rkennerley Posted May 2, 2011 Posted May 2, 2011 my next one for the GB is this one from revell which will be done as the MS version i have got the box open and even though it looks like there is a lot of flash it is not really bad the only thing i am not liking is the raised panel lines
Peter Marshall Posted May 2, 2011 Posted May 2, 2011 Another interesting German flying boat to watch come together.
Ray S Posted May 2, 2011 Posted May 2, 2011 B+V did some quaint designs didn't they? I have never seen this one, so look forward to following this one! Good luck, Regards, Ray
rkennerley Posted May 6, 2011 Author Posted May 6, 2011 seems like i havent done much but have dona a fair amount i would have the body together but i messed up the turret luckily im am doing the MS which dose not have the rear turret so i an putting that together at the moment i dont know if i will have the crew in it yet just doing them so i have the option i have also started putting wings together no filler yet just a lot of flash to sand i did find the fit to the body to be rather bad but easy to fix,the front alignment pin on the wing is 2/3mm to low so when put together you end up with a large step so i have cut it off and drilled a hole in the right place and put the pin on the body because there is a nice sleeve to glue it into
rkennerley Posted May 7, 2011 Author Posted May 7, 2011 got the two halves together not for the filling and sanding and all them nice raised panel lines
rowmk9 Posted May 15, 2011 Posted May 15, 2011 Looks great, you're doing a top job so far. This flying boat looks very pretty. Remove the gun turrets and replace the engines with radials and it would make a beautiful civillian flying boat.
rkennerley Posted May 18, 2011 Author Posted May 18, 2011 finally got that paint on and i am really liking this plane and i will definitely be doing another at some stage to improve on this one because although it needs a lot of tlc the kit is not bad and i think with a re scribe of the panel lines it will be really good
Vulcanicity Posted May 21, 2011 Posted May 21, 2011 A fine build of a most handsome flying boat. I love the handling trolley, did that come as part of the kit?
rkennerley Posted May 21, 2011 Author Posted May 21, 2011 yes the handling trolley is part of the kit
Jasonb13 Posted May 22, 2011 Posted May 22, 2011 Just seen the pics in the finished thread, it looks great! I gotta ask, what's the large circle around most of the aircraft? J.
rkennerley Posted May 22, 2011 Author Posted May 22, 2011 no idea really i just did the Ms version to be different i think it is some sort of radar set up maybe??? perhaps someone out there can enlighten us further
wkennerley Posted May 22, 2011 Posted May 22, 2011 The MS variant was a minesweeper, the hoop is a degaussing device, creates a magnetic field that I believe caused havoc with the mines? Wayne
