Tamiya 1/35 scale M3 Stuart 1 with AFV Club Tracks (another one catches my eye!)
After thoroughly enjoying the Crusader build and with a few hours to kill.. oh who am I kidding? I went and did it again, looking through the stash and found this blast from the past recently purchased along with a nice set of AFV Club workable tracks.
Tamiya35M3StuartWIP-25-06-16basic01_zpsf
Tamiya35M3StuartWIP-25-06-16basic02_zps7
Tamiya35M3StuartWIP-25-06-16basic01a_zps
After a few hours Saturday night and Sunday evening (after I got back from the Coventry and Warks show) we have this.
Tamiya35M3StuartWIP-25-06-16basic03_zpsn
Lower hull painted base coat of Olive Green (Tamiya XF-58), wheels and suspension assembled and painted (not necessarily in that order)
Tamiya35M3StuartWIP-25-06-16basic04_zpsw
Running Gear all in place (sans tracks at the moment)
Tamiya35M3StuartWIP-25-06-16basic05_zpsq
Wheels all turn (except drive sprockets which Tamiya decided should be glued for some reason :shrug: )
Tamiya35M3StuartWIP-25-06-16basic06_zpst
Fixed a little see through issue
Tamiya35M3StuartWIP-25-06-16basic07_zpsh
Upper hull mostly together
Tamiya35M3StuartWIP-25-06-16basic08_zpsw
and resting on chassis to show how it looks
Tamiya35M3StuartWIP-25-06-16basic09_zpso
Sorry for the delay in posting and the lack of process pictures but I sometimes get rather absorbed in the task and before I know it I've completed several assembly steps and there's no pictures of how I got there.
Anyhoo thanks for looking all
Comments and suggestions always welcome.
Phil :frantic:
Turret assembled. Leaving off the hatch covers and anti aircraft MG until painting all done. I shall have the hatches open and the provided figure in the suggested pose with forearms on the rim.
Tamiya35M3StuartWIP-25-06-16basic10_zpsx
Probably need a bit of filler in some of the seams, won't need much though.
Tamiya35M3StuartWIP-25-06-16basic11_zpsl
Gun barrels hollowed out and cooling holes in MG's opened up, a bit wonky but an improvement over the moulded raised circles as originally supplied.
Tamiya35M3StuartWIP-25-06-16basic12_zpsp
Lights, light guards, guns, grab handles and antenna base also added to upper hull.
Tamiya35M3StuartWIP-25-06-16basic13_zps5
A slightly closer view showing the cleaned up MG's
Tamiya35M3StuartWIP-25-06-16basic14_zpsv
Everything dry assembled to check fit.
Tamiya35M3StuartWIP-25-06-16basic15_zpsp
Tamiya35M3StuartWIP-25-06-16basic16_zpsw
Taking shape. A bit of filler here and there and then paint the base coat.
Then we'll move on to murdering the working tracks :)
Thanks for looking
Phil :hobbyhorse:
Base coat of Tamiya XF-58 Olive Green applied to upper hull and outside of turret. A light drybrush of Vallejo Steel to provide initial paint wear effect.
Tamiya35M3StuartWIP-25-06-16basic17_zps6
Underside of upper hull also painted.
Tamiya35M3StuartWIP-25-06-16basic18_zpsn
Tamiya35M3StuartWIP-25-06-16basic19_zpsr
Turret interior painted XF-2 Matt White
Tamiya35M3StuartWIP-25-06-16basic20_zpsg
Tamiya35M3StuartWIP-25-06-16basic21_zps5
A bit of face painting..
Tamiya35M3StuartWIP-25-06-16basic22_zpsh
These are the kit vinyl tracks, they might just be ok if I can paint them well enough
Tamiya35M3StuartWIP-25-06-16basic23_zpsl
Tamiya35M3StuartWIP-25-06-16basic24_zpsq
Commander painted up.
Tamiya35M3StuartWIP-25-06-16basic25_zpsk
Tracks Painted with base coat of Vallejo Panzer Aces Track Primer, drybrushed with Vallejo Steel and then the rubber pads painted with Tamiya XF-85 Rubber Black.
I reckon they'll look good when weathered. I may keep the AFV Club workable tracks for another project.
Tamiya35M3StuartWIP-25-06-16basic26_zps0
Tamiya35M3StuartWIP-25-06-16basic27_zpsd
Decals applied and overcoated with Tamiya Flat Clear. White stripes on mantlet were painted by hand.
Sorry for the blurred images
Tamiya35M3StuartWIP-25-06-16basic28_zpso
Tamiya35M3StuartWIP-25-06-16basic29_zpsj
Man in a hatch
Tamiya35M3StuartWIP-25-06-16basic30_zps3
I actually applied the decals on a matt clear coat and they didn't silver :yahoo:
Tamiya35M3StuartWIP-25-06-16basic31_zpsx
Shovel temporarily fitted to back
Tamiya35M3StuartWIP-25-06-16basic32_zpsx
Tamiya35M3StuartWIP-25-06-16basic33_zpse
Loosely assembled to show progress prior to weathering.
I'm planning on a lightly used look rather than a heavily weathered, muddy, gone through hell look.
Tamiya35M3StuartWIP-25-06-16basic34_zpsi
And that's the progress made today.
Thanks for looking
Please feel free to point out any glaring errors you might spot, it's a learning process for me and if nobody tells I won't learn anything :D
Phil :hobbyhorse:
Looking good so far. The main issue with the tracks is the track pin locations. They should be connecting the pads, not just on the pads.
I had planned to convert this kit into the version used in Tunisia but when the Academy kits came out I grabbed several of them to do.
Always loved the Stuart, probably because of the old Haunted Tank comics.
Thank you :thumbsup2: I hadn't spotted that. Obvious when it's pointed out.
AFV Club tracks it is then
Nice work thus far.
That cupola looks mighty uncomfortable. I wouldn't want to be sitting up top going over rough terrain, end up with bruised ribs for your troubles.
Australian convertible version, 7.4l super charged engine.
Love the supercharged convertible Stuart chassis :)
Spent the first part of the evening wrangling the AFV Club tracks (rather like herding cats) whereupon I struck upon the idea of prepainting them on the sprues (first with Vallejo Track Primer followed by Tamiya Rubber Black on the blocks and Vallejo Steel on the teeth) which added a little thickness to the pins providing a much more positive fit.
Thus after a full evenings work (with a small break for 2 slices of pizza) I got one side done :D
Tamiya35M3StuartWIP-25-06-16basic35_zpsm
They do look rather nice once wrestled into place though :)
Tamiya35M3StuartWIP-25-06-16basic36_zpsy
That's enough for now, I'm off to bed
Thanks for looking
As ever, comments, suggestions and observations always welcome.
Phil :hobbyhorse:
They definitely look better than the Tamiya ones though I have yet to try the single link ones. Have a Revell 72nd scale Abrams and it has link and length tracks and that is still holding me up.
After a sudded rush of activity, weathering is now complete. Mixture of Flory Grime,Sand and Light washes used. Initially too heavy so I cleaned most of it off (must have been Spadgent's brown trousers influence) after which I was much happier with it.
Assorted loose bits added, commanders hatch doors, commander, aerial etc.
Used AK interactive Engine Oil glossy finish enamel in places where oil might drip such as suspension and also used around what I believe to be fuel filler caps.
So Here it is.
RFI to follow when I take some nicer pictures but here it is as C Company, 1st Battalion, 13th Armoured Regiment, 1st Armoured Division, Tunisia Late 1942
Tamiya35M3StuartWIP-25-06-16basic38_zpsl
Tamiya35M3StuartWIP-25-06-16basic39_zpsp
Tamiya35M3StuartWIP-25-06-16basic40_zpsp
Tamiya35M3StuartWIP-25-06-16basic41_zpse
ooops, missed some pictures
Tamiya35M3StuartWIP-25-06-16basic42_zpsj
Fuel stains around fillers (?)
Tamiya35M3StuartWIP-25-06-16basic43_zpsa
Whaddya want?
Tamiya35M3StuartWIP-25-06-16basic44_zpsj
I plan to do a diorama with a figure in front of the tank talking up to the commander
Thanks for looking,
All the positive comments and observations truly appreciated.
Phil :thumbsup:
Edited by Phil Lewis
I really like you running the tank.
Could you please tell me as you did the dust and materials you used to it ?.
Cheers Phil :popcorn:
I used Flory water-based clay washes. In this case I used Grime, Sand and Light washes.
You apply them to a semi-gloss clear coated surface and let them dry.
You then reactivate them using tap water and can wash as much or as little off as you like.
Soft cloths and cotton buds can be used to get additional streaking effects.
I also refreshed the worn paint effect with a drybrush of Vallejo Steel, excellent stuff :D
Phil
  • 1 month later...
