A superb build of this Beagle bomber ! She looks great and the replica of this solid and long-serving Russian craft is presented wonderfully here in your images.
Mike
Finally i am online and what do i see?!
Very well build and finished model of a Beagle!!
I like it very much! I like that it is big and i like it in metal finish worn and weathered just enough!
And most of all i have enjoyed in-progress build full of interesting and useful tips for those like me who are hoping to start building this model.
Thank you IPMS19! :). Well done!
  • 6 months later...
wow! great finished model!
just found it now... searching for information on the kit and different markings....
cheers, Werner
Really looking very good your 28th! :thumbsup:
Edited by IGKent
cheers, Werner
-Hallo Werner
- This kit is wonderful generaly speaking, but as always there is some drawback.
- To my sense the worst is the notice.It is on a dvd, that is not a problem, but the different steps of the building are made of photograph wich are not of the best quality, that obliges the builder to some guess work for a lot of assembly steps of this rather complicated model which is far from ideal
- Another problem is the thinness of the resin on the fuselage spine , the only way to cure this is to reinforce the cementing joint by a plastic strip running from the rear canopy fairing to the fin base ( I have neglected this point so I had to reinforce over the upper fuselage halves once cemented with adhesive metal foil )
- Another difficulty comes from the air intakes rings of the engines.the engines nacelles are in two halves from exhaust to intake this requires a carefull fitting and a few putty at the leading edge ring; an entirely molded nose ring should have been the best solution
- The tyres are in two halves whitout any scribbing which rather unfair in rergard of the overall quality ( and cost )of this kit.
- You may find a lot of camo scheme on the web the main problem is to find the right shade of the colors required so I elected to rely on the bare metal scheme
-Happy modelling and send us photo once finished
-; J.M
