Graeme H Posted April 25, 2016 Share Posted April 25, 2016 I have to agree with you Mark, I really like the nose on the Hasegawa kits, and High Planes have long had a resin undercarriage bay to correct that shortcoming, although takes a lot of fettling to fit, also comes with a set of flaps, no photo here, http://www.hpmhobbies.com/products/High-Planes-North-American-P%252d51-Wheel-Wells-%26-Flaps-resin-%28Accessories-1%3A72%29.html there is a sort of one here https://www.scalemates.com/kits/876517-high-planes-models-hpa072001-north-american-p-51-mustang but as it's been available for about 20 years probably some more out there Link to comment Share on other sites More sharing options...
Gwart Posted April 25, 2016 Share Posted April 25, 2016 The tail and the 'thick' wing leading edge of the Hasegawa D puts me of a little,you are right about the nose though. Link to comment Share on other sites More sharing options...
Pat C Posted April 27, 2016 Share Posted April 27, 2016 Interestingly the pic above shows that the work I did removing the seam down the middle of the cowl of my Mustang was pointless!!! Pat 1 Link to comment Share on other sites More sharing options...
occa Posted May 26, 2016 Share Posted May 26, 2016 Finally found a photo that shows the drooping inner leading edges: http://www.ww2color.com/search/webapps/slides/slides.php?action=update&primary_key=11474 http://www.ww2color.com/search/webapps/slides/slides.php 3 Link to comment Share on other sites More sharing options...
Bedders Posted August 29, 2016 Share Posted August 29, 2016 (edited) Thought I'd share with you some pictures of the H-model I'm working on at the moment. It's the relatively new RS Model kit which I'm enjoying very much and, together with the Airfix D and the KP B/C, has got me back into Mustangs. I've always been attracted to the H, with the tall tail, shrink-wrapped Merlin and lack of kinks, and it's interesting to compare the shape of it to a more ubiquitous D. The spindly little main undercarriage and tail-wheel positioned much farther aft than on the eariler models makes the H look quite ungainly on the ground though. Here's a comparison with the Airfix D fuselage. Despite the distortion caused by the H being slightly closer to the camera, one can still see that the H was two feet longer than the D and a bit taller, though less rounded, in the fuselage too. I've also been able to learn more about Mustang kinks - with a bit of help from the BM massiv, and the three wings below seem to be reasonably accurate representations of the three styles: The KP B kit I bought has the Malcolm hood which can't really be posed open so I might have to invest in a vacformed one if I can find one. And it will also help to narrow down the options for decoration. My preference for a 4th FG aircraft means I might end up with Howard Hively's "The Deacon", but I'll cross that bridge in due course... Justin Edited August 29, 2016 by Bedders 5 Link to comment Share on other sites More sharing options...
Cookenbacher Posted September 1, 2016 Share Posted September 1, 2016 I have the RS 'H' kit and was thinking about giving it a go during the upcoming P-51 STGB, and I think you've convinced me Justin. 1 Link to comment Share on other sites More sharing options...
