In 1970 cadets and staff of 2393 squadron excavated a Bf110 in Billericay Essex and the OS map is TQ69 and this became the title of the project.
On Sep 7th 1940 Gerhard Granz and his gunner Willi Schuttle escorted some Do17s on a mission to bomb London. They were intercepted by the Big Wing lead by Douglas Bader. Bader's wingman was Sub Lt Richard Cork flying Hurricane LE O L and he had a dofight with Granz's 110 3M+BB bothe aircaft were damaged but Cork returned to base. Granz and Schuttle escaped by papachute and were captured by the home guard.
Thirty years later, now Col, Granz returned to Essex to pick up the reduction gear and propellor blade of his aircraft and returned it to Germany where it was displayed at the helicopter school commanded by Granz.
My build will be a diorama of the aircraft involved in 144 scale. The 110 is a Japanese capsule model, deconstruted and reassembeled and the Sweet Hurricane.
Regards
David
A 144th scale dio, that's nice!
:cheers:
Azgaron
Here is some progress from last night's work. The gun bay has been cut out and the guns, from Oz Mods, mounted.
From the spares box comes Andy the Armourer - I think he contributes to this site!
I changed the 110 donor kit and used the green one in this spectacularly boring shot you should see the control column, the instrumnet panel and gun sight - but as ints only about 1/3 of an inch its asking a lot of the camera!
I'll need to smooth the nose cone in this evening.
Regards
David
Good to see some 1/144 stuff that isn't an airliner.
Curious at seeing the Hurricane all in clear though.
Sweet give you two kits in one, each has 2 canopies and foor landing lights on the sprues - but 1 model is grey or green plastic and the other in clear. I am using the clear one for this build to better show off the navigation lights.
The model will be depicted refuelling so here is the Bowser.
Its the size of a 2p piece
Regards
David
Today’s update shows some progress on the cockpit area of the 110. I have added the magazines for the cannon and the third seat as well as the radio gear.
The Hurricanes have the instrument panels prepared and the seats from Aeroclub painted.
The machine guns have been painted ready to be added to the starboard wing.
Interviews were held last night and some of the characters have been identified. Don't forgrt these are about 1 cm high!
Tonight will see the interior of the Hurricanes completed
Regards
David
Very nice work David! Looking mighty fine!
:cheers:
Azgaron
A little more progress, the Bf110 has hac its undersides painted Hell Blau and a mist coat of green. I usually use rattle cans but for this project I've dug out the airbrush.
Here it is closer - remember the span is less than 3"!
And from the other side
The Hurricanes are a slower they are shown here in primer to show up the work still required on the joins.
I use the tops of food containers from the local chinese take away to help stopping little parts flying away.
More tomorrow,
Regards
David
The 110 is now been throughthe paint shop and is shown before the last residues of Blu tac have been taken off.
Here is a close up of the cockpit
Meanwhile the Hurricanes have been filled and the sky undersides painted
To avoid the what colour are the undercarriage bays - here is one in silver and one in green!
Regards and thanks for all your comments
David
Here are the Hurricanes fresh from the paintshop.
I use blu tack as it allows a tiny bit of feathering
But getting some of the bits off afterwards are a bit of a pain.
Next time will be decal time.
Regards
David
A lot of progress last night. The decals, from CanMilAir, for Bader's aircraft have been applied as have those for Cork's LEL.
The main markings for Granz's 110 have also gone on - a mixture of Myk decals and Aeroclub letters.
I have tried placing the models in position for the diorama.
Regards
David
Thanks Mish
A little more progress last night, the models are all on their wheels although I'm not happy with the stance of the 110. The base has been painted and the grass added. The dispersal hut is in the paint shop. The iron crosses are from Myk decals and the carrier film is on top of the print as this was removed with sticky tape.
Regards
David
Last night the Hurricanes had a spray of matt varnish and the codes for the 110 added. I have put on the backgrounds for the 110's badges. The small blob will have a black hand on it and the larger has a clown figure to go on it.
I have been looking at the layout for the diorama
The Hurricanes will be weathered tonight and as I messed up the starboard prop of the 110 I need to make a new one.
Regards
David
  • 4 weeks later...
Well here are the finishing touches,
This is an overview of the diorama with a scapel for scale.
The 110 is in Brugues, France and will take off about 15.00 hrs and will meet 242 squadron over Esssex
The crew of Lt Granz and Corporal Schutle have their photo taken before the op.
Here is the scene reproduced.
At Duxford 242 squadron are at readyness
The lead section will be Bader, Crowley Milling and Sub Lt Cork
Cork's aircraft is being refuelled and rearmed.
The aircarft will clash over Hornchurch and will end with Granz's 110 crashing in Billericay and it will be excavated 30 years later by the local ATC sqn
Regards
David
Here are the pictures of my diorama depicting the events of the afternoon of 7th September 1940 with a section of Hurricanes from 242 Sqn lead by Douglas Bader intecepted a raid over Hornchurch. In the ensuing dogfight Bader's wingman, Richard Cook, shot down a Bf110 piloted by Lt Gerhard Granz. 30 years later Air Cadets of Billericay Squadron dug up the remains of the 110.
The diorama is based on actual photos of the 110 concerned.
Here is Cork's aircraft
And an overview of the entire Diorama
The knife gives scale to the models
The model Hurricanes are the Sweet 1/144 scale, the 110 is a japanese capsule model rebuilt, figures are a mix of 'MiniFigs' and prieser railroad people. The Bowser is by Matador models and the trolley acc is by Pavla. There is an etched metal bicycle leaning on the fence and that is a model rail accessory.
Regards
David
