LorenSharp Posted October 5, 2021 Author Posted October 5, 2021 Yes the boys at Convair were a bunch of wild and crazy guys. Just look at the XFY Pogo. Try anything and throw it up on the wall and see if it sticks. What shall we do today? "Let's take an F-102 and see if we can land it on water and take-off again...OK" 1
LorenSharp Posted October 7, 2021 Author Posted October 7, 2021 After re-scribing everything, it was easier before attaching the wings and whatnot. I drilled small pilot holes for tiny steel nails. I'll use these to hold the main parts all together. My brass rods are too small and frail and plastic rod would be to soft. The fit is better than I expected. There are some pieces missing , but I'll be able to fix this without any problem. 6
LorenSharp Posted October 7, 2021 Author Posted October 7, 2021 I tried to open the by-pass ports on the intakes, but because the resin is super thin and translucent The openings wouldn't open without fracturing. So I'll just print new ones. Which isn't too bad, I can print them out when I do the After burner cans and the cockpit parts. 3
LorenSharp Posted October 7, 2021 Author Posted October 7, 2021 Couple hours later I have new parts The intakes are much better looking. And a better version of the white metal bang seat. Time and moving around has removed most of the detail from the cockpit side wall instruments. So new ones are the order of the day. [/url One of the instrument side panels didn't print right and will have to be redone. I reprint on the Mars , it will take a little bit longer but it does better with smaller parts. Probably due to the lift speed being smaller. The Exhaust is smaller than normal so I didn't need to add an enormous amount of detail. You can't see much anyways. 11
LorenSharp Posted October 7, 2021 Author Posted October 7, 2021 The fit though not absolutely spot on, is better than I expected. A few of the edges rounded on me but this I'll correct .Which I have to do anyway when I fill in around the wing joins. Masking tape around the wings ,tail, and fuselage to cut down on the mess and keep me from obliterating the panel lines. I'll let these dry then sand smooth then start adding parts and beginning the painting and masking process. I just got more 6mm masking tape in so I'm good to go. 11
LorenSharp Posted October 8, 2021 Author Posted October 8, 2021 Adding the Cockpit exterior. Sometimes the fit leaves much to be desired. A little bit of shrinkage in the ensuing quarter century. But no matter I'll fill with some spare rod then slather and sand away. Speaking of slathering and sanding..... Finally got everything all smoothed out and uniform.... Or so I thought. 13
LorenSharp Posted October 8, 2021 Author Posted October 8, 2021 A nice even coat of white primer. I'm using this instead of the usual gray because the next coat will be the yellow on the tail, wings and fuselage aft of the cockpit. Isn't it purdy? Unfortunately.... It's actually the pits! NO thats not dirt imbedded into the paint. but small, teenie, tiny little micro pits that I missed with the magnifying glass. I almost thought I was through sanding on this little project, unlike another BIG project taking up most of my workspace That I'm maybe a quarter of the way sanding and getting straight. But that's for another build thread That I must attend to, amongst other things. But I will let this dry a day and skin the pits One. More. Time. Good thing is all are on the keel. But I have started laying down paint! The FUN now begins! So until later guys, Stay safe, Stay Healthy, and Model ON! 10
dnl42 Posted October 8, 2021 Posted October 8, 2021 Amazing work on turning this fine molding around! And you're convincing me I need a 3d printer...
LorenSharp Posted October 8, 2021 Author Posted October 8, 2021 2 minutes ago, dnl42 said: Amazing work on turning this fine molding around! And you're convincing me I need a 3d printer... Thanks! They definitely have their uses and can save ones behind on occasion.
LorenSharp Posted October 9, 2021 Author Posted October 9, 2021 Not too much of an update but painting has now commenced. Having fixed all the little pin holes(I hope) First order of business a little bit yellow. This will have to cure for a day or so. I want it good and dry so no paint decides to peel off once masked before applying the blue. Ahh masking, what I live for.. If I thought masking red, white, and blue stripes and scallops on an F-4 was bad.... welll me boyos, this will probably give me the shivers in the pale moonlight just thinking about it. So until next time ... Model on! 11
AdrianMF Posted October 9, 2021 Posted October 9, 2021 Wow! Colourful. I’ve seen the blue one in San Diego but I didn’t realise that there was one with bright yellow plumage! Drilling out the two jet engines was a risky move, but it looks like you got away with it. Looking forward to more paint! Regards, Adrian
LorenSharp Posted October 9, 2021 Author Posted October 9, 2021 1 hour ago, AdrianMF said: Wow! Colourful. I’ve seen the blue one in San Diego but I didn’t realise that there was one with bright yellow plumage! Drilling out the two jet engines was a risky move, but it looks like you got away with it. Looking forward to more paint! Regards, Adrian Thanks Adrian! Believe me I sweated that drilling. I think had the rear been any thinner I don't think I could have done it without something cracking. Stay tuned for more. Same Bat Time, Same Bat Channel!
Martian Posted October 10, 2021 Posted October 10, 2021 Hmm , "shivers in the pale moonlight" , there has to be a song for my band in that phrase. 🎵 Filling pin holes in resin or bashing out the next couple of hundred for a submarine; you pays your money and tales your choice! Good work Loren. Musical of Mars 👽 1 1
Gene K Posted October 10, 2021 Posted October 10, 2021 On 10/4/2021 at 11:52 PM, Martian said: And I just remembered that there is still an official seaplane trot in Poole Harbour. It might cause a bit of chaos getting people moved off of it but still...👽 Gene K 2
Martian Posted October 10, 2021 Posted October 10, 2021 1 hour ago, Gene K said: Gene K I have often thought that it would be fun, if I had plenty of money, to charter a seaplane/flying boat and assert its legal right to land in Poole Harbour; just to see the chaos that would ensue, clearing the trot. I think the trot is a remnant of the multiple RAF, BOAC and FAA trots that existed during and just after the war. Slightly Anarchic of Mars 👽
LorenSharp Posted October 10, 2021 Author Posted October 10, 2021 2 minutes ago, Martian said: I have often thought that it would be fun, if I had plenty of money, to charter a seaplane/flying boat and assert its legal right to land in Poole Harbour; just to see the chaos that would ensue, clearing the trot. I think the trot is a remnant of the multiple RAF, BOAC and FAA trots that existed during and just after the war. Slightly Anarchic of Mars 👽 Thats the Spirit Martian! Git them Hippies off the water! 1
Gene K Posted October 10, 2021 Posted October 10, 2021 9 hours ago, Martian said: ... the chaos that would ensue, clearing the trot. Being American ... a trot is what a horse does ... or what a human does after consuming too much spicy Mexican food. Google wasn't much help. Gene 3
Martian Posted October 11, 2021 Posted October 11, 2021 7 hours ago, Gene K said: Being American ... a trot is what a horse does ... or what a human does after consuming too much spicy Mexican food. Google wasn't much help. Gene A trot is also a lane cleared for seaplane/flying boat operations. A sort of runway on the water if you will. Martian 👽 4
heloman1 Posted October 11, 2021 Posted October 11, 2021 Excellent progress Loren, the yellow, certainly jumps out at you. Neat work with the printer. Colin 1
Gene K Posted October 12, 2021 Posted October 12, 2021 @Martian thanks for the seaplane education. @LorenSharp Really appreciating the skills you applied to this challenging kit! Lest anyone get a bad impression of Collect-Aire -- the Sea Dart is one of the earlier (1995?) kits from Lou Maglio, Mr. Collect AIre. He initially (1990?) used different pattern makers and European resin casters before settling in with a superb Russian around 1998 (or so) whose patterns were cast in the US. The Russian-patterned kits are very good - one can check with Mr. Google, of course, but a good starting point for those interested in "researching" Collect AIre is here at Scalemates. Check out the superb builds by Fotios Rauch there! Gene K 1
LorenSharp Posted October 12, 2021 Author Posted October 12, 2021 Thanks Gene. Collect-Aires Models , are really good, well designed, modeling subjects, The Sea Dart making the 3rd one I've assembled . I have probably another 6 sitting in the stash. Although there are probably another 6-7 I wish I had but because of scarcity and cost, I doubt I'll never get. But, if I had any qualms about the kits it would be the amount of pin holes. But that is a minor beef really. I've built other resin subjects that were far more "Holey" What I probably should have done before starting was Primed everything to detect where all issues are and can be dealt with early on. Overall ,with a little bit of care, they come out really well.
Gene K Posted October 12, 2021 Posted October 12, 2021 2 hours ago, LorenSharp said: I have probably another 6 sitting in the stash. Although there are probably another 6-7 I wish I had but because of scarcity and cost, Loren, It's apparent from the Sea Dart that you are a Resin Master Builder. Unfortunately, it turns out that I'm a Resin Master Collector, my Collect-AIre stash being 17, mainly those patterned by the Russian. Pin holes in the newer resin aren't a factor, but thin pieces like wing strakes are fragile. In that regard, after your post I whiffed the Russian's FJ-3 Fury (the one that Kitty Hawk "referenced" for their kit), and both my kits are blemish free, one in the old dark resin, and the other in the more pleasing light tan. Sorry to stray off topic. Gene K 1
LorenSharp Posted October 12, 2021 Author Posted October 12, 2021 I don't know that I'm a resin "Master" I'm still working out trying to build a good model that was manufactured in resin.. Strake s and thin pieces do the same with me most are either chipped or broken off entirely. One thing I've noticed also with the Darker Tan/ochre resin kits, when you start sanding or grinding the resin down, the resin has the strong odor of Naphtha or more precisely Moth balls. 1
LorenSharp Posted December 27, 2021 Author Posted December 27, 2021 Here we are many weeks later. After several trys and as many re-dos I got a paint job that's almost satisfactory. I did finally get some 2 and 3 mm masking tape that helped a lot in being able to do the maddingly complex paint job over a bunch of compound curves. After the headache of a build with a Bicentennial F-4 I did I SWORE I wouldn't do any more complex paint jobs. So what did I do? Complex paint job of course. In my defense, I figured 2 colours would be easier than 3 colours. And the only white would be a base coat for the yellow. Still a son-of-a-gun to mask, AND keep the tape from curling up. One thing that helped this time I think was applying several misting coats and allowing them to settle a bit before continuing. If you're wondering it took about as long to remove the masking tape as it was to apply. There are a few spots on the Flaperons and on the "Spider web" pattern over the intakes that will need attending to but first I'll let this dry completely and give it a clear gloss varnish to at least protect what I have done. Then see if I can find my bottle of Flat White to do a touch up base. I'm hoping to finish this off before the New Year....Maybe. So stay tuned for more. 10 1
Desk Flyer Posted December 27, 2021 Posted December 27, 2021 Wow! Amazing work! And the paintjob too! Well done! 👏 May I please ask what did you do for those tiny holes/bubbles in the resin? Did you use some liquid filler? I have the same problem with a resin kit and I can't find a cure for it yet. Thanks!
