Here's the progress so far: I've sanded off the raised detail, installed some of the PE and done some priming of the tub and the rest of the cockpit PE.
I've also glued the wing sections and vertical tail together and dryfitted most of the larger parts to get a sense of how cool this will look when finished.
Dan
Thanks for the comments :)
I think I'm just about done with the cockpit. Lots of PE installed, decals+Klear for the controls and displays, and some guitar string on the top of the seat for the hoses there.
The photos have shown up some bits of paint that need touching up, but I'm very pleased with the overall effect.
Dan
Thanks folks. I'm really enjoying this one! In a way, it's nice to not have lots of historical photos to use as references. Usually, I build WWII aircraft and go for accuracy, but I think I'm enjoying giving myself a bit more freedom with this one.
Dan
  • 1 month later...
They were supposed to be atmosphere capable so it wouldn't be totally out of place :)
That cockpit looks great, you've probably seen it but its also in Airfix Model World this month with some nice little tips on weathering and painting the Viper if you are after the worn look.
Looking forward to seeing this one progress
Graham
Is that a windscreen wiper on a spaceship? lol.
Not sure where you're looking; I can't see a windscreen wiper!
Very impressive - the cockpit does look very good with the decal screens.
Thanks very much! The Paragraphix bits are great.
Graham
Thanks Graham. I hadn't seen that; I may have to try and pick up a copy. I do have a few ideas about the sort of weathering I want to do.
Dan
  • 3 weeks later...
Some time later... The pilot is painted up:
I've done some more painting (I really do love Alclad!):
And the fuselage is glued up:
The fuselage has had a bit of the putty-sand-repeat treatment and is nearly ready for a coat of primer.
Dan
Very nice, but shouldn't he have taken off his helmet before answering the phone? :winkgrin:
Andy
its hands free technically he isnt holding it lol
  • 1 month later...
Thanks again for the kind words folks. Progress is slow, and I seem to have spend the last week or two doing nothing but putty-sand-repeat, but it's starting to look like a Viper now...
Here it is with some primer. I've modified the tabs on the wings so that I'll be able to leave them off until the end, rather than attaching them at this point.
And a bit more of the aft fuselage has been stuck on. The nozzles aren't glued, but are just there to guide the rest as the glue sets. I've made a start at excavating a lot of the plastic inside the nozzles to make way for some more photoetch (I'm not entirely convinced of the wisdom of this, but I've already started, so I don't have much choice now :D).
On the one hand, the way the model fits together is quite clever (The bits snap together in such a way that they keep each other in the right place - it is possible to dry fit the whole thing together and swoosh it around), but it will make painting very awkward (it does leave some rather huge gaps to fill as well, and the join between the bottom/aft fuselage/cowling pieces is pretty unimpressive). I've painted up the exposed engine components here, and will mask this off for the white, but I'm pretty sure there are going to be some bits that I'll struggle to get at (the top intake, for example, had to be painted before I stuck the upper bits on).
The eagle-eyed among you might have spotted that the pilot sitting behind the Viper is a new one. I bought the MkVII this week (which comes with the option for a female pilot) and decided to swap the pilots, so the MkII will be Starbuck's (I just have to remember which paints I used for the first pilot so they match...).
Dan
Very nice work! Looking good so far!
HÃ¥kan
I hope you're gonna do it nice 'n' beat
If you are I recommend using maskol to chip the paint, as per the viper build article in the airfix magazine last year. It's worked really well on my snowspeeder.
Edited by Neal
I'm not planning on doing it too battered, but it'll certainly get a bit of salt-masking and be dirtied up a bit.
I'm struggling on with the rear fuselage at the moment - the gaps are really quite huge... And I'm not quite sure how I'm going to sand down some of the filler I've had to apply in awkward places.
The butchering of the nozzles also continues :S
Dan
Do you plan to cut the stick in the cockpit away when you mount the figure? If so, there is going to be a bit of a disconnect between the stick molded in the pilot's hand and the stem in the cockpit with the figure's arm and stick looking like it is floating above the floor. I encountered that problem when I built my Viper a little over a year ago. In my case, I drilled a hole through the base of the stick in the hand and one in the floor and used a piece of music wire to join them and a small piece of brass rod to act as a thick stem. So when the pilot got slotted into the pit, the stick grip with the hole in it aligned on the base perfectly and made the join look seamless:
These images are not intended as a thread hijack, just an illustration of the modification I did in case you want to try something similar.
Edited by JMChladek
