Breaker Posted April 13, 2016 Author Share Posted April 13, 2016 René, I've just had a conversation with the current owner. Those decals are really old (1998 vintage potentially!) so might be a bit suspect. If you could scan the sheets and send me a copy, i'd appreciate it greatly! Link to comment Share on other sites More sharing options...
mcdonnell Posted April 13, 2016 Share Posted April 13, 2016 (edited) Hello,Breaker - You've made a magnificent job of this build and I'm so sorry that you've hit this snag.Dare I ask what Paint and Decal Solution System you used? I use Xtracolor Enamel > Johnsons Klear > Decal Application with MicroSet and MicroSol > Johnsons Klear and finally Xtracolor Enamel Varnish. I've often found,for example,that Xtradecal Stripe is a tough cookie to deal with around more curved areas and has needed a few shots of the MicroSol before it would behave.Johnsons Klear can also give that little extra 'pull' if need be. Wishing you restored success with this build. All the very best,Paul. Edited April 13, 2016 by mcdonnell Link to comment Share on other sites More sharing options...
Blacktjet Posted April 13, 2016 Share Posted April 13, 2016 So I can't recommend CAM decals at all. They don't seem to be able to conform to compound curves at all and any attempt to manipulate them results in them snapping. I've followed the directions to the letter provided by CAM. They confirm lovely where there's only a slight curve like the main body of the external tank or the cockpit sidewalls but as soon as you throw the tapering areas in such as the nose or the tip of the tank, they won't bend and just break. Not happy at all as this will leave me right in limbo. Having to consider masking and spraying all of the main markings now which will add so many more hours onto this build! I had the same problem with the 1/72 scale version of these decals, I found that the only way I could get then to bed down onto compound curves was to give the decal a light spray with Humbrol acrylic satin varnish spray. A light spray softens the decal and bonds it to the paint - a very light spray! 1 Link to comment Share on other sites More sharing options...
Gary West Posted April 13, 2016 Share Posted April 13, 2016 Thats seriously crap, I hope it doesnt make you put the project down Link to comment Share on other sites More sharing options...
Caerbannog Posted April 14, 2016 Share Posted April 14, 2016 (edited) René, I've just had a conversation with the current owner. Those decals are really old (1998 vintage potentially!) so might be a bit suspect. If you could scan the sheets and send me a copy, i'd appreciate it greatly! I will try to do so tonight and send you a PM with a link to my dropbox where I will save the scan to. I suppose attaching a file to a PM will not work here and the Dropbox will not complain about file size either. Any preferences regarding resolution? I usually scan my decals with 600 dpi. By the way - I use Mr Mark Softener which works great on most stuborn decals that I ever had the "joy" to meet - including those awful decals which Italeri had in the eighties and nineties. Only Roden decals for a Junkers J1 were completely unimpressed. René Edit: PM sent with link Edited April 15, 2016 by Caerbannog Link to comment Share on other sites More sharing options...
