infofrog Posted January 1, 2015 Author Share Posted January 1, 2015 Little more update Here is more parts in primer Side arm and floaters . I'm not sure if this the proper name . If not ,Can some one correct me . I used a new airbrush primer . Badger Badger Primer Stynylez. I like it a lot . I added couple drop of water . Sprayed great , drys fast and sands great . This primer is not a filler . Thanks Rick The left side exhaust there a miss place hole . I relocated pipe to correct area Reference photo As you can see the side arm is installed below . Also in this reference photo . under this nose of this bird . There is a plate and not sure What this part is mounted to the plate is ( Annetta ) . The kit does not have it . There is a lot parts not in this kit .. 2 Link to comment Share on other sites More sharing options...
infofrog Posted January 1, 2015 Author Share Posted January 1, 2015 4 Link to comment Share on other sites More sharing options...
HOUSTON Posted January 2, 2015 Share Posted January 2, 2015 Info frog, She is coming along quite nicely. Good job. 1 Link to comment Share on other sites More sharing options...
hendie Posted January 2, 2015 Share Posted January 2, 2015 looking good Rick - you're quite the master modeler! 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 2, 2015 Author Share Posted January 2, 2015 looking good Rick - you're quite the master modeler! No I'm not .. I like building them out of the box . I like to keep it stress free and fun to do . But thank you Rick 1 Link to comment Share on other sites More sharing options...
georgeusa Posted January 2, 2015 Share Posted January 2, 2015 No I'm not .. I like building them out of the box . I like to keep it stress free and fun to do . But thank you Rick Have you noticed this is nowhere near out of the box; maybe outside of the box due to the great scratch building, but not OOB! 2 Link to comment Share on other sites More sharing options...
Dermo245 Posted January 2, 2015 Share Posted January 2, 2015 Great build Rick! Can I borrow some of your ideas when I try a 1/72 scale one soon? All the best, Dermot 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 3, 2015 Author Share Posted January 3, 2015 Great build Rick! Can I borrow some of your ideas when I try a 1/72 scale one soon? All the best, Dermot Yes you can . This shunkmodel is not the best kit .. Manual is poorly done . Rick I finishing under the nose . . Enjoy Rick Reference 2 Link to comment Share on other sites More sharing options...
infofrog Posted January 6, 2015 Author Share Posted January 6, 2015 I installed some Photo Etch . Then brushed on Black Primer to check rough areas Enjoy Rick Stynylrez Water Based Acrylic Polyurethane I'm working on relocating the exhaust pipe to correct area . 2 Link to comment Share on other sites More sharing options...
georgeusa Posted January 6, 2015 Share Posted January 6, 2015 Looks those primers work quite well! And, from the photos, the kit doesn't seem to have many glitches to fix before the paint is applied. 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 6, 2015 Author Share Posted January 6, 2015 The front doors , do not fit .. This is going be my down fall on this kit .. I was hoping to have it in primer this weekend . I don't think so . Those doors are going suck . Rick Those primers are for airbrush ready . I'm using the black primer to brush on , So I can see rough area . This primer dries fast The self leveling agent in these primers are not good for filling . I have Tamiya brush primer for filling heavy scratches . But takes hours to set up . Thats the down fall . But its good primer Link to comment Share on other sites More sharing options...
georgeusa Posted January 6, 2015 Share Posted January 6, 2015 I'm sure you will be able to get the doors to fit. I have confidence that a simple door will not defeat you. I also hate waiting for primers,paints and putties to dry. 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 8, 2015 Author Share Posted January 8, 2015 Today I notice out of the blue my build has round hole on right side from factory . Not sure what its for , maybe a different model build . I checked my reference photos, there is not panel with this round cut hole . Now I'm in process of filling the hole . Enjoy Rick Reference photo Here is photo with some photo etch at the wing . I brushed some primer on to set for problem areas. 1 Link to comment Share on other sites More sharing options...
georgeusa Posted January 9, 2015 Share Posted January 9, 2015 Looking good! Keep plugging away. I know this kit isn't the easiest to work with. 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 9, 2015 Author Share Posted January 9, 2015 Looking good! Keep plugging away. I know this kit isn't the easiest to work with. You are correct . The manual is worthless . Rick Today I'm working on building a front hood hinge from Photo etch scrape . Reference photo below Enjoy Rick Reference Here I trimmed small section from the photo etch to make the hinge . 1 Link to comment Share on other sites More sharing options...
phildagreek Posted January 9, 2015 Share Posted January 9, 2015 Looking good! Looks like you've got this one beaten. 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 9, 2015 Author Share Posted January 9, 2015 I finally installed the hinge on the front hood Enjoy Rick 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted January 9, 2015 Share Posted January 9, 2015 Looks good, nice work there Rick. Link to comment Share on other sites More sharing options...
infofrog Posted January 10, 2015 Author Share Posted January 10, 2015 I found out . That is not a hinge system . That is a water drip edges . Rick Link to comment Share on other sites More sharing options...
infofrog Posted January 13, 2015 Author Share Posted January 13, 2015 I finally glue front windshield into place .Does not fit good at all . Now its time to add tamiya putty to fill in gaps . Enjoy Rick 1 Link to comment Share on other sites More sharing options...
Nigel Heath Posted January 14, 2015 Share Posted January 14, 2015 Fine work there Rick. 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 14, 2015 Author Share Posted January 14, 2015 This will test me here . Its super hard . I'm frighten of screwing up the windshield .. May let this set for day . I will think about it . I started Humvee build . My wife got me a Humvee for Christmas . I really like it . http://www.britmodeller.com/forums/index.php?/topic/234974399-ricks-humvee-nato-build/ Rick Link to comment Share on other sites More sharing options...
georgeusa Posted January 14, 2015 Share Posted January 14, 2015 Just let the putty set and glue set for a day. That way everything will be in a set place and you will know where to go from there. You won't screw it up, I have confidence in you. Just take your time with it. I will take a look at your Humvee now. 1 Link to comment Share on other sites More sharing options...
infofrog Posted January 29, 2015 Author Share Posted January 29, 2015 Just let the putty set and glue set for a day. That way everything will be in a set place and you will know where to go from there. You won't screw it up, I have confidence in you. Just take your time with it. I will take a look at your Humvee now. note: This front window made me want throw this kit in the trash .. Thanks george , Thats what I did . Slowly worked it . Not perfect , but I need to move on . I hope when the paint comes , it will smooth out . I will see . Some updates . Front window and right door installed, brushed on some black primer . Added some Photo etch . Enjoy rick 1 Link to comment Share on other sites More sharing options...
hendie Posted January 29, 2015 Share Posted January 29, 2015 looking very nice Rick - I'm sure you'll beat the window into submission Link to comment Share on other sites More sharing options...
