wimbledon99 Posted March 13, 2015 Share Posted March 13, 2015 Hi All, With my Sea King GB entry almost complete, I thought it time to join this party too Here's my entry. Hoping to make a start this weekend. Cheers Nigel 1 Link to comment Share on other sites More sharing options...
whitestar12chris Posted March 13, 2015 Share Posted March 13, 2015 Hi Nigel look forward to this, like the AMT clanger on the instructions front sheet NCC-1707? the enterprise being 1701 LOL All the best Chris Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 13, 2015 Author Share Posted March 13, 2015 Hi Nigel look forward to this, like the AMT clanger on the instructions front sheet NCC-1707? the enterprise being 1701 LOL All the best Chris Indeed!! At least they have the decals correct Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 14, 2015 Author Share Posted March 14, 2015 Cling-ons?!?!?!?! I'll get my coat. Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 15, 2015 Author Share Posted March 15, 2015 OK So here are the fruits of my labour this weekend.However, I have a bit of a conundrum. The main slot is really tight and I'm nervous that I'll scrape off any fuselage paint when coming to the final fit. I'm thinking about just painting a coat of Klear (for the decals) and a bit of colour for the warp drives. Does anyone have any thoughts / ideas? Cheers Link to comment Share on other sites More sharing options...
whitestar12chris Posted March 16, 2015 Share Posted March 16, 2015 Just a thought, could you not open up the slot by carefully cutting/sanding only the lower edge of the slot, so that any slight marks to the Perspex are not seen from above. Chris Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 16, 2015 Author Share Posted March 16, 2015 Just a thought, could you not open up the slot by carefully cutting/sanding only the lower edge of the slot, so that any slight marks to the Perspex are not seen from above. Chris Hi Chris, I have contemplated this but the slot has been cut so cleanly I don't want to run the risk of spoiling it. I guess the fit is so tight in order to stop the model from drooping so this could also introduce other issues. Hence, If I do paint it, I may just try some white primer and touch it up if required. Cheers Link to comment Share on other sites More sharing options...
plasmahal Posted March 16, 2015 Share Posted March 16, 2015 Great stuff so far. I second whitestar's comment and try to open the hole just a little. I'm sure you can polish the edges once you have a better fit. You will need a really togh final coat on the model either way. Just depends on how much time you have to spend on it. Link to comment Share on other sites More sharing options...
PlaStix Posted March 18, 2015 Share Posted March 18, 2015 This looks like an interesting project. I haven't seen this kit before with it's display base. I shall follow with interest. I'd be inclined to do a little bit of sanding of the lower edge as Chris suggested - but only a bit at a time with a lot of test fitting. Entirely up to you though. Kind regards, Stix Link to comment Share on other sites More sharing options...
Hunter Rose Posted March 19, 2015 Share Posted March 19, 2015 Never seen this before love the display. If your worried about scuffing the acrylic if you widen the slot with sanding/cutting, you can always buy a cheap lighter powered butane torch and flame polish the edges? Just a thought. Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 19, 2015 Author Share Posted March 19, 2015 Thanks for the ideas all. Still scratching my head on this one. Not so sure about the butane torch though Link to comment Share on other sites More sharing options...
Hunter Rose Posted March 20, 2015 Share Posted March 20, 2015 Not so sure about the butane torch though Yeah actually after I managed to burn a hole in the door of my truck in my build, I'm the last person you should take advice from involving fire! 1 Link to comment Share on other sites More sharing options...
bhouse Posted March 20, 2015 Share Posted March 20, 2015 Not so sure about the butane torch though Give it a go. It's remarkably easy and produces a perfect finish. Do practice on a bit of scrap acrylic first though! Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 20, 2015 Author Share Posted March 20, 2015 Give it a go. It's remarkably easy and produces a perfect finish. Do practice on a bit of scrap acrylic first though! Link to comment Share on other sites More sharing options...
philp Posted March 21, 2015 Share Posted March 21, 2015 If you seal the ships with a good, solid clear coat it should protect it enough not to worry about messing up the paint or decals. AMT/ERTL did several of these flight display bases not only for Star Trek and Star Wars kits but also the Thunderbirds and Blue Angels. There are a couple of build ups over on Starship Modeler (one of a Klingon Bird of Prey and the other the Star Wars Speeder Bike) and neither of them mention any issues. Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 21, 2015 Author Share Posted March 21, 2015 If you seal the ships with a good, solid clear coat it should protect it enough not to worry about messing up the paint or decals. AMT/ERTL did several of these flight display bases not only for Star Trek and Star Wars kits but also the Thunderbirds and Blue Angels. There are a couple of build ups over on Starship Modeler (one of a Klingon Bird of Prey and the other the Star Wars Speeder Bike) and neither of them mention any issues. Cool - Thanks for the info. I'll have a look on the site Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 26, 2015 Author Share Posted March 26, 2015 OK - I've opted to give the Alclad white primer a go and see what happens when I try to fit them back into the perspex. Worst case is I have to mask the perspex and tidy things up. Progress will be slow however as I have a rugby tour this weekend and I have family here over Easter. 1 Link to comment Share on other sites More sharing options...
theanorak73 Posted March 28, 2015 Share Posted March 28, 2015 just to give another opinion/option... i never did like these perspex disc mounts so i would scrap it and mount the three ships on some perspex rods... just a thought !! 1 Link to comment Share on other sites More sharing options...
wimbledon99 Posted March 29, 2015 Author Share Posted March 29, 2015 Thanks Anorak. I'll keep it in mind if I run into trouble Link to comment Share on other sites More sharing options...
wimbledon99 Posted May 2, 2015 Author Share Posted May 2, 2015 And then they were white. Thought I'd better do a little on this today to prove it's not been side-lined. 3 Link to comment Share on other sites More sharing options...
PlaStix Posted May 3, 2015 Share Posted May 3, 2015 Hi Nigel. Hope you're having a good weekend. Good to see some progress on these again. They're all looking very neat and tidy. Kind regards, Stix 1 Link to comment Share on other sites More sharing options...
wimbledon99 Posted May 4, 2015 Author Share Posted May 4, 2015 Hi Nigel. Hope you're having a good weekend. Good to see some progress on these again. They're all looking very neat and tidy. Kind regards, Stix Hi Stix and thanks. We had family down for the weekend so just managed to grab a couple of hours before they arrived. I'm hoping to do a bit more during the week so hopefully a few more pictures to follow. Cheers 1 Link to comment Share on other sites More sharing options...
PlaStix Posted May 6, 2015 Share Posted May 6, 2015 Hi Nigel. I hope you and the family had a good time and I look forward to seeing the photos. Kind regards, Srtix 1 Link to comment Share on other sites More sharing options...
wimbledon99 Posted May 22, 2015 Author Share Posted May 22, 2015 Later than I would have liked but a little more progress Link to comment Share on other sites More sharing options...
whitestar12chris Posted May 22, 2015 Share Posted May 22, 2015 Coming along nicely Nigel All the best Chris 1 Link to comment Share on other sites More sharing options...
