Courageous Posted May 29, 2017 Posted May 29, 2017 Hi folks, As the likelihood of a new kit arriving for this bird in 1/72 are non-existent, I thought I'd start gathering reference for a future build. I have obtained the conversion process from the Airfix forum using Airfix DH4 kit(s) and now need help on producing the cockpit tub. I understand that the tub will have to be vacformed but have never done such a thing, no plans...nothing. Where do I start? I also have lots of photos of the Beardmore 120hp engine that I plan to scratch-build but I have no scale reference. Stuart
Paul Thompson Posted May 29, 2017 Posted May 29, 2017 The Formaplane vac is fairly easy to find at a reasonable price. The wings need a lot of work (it has grooves for ribs) but the nacelle is a good starting point. All the plans you could shake a stick at are in Windsock Datafile 18. Many useful photos in the later Datafile 147. Then there are also the Cross & Cockade book 'FE2b/d & variants in RFC, RAF, RNAS and AFC service, and for colour photos of an authentic modern repro there's 'The Fe2b Flies Again!', which like the datafiles is an Albatros publication. HTH. Paul.
GrzeM Posted May 29, 2017 Posted May 29, 2017 (edited) Aren't the wings and tailplane of the Fee identical with the BE2c? The nacelle (cockpit tub) is pretty easy to do from plastic card. Except the nose area even no vacuforming is necessary. Even more, you may replace pretty complex vacuforming with the simple crash-moulding: http://uamf.org.uk/viewtopic.php?t=4381 Edited June 2, 2017 by GrzeM
Courageous Posted May 30, 2017 Author Posted May 30, 2017 8 hours ago, Paul Thompson said: The Formaplane vac is fairly easy to find at a reasonable price. The wings need a lot of work (it has grooves for ribs) but the nacelle is a good starting point. All the plans you could shake a stick at are in Windsock Datafile 18. Many useful photos in the later Datafile 147. Then there are also the Cross & Cockade book 'FE2b/d & variants in RFC, RAF, RNAS and AFC service, and for colour photos of an authentic modern repro there's 'The Fe2b Flies Again!', which like the datafiles is an Albatros publication. HTH. Paul. Thanks Paul, I did know about these ref books but as I tend to build 'one-offs' of a type, I think they're an expensive option for me...we'll see. If the Formaplane is easy enough to find, it might be the case of getting it for the tub and bits and use the wings and stuff from the Airfix DH4? 8 hours ago, GrzeM said: Aren't the wings and tailplane of the Fee identical with the BE2c? The nacelle (cockpit tub) is pretty easy to do from plastic card. Except the nose area even no vacuforming is not necessary. Even more, you may replace pretty complex vacuforming with the simple crash-moulding: http://uamf.org.uk/viewtopic.php?t=4381 I couldn't tell you if the FE2B has identical parts to a BE2C but I'll take a look at 'crash moulding'. Thanks Guys, Stuart
Paul Thompson Posted May 30, 2017 Posted May 30, 2017 20 minutes ago, Courageous said: Thanks Paul, I did know about these ref books but as I tend to build 'one-offs' of a type, I think they're an expensive option for me...we'll see. If the Formaplane is easy enough to find, it might be the case of getting it for the tub and bits and use the wings and stuff from the Airfix DH4? Should work. There are plans with the Formaplane kit but they're quite old and may not be currently regarded as all that accurate, but they are very informative. If you can't find the kit I can scan them for you (assuming I can locate them in the stash). Paul.
GrzeM Posted May 30, 2017 Posted May 30, 2017 2 hours ago, Courageous said: I couldn't tell you if the FE2B has identical parts to a BE2C That was a hint The wings are identical, so you can use wings from new Airfix BE 2c! The tailplane may be identical too, maybe the propeller, machine gun... 1
Courageous Posted May 30, 2017 Author Posted May 30, 2017 4 hours ago, Paul Thompson said: Should work. There are plans with the Formaplane kit but they're quite old and may not be currently regarded as all that accurate, but they are very informative. If you can't find the kit I can scan them for you (assuming I can locate them in the stash). Paul. Paul, I'll keep an eye out for the Formaplane and I'll keep your offer in mind if nothing appears. 2 hours ago, GrzeM said: That was a hint The wings are identical, so you can use wings from new Airfix BE 2c! The tailplane may be identical too, maybe the propeller, machine gun... Mmm...not sure about the wings; Wiki put the FE2B wingspan at 14.55 m, BE2C at 11.28 m and the DH4 at 13.21 m?
GrzeM Posted May 31, 2017 Posted May 31, 2017 22 hours ago, Courageous said: Mmm...not sure about the wings; Wiki put the FE2B wingspan at 14.55 m, BE2C at 11.28 m and the DH4 at 13.21 m? FE 2B has the wingspan extended by adding center section between the standard BE 2c wing panels. It is literally stated in FE 2B Windsock Datafile. Also you can see that on the plans of the two airplanes. In my opinion this is easiest way to build good FE 2B model.
Courageous Posted May 31, 2017 Author Posted May 31, 2017 11 hours ago, GrzeM said: FE 2B has the wingspan extended by adding center section between the standard BE 2c wing panels. It is literally stated in FE 2B Windsock Datafile. Also you can see that on the plans of the two airplanes. In my opinion this is easiest way to build good FE 2B model. Looks like both BE2C and DH4 kits will be useful with the Formaplane tub. 1
pheonix Posted June 2, 2017 Posted June 2, 2017 As the author of the ATF article on the FE 2 conversion that you alluded to I can assure you that if I were to do it again I would use BE 2C wings: you will need two kits so that you can make the centre sections. Alternatively build the centre-section from plastic card as I did. The struts, wheels, probably the prop, guns could all come from the BE 2 kits. The nacelle is easy to plunge mould (as I did) and the Beardmore can be scratched - look up the WNW site or Viking's build of the WNW kit on this site - I used his photographs to help me. The drawings in the Albatros publications are very good. If you want any further help/advice just pm me and I will try to help. P 2
Courageous Posted June 2, 2017 Author Posted June 2, 2017 1 hour ago, pheonix said: As the author of the ATF article on the FE 2 conversion that you alluded to I can assure you that if I were to do it again I would use BE 2C wings: you will need two kits so that you can make the centre sections. Alternatively build the centre-section from plastic card as I did. The struts, wheels, probably the prop, guns could all come from the BE 2 kits. The nacelle is easy to plunge mould (as I did) and the Beardmore can be scratched - look up the WNW site or Viking's build of the WNW kit on this site - I used his photographs to help me. The drawings in the Albatros publications are very good. If you want any further help/advice just pm me and I will try to help. P Hi P, thanks for the input as being the author and I will certainly pm you when I'm closer to the build. I haven't had much need to do anythig with plunge moulding so it would be very new to me but if needs must... Scratch building the Beardmore engine sounds interesting and hopefully the reference you suggest should help. Stuart
GrzeM Posted June 2, 2017 Posted June 2, 2017 What an interesting topic! Pheonix, could you post here some pictures of your model, or point us where we can see it? All the best! Grzegorz 1
Courageous Posted June 3, 2017 Author Posted June 3, 2017 10 hours ago, GrzeM said: What an interesting topic! Pheonix, could you post here some pictures of your model, or point us where we can see it? All the best! Grzegorz WingNutWings FE2B Viking's FE2B RIP Between the two, one should be able to build the Beardmore engine, all we need is a scale? Stuart
pheonix Posted June 3, 2017 Posted June 3, 2017 9 hours ago, Courageous said: WingNutWings FE2B Viking's FE2B RIP Between the two, one should be able to build the Beardmore engine, all we need is a scale? Stuart You can find a scale drawing of the engine in DataFile No 147 FE 2b at War. I will post some photos of my completed build on this site shortly, (I have to load the images first as Photobucket has terminally fallen over for me). There is a build log on ww1aircraftmodels.com under scratchbuilds and in ATF under conversion corner. Unfortuneatley the photos are not as good as they may have been because the close-up system was not working properly on my camera at the time.
stevehed Posted June 3, 2017 Posted June 3, 2017 Hi Stuart, I built the Formaplane FE2b last year and found it a pleasant build. Here's the build thread. http://airfixtributeforum.myfastforum.org/viewtopic.php?f=78&t=48847 http://airfixtributeforum.myfastforum.org/viewtopic.php?f=80&t=39957 And the ATF article referred to by Phoenix. Regards, Steve
Courageous Posted June 3, 2017 Author Posted June 3, 2017 10 hours ago, pheonix said: You can find a scale drawing of the engine in DataFile No 147 FE 2b at War. I will post some photos of my completed build on this site shortly, (I have to load the images first as Photobucket has terminally fallen over for me). There is a build log on ww1aircraftmodels.com under scratchbuilds and in ATF under conversion corner. Unfortuneatley the photos are not as good as they may have been because the close-up system was not working properly on my camera at the time. I must confess that reference material is my weakness, I'm not one for spending lots of money on a book for one build. I wasn't aware of the the dedicated WW1 site you stated and looks rather interesting. 5 hours ago, stevehed said: Hi Stuart, I built the Formaplane FE2b last year and found it a pleasant build. Here's the build thread. http://airfixtributeforum.myfastforum.org/viewtopic.php?f=78&t=48847 http://airfixtributeforum.myfastforum.org/viewtopic.php?f=80&t=39957 And the ATF article referred to by Phoenix. Regards, Steve An interesting Formaplane build Steve.
pheonix Posted June 4, 2017 Posted June 4, 2017 I have put up some photos of the completed model and engine in the ready for inspection section. P 2
Brandy Posted June 10, 2017 Posted June 10, 2017 I think I may have a duplicate of the vac FE2b kit in my stash. Let me know if you're interested and I'll double check. Ian
