B0BY_1234567 Posted March 10 Share Posted March 10 Hello! I normally paint my models with Vallejo Model Air paints as I have really come to enjoy their "feel" when brush painting. Normally, I refer to Vallejo's box sets for picking up the right colours for my models (yes, I know there are some slight accuracy issues with their paints, but for the most part I'm not too bothered since they look pretty alright to my eye). However, I was doing some research on Vallejo's RAF Day Fighter set and saw this photo: For Vallejo's Medium Sea Grey, it looks much darker than what I think it should look like! I haven't seen many complaints about the other paints in the set, however. My question is, for the Day Fighter Scheme, what VMA colours would you recommend? I don't want to really step outside of the paint line as I have really grown accustomed to VMA's properties. I'm personally happy with the shade of Vallejo's Dark Green, I'm just a little confused regarding the greys in the DFS. While I am here, are there any issues of similar gravity with Vallejo's Temperate Sea Scheme recommendations? Thank you for your help! Link to comment Share on other sites More sharing options...
Bozothenutter Posted March 10 Share Posted March 10 The whole picture looks dark. Pretty much useless to make a decision on. Take a look at a bottle, and decide. Link to comment Share on other sites More sharing options...
alt-92 Posted March 10 Share Posted March 10 It is a bit dark, but not like that pic shows. I do note that they say they brushpainted it, which in my experience tends to work less well. Spraying leaves a thinner coat so less 'dense'. 1 Link to comment Share on other sites More sharing options...
JackG Posted March 10 Share Posted March 10 @Casey posted measurements of various paints compared to the samples from the book British Aviation Colours of World War Two. The results for Vallejo 71.307 BS Medium Sea Grey was a rating of 5.3, while a rating of 2.0 or less is considered a good match. It was suggested a better paint match from Vallejo brand and rated at 1.59 is Vallejo - 71.050 See pages from 2 and 3 from the link below Link to comment Share on other sites More sharing options...
Troy Smith Posted March 10 Share Posted March 10 9 hours ago, B0BY_1234567 said: I'm just a little confused regarding the greys in the DFS. the post linked by @JackG will give as good answer as you will get. Acrylic model paint makers seem to have a great deal of difficulty matching the MAP paint standard. Medium Sea Grey is one of a family of Sea Greys, they have subtle purple-blue hue to them. Various model paints tend to be an olive or brown hued grey. Ocean Grey has a slight green hue to it, it's not obvious as tends to appear 'blueish' when next to Dark Green. Taken in direct sunlight, to my eye the Ocean Grey is dead on, the camera thinks otherwise. I made up mixes with Tamiya to the MAP chart, and others as well, which made me appreciate how carefully these colours were chosen, they change subtly in different light conditions. 9 hours ago, B0BY_1234567 said: I normally paint my models with Vallejo Model Air paints as I have really come to enjoy their "feel" when brush painting. If you use Model Color you get more paint, as they need thinning. Model Air are a bit watery for brush work I find. HTH Link to comment Share on other sites More sharing options...
B0BY_1234567 Posted March 10 Author Share Posted March 10 Thank you all for the info! 1 Link to comment Share on other sites More sharing options...
Casey Posted March 10 Share Posted March 10 (edited) If you have trouble finding the entry with measurements matches, try thus link instead: Maybe I should extract it in a separate post one day since the original thread went into generic can of worms... Edited March 10 by Casey 1 Link to comment Share on other sites More sharing options...
B0BY_1234567 Posted March 10 Author Share Posted March 10 27 minutes ago, Casey said: If you have trouble finding the entry with measurements matches, try thus link instead: Maybe I should extract it in a separate post one day since the original thread went into generic can of worms... Thanks for doing the tedious work for all of us! I did some digging around and I found most of what I was looking for, but what VMA colour would you recommend for Ocean Grey, if any? Link to comment Share on other sites More sharing options...
Casey Posted March 10 Share Posted March 10 51 minutes ago, B0BY_1234567 said: Thanks for doing the tedious work for all of us! I did some digging around and I found most of what I was looking for, but what VMA colour would you recommend for Ocean Grey, if any? If I had no other choices than VMA, I'd use 71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629. It has a wrong tint and it is not that close (>3.0 DE) Link to comment Share on other sites More sharing options...
B0BY_1234567 Posted March 10 Author Share Posted March 10 5 minutes ago, Casey said: If I had no other choices than VMA, I'd use 71.273 | Ocean Gray | Gris Oceano | FS36176 | BS629. It has a wrong tint and it is not that close (>3.0 DE) Ok, thank you for the recommendation. I see that it is slightly off but it is still just about close enough for me. Thanks again! Link to comment Share on other sites More sharing options...
flyboy2610 Posted March 10 Share Posted March 10 7 hours ago, alt-92 said: It is a bit dark, but not like that pic shows. I do note that they say they brushpainted it, which in my experience tends to work less well. Spraying leaves a thinner coat so less 'dense'. Precisely. Brush paint is always going to give a more dense coat than spraying, hence the color looks darker. It also makes a difference what color primer is used. Painting over a black primer will give a different shade than painting over a gray primer than painting over a white primer, etc. Link to comment Share on other sites More sharing options...
Matthew1974 Posted March 11 Share Posted March 11 If you aren’t adverse to using Vallejo Model Color (I find they brush pretty well using a wet palette technique), I found this here: https://i.4pcdn.org/tg/1474297046471.pdf. On page 11, it recommends mixing two parts 70.905 and one part 70.991 for Medium Sea Grey. For Ocean Grey it recommends two parts 70.868, one part 70.900, & one part 70.904. I haven’t tried it so I can’t comment one way or the other on accuracy but maybe it’s worth a shot. To confuse the issue even more Vallejo Model Color does have a Medium Sea Grey (70.870) in its range. Link to comment Share on other sites More sharing options...
B0BY_1234567 Posted March 12 Author Share Posted March 12 7 hours ago, Matthew1974 said: If you aren’t adverse to using Vallejo Model Color (I find they brush pretty well using a wet palette technique), I found this here: https://i.4pcdn.org/tg/1474297046471.pdf. On page 11, it recommends mixing two parts 70.905 and one part 70.991 for Medium Sea Grey. For Ocean Grey it recommends two parts 70.868, one part 70.900, & one part 70.904. I haven’t tried it so I can’t comment one way or the other on accuracy but maybe it’s worth a shot. To confuse the issue even more Vallejo Model Color does have a Medium Sea Grey (70.870) in its range. Thank you for the extra help! Link to comment Share on other sites More sharing options...
