IPMS19 Posted May 15, 2013 Share Posted May 15, 2013 -This is at last finished the Beagle I've shown the building in WIP Aicraft. - As usual the scale is in 48;. The whole model is in resin ; It is a mixture of good things and others not exactly bad buT which could be bettered - The resin is thin but strong, the detail level is high and accurate.The thinly engraved panels and rivets are very realist . -A metallic spar is moulded inside the wings which prevent them from bending and the landing struts are reinforced with metal rods. - The clear parts are in very clear resin. - On the other end there are some parts which could have been bettered;That make the difference between a good model and and excellent one. - First , the notice is difficult to use, it has to be printed from a dvd ,the different steps are shown in photos not very neat and difficult to exploit mostly for the smallest parts; The intakes should have been much more easy to install and realist if they had been presented in a ring to be added at the front of the nacelle, the tyres are untreaded and the forward landing gear strut is too long. -The joint between the fuselage halves has to be reinforced from the inside and some putty is required.; But let's see the photos/ -Ive used Alclad dull aluminium for the darkest areas and rub'n buff for the brightest,ones, the weathering is made of Tamiya pastels together with Mig pigments 4 Link to comment Share on other sites More sharing options...
HL-10 Posted May 15, 2013 Share Posted May 15, 2013 That is very nice! You've done your usual great job Link to comment Share on other sites More sharing options...
nicE1 Posted May 15, 2013 Share Posted May 15, 2013 Really nice Link to comment Share on other sites More sharing options...
glyn Posted May 15, 2013 Share Posted May 15, 2013 another cracking build on here. glyn Link to comment Share on other sites More sharing options...
colin Posted May 15, 2013 Share Posted May 15, 2013 Very nice Link to comment Share on other sites More sharing options...
John_W Posted May 15, 2013 Share Posted May 15, 2013 Thats beautiful. Link to comment Share on other sites More sharing options...
seadog Posted May 15, 2013 Share Posted May 15, 2013 Looks brilliant, and in far better nick than the one I saw in the flesh in the Czech Republic! Link to comment Share on other sites More sharing options...
Tiger331 Posted May 15, 2013 Share Posted May 15, 2013 Very nice......I've been watching progress with this in the WIP Section for a while but was away for two weeks on business and took my eye off the ball and kinda lost track. Having 'invested' (and I mean that quite sincerely !) in one of these kits last month I'm keen to start work so your RFI has provided real inspiration. Thanks for sharing it with us Mark 1 Link to comment Share on other sites More sharing options...
F-32 Posted May 15, 2013 Share Posted May 15, 2013 I really like that, I've always thought it was an interesting design 1 Link to comment Share on other sites More sharing options...
russ c Posted May 15, 2013 Share Posted May 15, 2013 Fantastic job, Really Nice Well done !! Link to comment Share on other sites More sharing options...
jimbuna Posted May 15, 2013 Share Posted May 15, 2013 A great looking blast from the past. Link to comment Share on other sites More sharing options...
llking Posted May 15, 2013 Share Posted May 15, 2013 awesome job, weathering looks great Link to comment Share on other sites More sharing options...
Dave N Posted May 15, 2013 Share Posted May 15, 2013 You really managed to get a sense of realism with your painting.Thanks for sharing. 1 Link to comment Share on other sites More sharing options...
Amo Aero Posted May 15, 2013 Share Posted May 15, 2013 You have created a superb model of the Beagle! The NMF finish is very realistic. I have one of these kits in the stash and your "in progress" build will be referred to when I finally get around to building. Thanks so much for taking the time and trouble to take photos and add your notes, and then to post it all here! 1 Link to comment Share on other sites More sharing options...
JOCKNEY Posted May 15, 2013 Share Posted May 15, 2013 Stunning example Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted May 16, 2013 Share Posted May 16, 2013 Very nice paintwork Link to comment Share on other sites More sharing options...
IPMS19 Posted May 16, 2013 Author Share Posted May 16, 2013 Very nice......I've been watching progress with this in the WIP Section for a while but was away for two weeks on business and took my eye off the ball and kinda lost track. Having 'invested' (and I mean that quite sincerely !) in one of these kits last month I'm keen to start work so your RFI has provided real inspiration. Thanks for sharing it with us Mark - I will be happy to see your model just be sure to strengthen the inside dorsal spine as the jointure of the halves requires a few cyano resin' putty ' the lack of thickness make the sanding difficult ,(for the less, it was the case on my exemplary).to the extent that as I didn't took the measure of this, I had to use adhesive aluminium foil externally to reinforce the top fuselage. Link to comment Share on other sites More sharing options...
Paul A H Posted May 16, 2013 Share Posted May 16, 2013 Superb finish, thanks for posting Link to comment Share on other sites More sharing options...
Josip Posted May 16, 2013 Share Posted May 16, 2013 I have just two negative remarks. 1. This plane is big and in 1:48 it's even bigger and being in NMF makes it kinda dull to my eyes. 2. You should allign the barrels of the tail cannon Otherwise it's a great model of a seldom seen bomber. Josip Link to comment Share on other sites More sharing options...
IPMS19 Posted May 16, 2013 Author Share Posted May 16, 2013 I have just two negative remarks. 1. This plane is big and in 1:48 it's even bigger and being in NMF makes it kinda dull to my eyes. 2. You should allign the barrels of the tail cannon Otherwise it's a great model of a seldom seen bomber. Josip - For the step one: I 'm not guilty for this... - Step two : You're right.....I didn'nt noticed it .Soon to be corrected Link to comment Share on other sites More sharing options...
colin Posted May 16, 2013 Share Posted May 16, 2013 Very nice build of a difficult kit,certainly not one I'd contemplate building.I'll wait for Trumpy' to do one and accept the little wrongs with it . NMF looks great,when did you see any Soviet nmf that were polished. 1 Link to comment Share on other sites More sharing options...
stevej60 Posted May 16, 2013 Share Posted May 16, 2013 Lovely build and superb finish. Link to comment Share on other sites More sharing options...
DaveH Posted May 16, 2013 Share Posted May 16, 2013 Damn good, looks very, very nice....... Dave Link to comment Share on other sites More sharing options...
snapper_city Posted May 16, 2013 Share Posted May 16, 2013 Looks great finished. Link to comment Share on other sites More sharing options...
Val Posted May 16, 2013 Share Posted May 16, 2013 Wow that's a great model, loved the weathered metal finish, brilliant! 1 Link to comment Share on other sites More sharing options...
