - enjoying another 'naked' build! Cheers, Roger 1 Link to comment Share on other sites More sharing options...
Silenoz Posted August 26, 2022 Share Posted August 26, 2022 Looking good. Will you add woodgrain? and how will you try to apply it (oil/woodgrain decal/...)? wouldn't it be better to apply it now before the metal paint? 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 26, 2022 Author Share Posted August 26, 2022 3 hours ago, Dunny said: Lovely work John - enjoying another 'naked' build! Cheers, Roger thanks Roger I must admit to liking these "naked" versions myself, there's something about seeing the materials used to build the aircraft gives the pilots and crew even more kudos when they took to the sky 2 hours ago, Silenoz said: Looking good. Will you add woodgrain? and how will you try to apply it (oil/woodgrain decal/...)? wouldn't it be better to apply it now before the metal paint? thanks Silenoz I'll be using Uschi van der Rosten wood decals so rather than risk damaging them they'll be applied after I've finished all the paint, I just know that I'd damage them if I even thought of putting (de-tacked) masking tape anywhere near them regardless of how much "protective" varnish applied!? rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 26, 2022 Author Share Posted August 26, 2022 Bothe the wood and linen base colours were masked before I sprayed the Stynylrez black primer. Looking at the gaps and filled areas I was lucky to get away with it!, with the exception of this… Next I’ll be spraying the base metal colour. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 7 Link to comment Share on other sites More sharing options...
Biggles87 Posted August 26, 2022 Share Posted August 26, 2022 Uh-oh, more filling and sanding required. What metallic paint will you be using as if I couldn’t guess. 😜 john. 🇺🇦 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 26, 2022 Author Share Posted August 26, 2022 5 hours ago, Biggles87 said: Uh-oh, more filling and sanding required. What metallic paint will you be using as if I couldn’t guess. 😜 john. 🇺🇦 I'll be using Xtreme Metal, for the "main" areas however I'll use vallejo for the small latches, in the middle of the wood, as I can brush paint them rgds John(shortCummins) 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 28, 2022 Author Share Posted August 28, 2022 After filling and sanding the gap in the bulge… …the base metal colour Xtreme Metal AK479 aluminium was sprayed. Next I’ll be applying some different metal “shades”. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 7 Link to comment Share on other sites More sharing options...
mark.au Posted August 28, 2022 Share Posted August 28, 2022 Looks very good so far, John. Looking forward to the reveal. 1 Link to comment Share on other sites More sharing options...
shortCummins Posted August 28, 2022 Author Share Posted August 28, 2022 On 16/08/2022 at 16:36, Silenoz said: Good luck with this one. The same idea (lack of camouflage to display the wood) is linguering in my mind.. just lacking time etc... Silenoz I've found the "half and half" mossie build, it's by a chap called Roberto Colaianni and what's even more impressive is that his version was 1:72, here's a link to his build... http://www.kitshow.net/int/RC_26_Mosquitos.php rgds John(shortCummins) 2 Link to comment Share on other sites More sharing options...
shortCummins Posted August 28, 2022 Author Share Posted August 28, 2022 I’m lucky enough to have a number of AK Xtreme Metal paints, so I’ll be using some different “shades” to try and create some visual interest. These additional “colours” will be lightly sprayed over the base aluminium colour, my theory is that they will give a subtile shift in the metallic effect? Post-it notes were used as masks, their low-tac glue is ideal for minimal effect on the painted surface. 478 white aluminium 480 dark aluminium 482 duraluminium 488 matt aluminium 670 stainless steel Here she is with the mask(s) removed… There’s some overspray that I’ll need to attend to, I’ll do that when I “fix” the rear fuselage seam. Next I’ll be add “shadow” colour to the linen parts. until next time as always, any suggestions, criticisms or comments will be gratefully received. rgds John(shortCummins) 10 Link to comment Share on other sites More sharing options...
Biggles87 Posted August 28, 2022 Share Posted August 28, 2022 Nice subtle variations John. I also have several Extreme Metal shades, they all look much more similar n the bottles than when sprayed. John. 🇺🇦 1 Link to comment Share on other sites More sharing options...
