My Entry, the Pfalz D.IIIa
Box and Sprue Shots:
Started by spraying all the wood bit's with Tamiya Buff paint, followed by a coat of Klear
While that was drying, I got out my punch set and some thin plasticard, and used it to make some bezels for the instruments.
Then drag some Burnt umber oil paint over the wooden surfaces with a stubbly brush, gradually removing paint and giving a wood grain effect (that's the theory anyway)
Then start assembling the cockpit, first the cockpit floor, rudder pedals and compass, complete with klear for the compass dial
Then the Starboard sidewall - oil pressure gauge, fuel pump and switches
Finally the main instrument panel
Then with the cockpit complete....
On with the engine - nice and simple, just painted Aluminium, Gunmetal and brass, and given a coat of Tensocrom Oil.
Buttoned up the fuselage
And finally for the day, fitted the lower wing, and put some Mr Surfacer 1000 over the fuselage seams and the joint with the lower wing. Nothing too bad, but then again, nothing that won't benefit from a cleanup either..
Peter
Lovely cockpit! I bet this is gonna look just great when finished.
Today's work on the Pfalz:
First the prop which was painted yesterday, but now has a coat of klear
The the preparation for the rigging later - adding the buckles. First what you will need, a pin vice with a 0.4mm drill and the model. Oh and some buckles - for this one i'm using my own but normally use Bobs Buckles.
You then drill holes where the buckles will be
Then the buckles - you need tweezers, the buckles, some image magnification and gel super glue.
Then you pick up the buckle with the tweezers, dip the end in the CA, and place in the hole
Repeat a few times -
At which point I ran out of buckles - fear not intrepid watchers, I made some more. To make your own you need a 0.4mm drill bit, 0.2mm copper wire, and some lockwire pliers
Mount the drill bit in a vice, drill point down
Bent the wire around the drill, grab with the pliers and spin gently - hey presto a buckle
Finished adding the buckles
masked the Cockpit and engine
Fitted the tail surfaces
Sprayed the underside of the wings silver and the rear white
Then sprayed the Red
Peter
Wonderful step by step.
Well done for the wood effect for the pit and the prop.
Watching with interest how you will do the rigging, with those buckles.
Cheers!
First off - Thanks to Bob who found me a photo of the mounting for the MG's.
Masked off the radiator on top wing
Then used my Dremel to thin a Cocktail stick to make cocking handles for the MG's
Drilled out the barrel, and added some holes, then painted gunmetal, and given a black oil wash. Also painted a length of Jammydog tape with canvas model color, to make ammo belts.
Sprayed the radiator Brass and unmasked
Weathered and darkened some parts with an oil wash
Then fitted the MG's and ammo belts, and painted the leather padding around the cockpit
Fitted the wings
Ready for the rigging now - the prerequisites - Rigging Elastic, CA Kicker, CA, Tweezers, Magnifier and cocktail sticks for applying the glue
First attach the rigging elastic to one buckle
Then pull through the other buckle and tension the elastic
Giving a nice tight line like this
Repeat a few times and you have a rigged biplane
The exhaust, sprayed with Model air rust, then some Alclad Hot Metal Blue for discolouration
Fitted the exhaust and a pipe for the radiator, made out of copper wire
Finally added the control horns, and the last bit's of rigging - all ready for decals tomorrow.
Peter
PETER: Very nice indeed, great WIP pics and narrative...! What an elegant design..!
WWI Cheers,
ggc
Superb, Loving this Pete. I'm no plane builder, but I always fancied a Pfalz, and always wandered what this kit is like. When I come to do one, I'll be using this as reference :)
Wow! You make the rigging look easy-peasy. I'll have to try that next time. So how does this CA Kicker work? I assume that it sets the CA instantly so you don't have to wait for it to cure?
Yes, makes this a lot easier to get tension in the wires
Peter,
I have just looked through this build and it was great to see how you carried out the rigging etc.
Well done mate.
Deacon
  • 3 weeks later...
