Maxus Posted June 15, 2011 Posted June 15, 2011 Hi, about to try out Klear for the first time and a little unsure what to use to clean up the airbrush - advice please. Cheers.
kev67 Posted June 15, 2011 Posted June 15, 2011 Klear as I know has a Acrylic base to it, so should clean ok with warm water but I also use Lifecolor airbrush cleaner as well, you can use other similar airbrush cleaners
Jetblast Posted June 15, 2011 Posted June 15, 2011 Most stronger solvents will work a treat, but just make certain that you don't leave your brush for any length of time before giving it a good clean!
grayh Posted June 15, 2011 Posted June 15, 2011 I Just use water with a bit of tamiya acrylic thinner in , Works fine but as stated in previous dont let your brush stand uncleaned
stevehnz Posted June 15, 2011 Posted June 15, 2011 If you do suffer from Klear drying on a brush, you can fix it by soaking it in a household ammonia cleaner. Steve.
Doug Rogers Posted June 15, 2011 Posted June 15, 2011 I use warm 'soapy' water, followed by a blow through with a drop of white spirit. Seems to do the job OK.
Andy Mullen Posted June 16, 2011 Posted June 16, 2011 I have a bottle of Ammonia I picked up from my local cash & carry ages ago. I have a 1oz bottle I put a few drops of Ammonia in and then fill the rest with water. When I have finished spraying Klear, I attach the bottle and spray through the brush for a few seconds. Cleans it out nicely.
