bristol boy Posted August 7, 2018 Posted August 7, 2018 Hello All, A bit late to the party but here is my project, two Bristol Scouts, one injection moulded by MAC and a vacform by Libra. Some spare parts from the MAC one including decals will be used in the vac build. Not decided schemes yet but the Libra will be a 'D' and the MAC a 'C' Just noticed the Libra kit is issue 001, would have been a collectors item if I hadn't already started chopping it up! 5
bristol boy Posted August 8, 2018 Author Posted August 8, 2018 Very pleased with how easily the Libra parts cut out and sanded down, but then they are small. The fit seems a lot better than any Contrail or Sanger vac I have made before. I now have two fuselage's assembled and glued. The MA one see a bit fatter at the tail end! I've now decided on my schemes, the Libra vac will be a Scout D in linen ..and the MAC one a Scout C in green. 3
Robert Stuart Posted August 8, 2018 Posted August 8, 2018 That's quick progress, especially with the vac-form. Getting the cockpit and cowel openings neat can be a struggle. 1
bristol boy Posted August 10, 2018 Author Posted August 10, 2018 Cowlings, engines on, showing the difference between a 'C; and 'D'. The vac cowling for the Libra kit was oversize so was able to use the spare one from the MAC kit. Also added a cockpit combing (I think that's the right term?) to the vac kit using some thin wire. Will start looking at wings next. 4
Ted Posted August 10, 2018 Posted August 10, 2018 They both look great, the Bristol Scout is such a beautiful airplane. 1
Robert Stuart Posted August 12, 2018 Posted August 12, 2018 Those scouts are looking good On 10/08/2018 at 08:26, bristol boy said: Also added a cockpit combing (I think that's the right term?) to the vac kit using some thin wire. I like your wire idea - that is an idea I should pinch for my own build 1 1
Brandy Posted August 28, 2018 Posted August 28, 2018 I use Mr Dissolved Putty for the coaming. It can be applied with an old paintbrush and pulled into shape as it starts to dry. It is also much easier to adjust the amounts to get the thickness you want. Ian 1
Corsairfoxfouruncle Posted August 28, 2018 Posted August 28, 2018 On 8/10/2018 at 2:26 AM, bristol boy said: Also added a cockpit combing (I think that's the right term?) to the vac kit using some thin wire. I know you used wire and it does look good. However while reading this I had a thought pop into my head. If you stripped off the insulation from a fine wire. Could you not carefully split it on one side and place it around the opening to form the combing ? Dennis 2
bristol boy Posted August 29, 2018 Author Posted August 29, 2018 18 hours ago, limeypilot said: I use Mr Dissolved Putty for the coaming. It can be applied with an old paintbrush and pulled into shape as it starts to dry. It is also much easier to adjust the amounts to get the thickness you want. Ian I shall remember that for future use, bending wire can be difficult but I quite like the fact that it is neat and a constant thickness. 17 hours ago, Corsairfoxfouruncle said: I know you used wire and it does look good. However while reading this I had a thought pop into my head. If you stripped off the insulation from a fine wire. Could you not carefully split it on one side and place it around the opening to form the combing ? Dennis Nice idea but I don't think my eyesight or fingers could manage to install the split insulation.
bristol boy Posted August 29, 2018 Author Posted August 29, 2018 Time for a long overdue update as things are now coming together, I'm trying to keep them both going at roughly the same pace. One of the most difficult things with biplanes is getting the top wing on and all the struts lined up particularly with a vac where there are no locating points and you can't drill one for fear of going through the wing! 5
Robert Stuart Posted August 29, 2018 Posted August 29, 2018 That is good progress. I like the wing strut jig, and may steal that idea when I come to that stage with my own build. 1
bristol boy Posted September 7, 2018 Author Posted September 7, 2018 Upper wing now on, a bit of cursing involved and rigging well under way. It's fine fishing line. 3
Corsairfoxfouruncle Posted September 7, 2018 Posted September 7, 2018 I do like the nose art 👍 thats literally on the nose of the aircraft. 1 1
bristol boy Posted September 8, 2018 Author Posted September 8, 2018 17 hours ago, Corsairfoxfouruncle said: I do like the nose art 👍 thats literally on the nose of the aircraft. Thanks, I’m using the spare MAC decals for the Libra kit Which included the Weary Willie decal but had no instructions about where to put it, from the shape the nose seemed the most likely position. I’ve noticed with the MAC kit that there are quite a few parts with no indications as to where they go! 1
bristol boy Posted September 20, 2018 Author Posted September 20, 2018 Rigging! Getting a bit bored with fishing line and stretched sprue but it has to be done and is nearly finished.
bristol boy Posted September 20, 2018 Author Posted September 20, 2018 Helps if you attach the photos before you accidently press Submit Reply! One issue that has cropped up with the Libra model is the oversize Aeroclub wheels that come with the kit, hence no wheels on that one yet! A solution arrived in the post courtesy of Jinxman- many thanks. 5
Colin W Posted September 21, 2018 Posted September 21, 2018 Excellent piece of work. Good to see you doing the aileron control lines Colin 1
John Masters Posted October 8, 2018 Posted October 8, 2018 Nice work...love the rigging and a fun idea for the two builds! 1
