Steve Vince Posted June 20, 2019 Posted June 20, 2019 (edited) Well here goes guys and gals. This is my first build blog, so not sure how well it is going to go I have a severe sight impairment, so I am not professing to be a master builder by any means, but i thought I would give it a try I am attempting the Monogram Pro Modeller f-117A Nighthavk kit which has been sat on my shelf for a year or so now I believe there are still a few of the kits about on ebay So here goes...... Edited June 20, 2019 by Steve Vince 8
Steve Vince Posted June 20, 2019 Author Posted June 20, 2019 (edited) I got a bit of a head start before deciding I was going to do this blog, so here are some pictures of the finished seat and cockpit A couple of PE buckles and some masking tape were used to finish the seat belts off The rest of the cockpit is straight out of the box, switches panels painted dark grey then dry brushed with light grey, the displays were painted in transparent green then a coat of Johnsons clear And finally with the seat in place A dark oil wash was used in cockpit before a final matt finish was applied Edited June 20, 2019 by Steve Vince 11
Nikolay Polyakov Posted June 20, 2019 Posted June 20, 2019 Hello and welcome to the modelling world, Steve! 👋 Nice progress with the Nighthawk, keep up the good work.
frelon94 Posted June 20, 2019 Posted June 20, 2019 I wish you to enjoy building this kit but be careful ; the monogram kit is representing the early/prototype version of the Nighthawk. So it is not accurate to make a late or operational aircraft. I painted mine with the 3 tones experimental camo (you can find few pictures on the net with not so good quality unfortunately)
Steve Vince Posted June 20, 2019 Author Posted June 20, 2019 Thanks for the comments. I am probably not going to deviate from the instructions on this one, keeping it simple for the first posting 1
LorenSharp Posted June 20, 2019 Posted June 20, 2019 Excellent job so Steve, Keep up the good work and Welcome to our Merrie Band of Misbegotten Builders.
Steve Vince Posted June 21, 2019 Author Posted June 21, 2019 A bit more progress, Front wheel well and bomb bay done today and after some weathering Bomb racks next, then on to the wings. Already see fit issues with them ☹️😑😑 2
bushande Posted June 22, 2019 Posted June 22, 2019 On 6/20/2019 at 9:10 PM, frelon94 said: I wish you to enjoy building this kit but be careful ; the monogram kit is representing the early/prototype version of the Nighthawk. So it is not accurate to make a late or operational aircraft. I painted mine with the 3 tones experimental camo (you can find few pictures on the net with not so good quality unfortunately) Can you give proof to that? I always had the impression that boxing of the Revell kit actually represents a proper operational aiframe. From which exact features would you derive that this kit doesn't represent a normal operational aircraft?
Maxwellphillips Posted June 23, 2019 Posted June 23, 2019 On 21/06/2019 at 17:51, Steve Vince said: Bomb racks next, then on to the wings. Already see fit issues with them ☹️😑😑 Hopefully nothing too serious, looking good so far
Steve Vince Posted June 24, 2019 Author Posted June 24, 2019 A couple of more updates The missicle crriages are built and installed Below you can see the fitting issues with the wings...both were as bad Built the Paweway bombs that came with the kit They really are pants, so bit the bullet and have invested in Eduard Brassins resin set. Just waiting for them to arrive along with the paint masks You can see below that the entire wing lengths needed filling. Not shown was that there were gaps in the leading edges of one of the wings that also needed some filling. (These are not th Eduard bombs) Off on my hollies for a week, so more when I get back 4
frelon94 Posted July 10, 2019 Posted July 10, 2019 On 22/06/2019 at 17:23, bushande said: Can you give proof to that? I always had the impression that boxing of the Revell kit actually represents a proper operational aiframe. From which exact features would you derive that this kit doesn't represent a normal operational aircraft? I know that landing gears and wheels are not he same on the early version (that I called prototype) of the F-117. And I've never talked about the Revell kit but the Monogram one 🙂
Alan P Posted July 10, 2019 Posted July 10, 2019 Nice work! Always loved the F-117, it was a major milestone in combat aircraft development. Alan
Steve Vince Posted May 25, 2020 Author Posted May 25, 2020 Cant beleive its been such a long time since starting this model and my last post here Lockdown has given time to do some more work on this model. So here are the latest pics the tail has mow been fitted not too much filling and sanding to get it to look half decent A small amount of photoetched parts were supplied with the kit so have fitted them 1
Steve Vince Posted May 25, 2020 Author Posted May 25, 2020 Painted and added some fine solder to create pipes on the under carriage 1
Steve Vince Posted May 25, 2020 Author Posted May 25, 2020 A coat of primer to show up any imperfections, and gaps etc, then ready for painting 2
Steve Vince Posted June 4, 2020 Author Posted June 4, 2020 As i said in a previous post, the included weaponry was a bit naff Here you can see the difference between the original and the Eduard Brassin Resin ones
Steve Vince Posted June 4, 2020 Author Posted June 4, 2020 Here is the body finally painter and the decals applied And weapons installed
exdraken Posted June 5, 2020 Posted June 5, 2020 15 hours ago, Steve Vince said: As i said in a previous post, the included weaponry was a bit naff Here you can see the difference between the original and the Eduard Brassin Resin ones hmm, not sure, but those bombs are GBU-11 s as it seems.... never seen them on a F-117 before! I think they use the GBU-27, or maybe GBU-10 that is included in the kit itself and does not look that bad at all.
