reini Posted January 15 Share Posted January 15 I've done a 1:48 Stuka a while a go but I wanted to do one in my preferred scale which is 1:72. And I specifically wanted to do the 'cannon bird' with the big underwing mounted cannons. So let's get a kit (Academy in this case) and build it - and we're done. Easy, right? Simple 1:72 kit with couple of sprues. How hard can it be? Maybe get a mask set, that will make things even easier. So we get few extras to correct or spruce things up. Okay it might complicate things a bit... ...oh right so we start to hack'n'slash the fuselage in pieces and carve out the existing cockpit details and install a new one - which I guarantee will not fit - and build up new cannons from a random pile of super thin resin bits and throw in some metal barrels just in case. I'm not sure yet but this might be the hard part of the build. 😬 Oh and the best part, deadline is 24th of February, hoping to attend a modelling show with this build. Oh and I still have to get some decals, Wish me luck! 7 2 1 Link to comment Share on other sites More sharing options...
billn53 Posted January 15 Share Posted January 15 Yes, that’s exactly how I do an easy build! 2 Link to comment Share on other sites More sharing options...
François Escudé Posted January 15 Share Posted January 15 Hi Reini, amazing for me as I have exactly the same elements you're showing !! Will follow your build with more than interest ...😀 whish you all the best of course ! François 1 Link to comment Share on other sites More sharing options...
reini Posted January 16 Author Share Posted January 16 9 hours ago, François Escudé said: Hi Reini, amazing for me as I have exactly the same elements you're showing !! Will follow your build with more than interest ...😀 whish you all the best of course ! François Cool Thank you! This is the pile of plastic that I will be replacing... ...with this pile of resin, PE & plastic film. It is encouraging that the floor slotted right in. If I would have wanted, I could have used just the floor with no modifications. But I wanted the side panels too of course so some plastic scraping, sanding & sawing ensued. It's not perfect yet but it's getting pretty close Still need to thin the side panels down a bit to get a nicer fit. But in general, everything closes down so there are enough room for the parts. Have not test fitted the instrument panel yet. I need to adjust the side panels a bit, they are bit high on the back. 11 Link to comment Share on other sites More sharing options...
ColinChipmunkfan Posted January 16 Share Posted January 16 This looks a really interesting build. Looking forward to the next installment. 1 Link to comment Share on other sites More sharing options...
neil5208 Posted January 16 Share Posted January 16 Good start, I did this kit a few years back with just the prop correction set you have. 1 Link to comment Share on other sites More sharing options...
reini Posted January 21 Author Share Posted January 21 Drilling out the... well, I'm not quite sure what this is? Somekind of antenna? It will be under glass just behind canopy. I've seen other Luftwaffe planes with similar contraption, He 219 for example. Gluing down the cockpit side panels with superglue. The fit was good, I just needed to sand out little bit from the cockpit floor so it sits down a little bit lower than initially - then the side panels line up nicely. We can start adding the details. Like these rudder pedals. I mean what. 1/72 scale rudder pedals which you build out of seven parts of resin & folded PE. Yeah I'm gonna do it (try it atleast!) but I have a feeling I'm not gonna like it... That will have to wait until next time, though. This is where I am at. I was kinda hoping to get the primer on but still plenty of PE work to do. Pedals, instrument panel, lots of tiny levers, seatbelts & back seat. Oh, and the machine gun with PE sights and all! 2 Link to comment Share on other sites More sharing options...
Graham Boak Posted January 21 Share Posted January 21 I think it is the master compass. Perhaps most obvious on Ju.88s. 1 Link to comment Share on other sites More sharing options...
Gondor44 Posted January 21 Share Posted January 21 Looking at the refference book I have on Ju 87's, it's a Peil G.IV D/F loop and was positioned there from the D-1 versions onwards. Gondor 2 1 Link to comment Share on other sites More sharing options...
reini Posted January 27 Author Share Posted January 27 Okay, the rudder pedals. They come with a separate link arm or something and a nice resin axle. Too bad that the axle is just too big and the PE parts wont fit into it 😶 I got simplified version of the pedals done, just barely. I left out some PE parts and replaced the axle with a styrene rod. They are bit wonky but they will do... I was pretty close at squishing the whole setup under my thumb But seriously. This is just silly? Who on earth will put all those levers inside the cockpit? That is just crazy stuff. I just threw in couple of levers so that it will look that it has something. But I have no confidence that they will stay there during the painting process. Seats are done too. So is rest of the cockpit. Just need the gun now but I noticed that I was missing barrels... Ugh. I will sort it out later and prime the cockpit. 6 Link to comment Share on other sites More sharing options...
