Building this one as part of the SEAC GB over on Promodeller and I hope I'm allowed to enter it here as well.
With these decals
The sprue shots
Seat, cockpit and pilot primed.
and then painted
Seat assembled
Cockpit assembled
Fuselage halves together
Edited by Mish
Blimey, you're not messing about with this one Mish :lol: Very swift progress, that cockpit looks very nice indeed :)
Being a big fan of the Crusader, I'll be watching this one with added interest :popcorn:
Hi Mish
off to a flying start!
love the Crusader. Must get one some time.
are those state of the art pink and blue parts holders or the things you stick between your toes to paint nails
i love the ways in which modellers find new and imaginative use for household items.
Interested to know what the kit is like. Good start by the way.
I believe it's the old Monogram kit Nick. Raided panel lines :(
Hi Mish
Spot on Walrus, there is always some in cheap nail care kits that I pilfer the sanding boards from.
Hi Mish,
Great work so far, I love the Monogram Crusader. the kit is good OOB, there are a couple of faults in the basic kit though, the ejection seat provided is a MB GRU-7 as used in the Tomcat, it is the wrong type for a Crusader which originally had a MB Mk. F5 seat although some were later fitted with a Mk. F7 seat, the seat from a Phantom looks a closer match than the Tomcat seat.
Also the main undercarriage legs are set at the wrong angle resulting in the finished kit sitting too low at the rear when built, Aeroclub do a correction set to cure this or you can just shorten the lower oleo and bend the upper oleo down to raise the rear fuselage off the deck.
Having said that the kit looks good out of the box even without the corrections.
Keep the photo's coming.
Ant
Bit more construction done this afternoon.
Should be ready for paint tomorrow.
Jez I thought I built quick. Nice work. looks really nice so far
I used to have one of these before steping up to 1/32 only, so Now I'd like to get a trumpeter one in the stash
Seems a bit easier build for you, than the Sea Harrier.
Dave
Edited by zero
Mish,
Looking good. Have you got a correction set for the main gear as it sits too low otherwise. Not too noticable but also kind of noticable.
If you have not shoot me a PM as I have a few spares.
Julien
Mish,
Julien
I haven't Julian and I've cemented the U/C legs in now :( they're not coming out in a hurry as it's a one piece part.
  • 1 month later...
Finally got around to doing a little more on this one tonight. I've 'touched' up the grey and applied a little post shading and tried to give it that work look. No pics as the lighting washes out the subtle shading.
Got a bit more done this morning. All the underside is sprayed white and the tailpipe has been sprayed up with Citadel Boltgun and I've attempted to add some heat discolouration bands.
Only half a days work today. Got the most of the underside, top and port side decaled. Decals are nice and thing but it has taken quite a few coats of Microsol to get them to conform over the raised panel lines and detail.
