Hardtarget Posted April 3, 2012 Posted April 3, 2012 (edited) I shall be building the home islands & malta boxing of the special hobby kit. She comes with PE and resin so will be a multi material build. Edited April 3, 2012 by Hardtarget
Test Graham Posted April 3, 2012 Posted April 3, 2012 I find the engine cowlings oversized, certainly the P&W ones on the Mk.II. Red Roo used to sell replacement cowlings from Ron's Resins, but I think they are sold out now. The P&W engines also need the pushrods - a very annoying habit of MPM on all their engines. Fortunately, the Taurus don't.
maltadefender Posted April 4, 2012 Posted April 4, 2012 Splendid stuff Hardtarget, much too fiddly for me I shall watch with envy!
Hardtarget Posted April 7, 2012 Author Posted April 7, 2012 Made a start on the beau. Tackling the cockpit area requires the use of the PUR and IM parts. The PUR parts are very brittle and dont want to come off their mouldings very easily. After some prising with the scalpel and saw they were free and glued into place with some zap. This is the base of the turret which comprised of 3 PUR parts, the base, seat and seat bracket. Bit fidilly especially when superglue is involved. Next up the cementing of the bomb bay into place. This needs to be done before the front seat as if done the otherway aruond you may not get the bay into its proper place. Note there is no locating slots. Cementing of the blanking plate and the PUR front seat followed. Next the airbrush was loaded with some hu78 interior green and duly applied to the cockpit, fuselage halves and the window areas. Next up will be the detailing of the cockpit area.
maltadefender Posted April 7, 2012 Posted April 7, 2012 Those resin parts look like a minefield HT. Congratulations on getting through unscathed!
Peter Lloyd Posted April 8, 2012 Posted April 8, 2012 Good on you. I gave up on mine in the home stretch, so I'm enjoying your build.
philp Posted April 19, 2012 Posted April 19, 2012 Very cool, loved the bits in Torpedo Bomber and have wanted to do one of these for a while.
Hardtarget Posted April 29, 2012 Author Posted April 29, 2012 (edited) Some progress on thie interior. And on the resin engines. Edited April 29, 2012 by Hardtarget
Hardtarget Posted May 7, 2012 Author Posted May 7, 2012 Some small progress on this aircraft as my time has been taken up with the making of the F-16's. I was on a roll but there was a small pause in waiting for them to dry so moved onto the beaufort. I managed to sort out the engines and cementing them in place to the cowlings. Tight fit this. Affixed the gun turret together with the windo cut out (what a pain in the bottom this is). And finally cemented the wings and tail seaction together. Fuselage at this stage is not cemented as i have to construct the turret first as she wopnt fix later on. I might even pain the fuselage halves at this stage, not sure yet.
Peter Lloyd Posted May 8, 2012 Posted May 8, 2012 Good progress mate, keep it up. I'm eyeing mine off (I left the turret off and assembled, I also left out one of the 'porthole' windows) for a possible unofficial contribution to the GB, but the smart money says I'll leave it on the shelf where it's sat happily for years. But I do get the vicarious enjoyment of seeing yours go together.
maltadefender Posted May 8, 2012 Posted May 8, 2012 In for the long game, HT. I think it's going to be worth the persistence - and the F16s!
Hardtarget Posted May 8, 2012 Author Posted May 8, 2012 Hopefully. Got a few builds on at the mo so its busy time. Dont worry she will get some modelling time as im hoping to follow this up with the SH Baltimore aswell.
Hardtarget Posted May 15, 2012 Author Posted May 15, 2012 Midweek update. After playing about with the turret and housing, i managed to make it fit in its little pit and also got the fuselague halves to cement together. With a little persuasion with the clips the fuselage was set. Next I masked the turret and also added the glass front end ready for painting later by hand as I didnt fancy masking all those windows. Also at this stage i added the radiators and exhausts. Engines were plugged with sponge and also masking of the glass section prior to spraying a mix of hu102 and some gloy dark slate grey (one was too green one was too grey). And ive just literally applied the EDSG hu123. She will dry now ready for tomorrow spraying of azure to add a bit of colour.
maltadefender Posted May 17, 2012 Posted May 17, 2012 Lovely stuff - and Azure Blue too! My favourite!
Hardtarget Posted May 17, 2012 Author Posted May 17, 2012 As promised, i sprayed the azure blue on yesterday and today as i got in went straight onto the framing. I think she is now ready for her legs.
Killingholme Posted May 18, 2012 Posted May 18, 2012 Hello, this is beginning to look rather nice indeed. Is your framing painted decal? Will
Hardtarget Posted May 18, 2012 Author Posted May 18, 2012 Hi Will, no hand painted on using a 4/0 brush.
Hardtarget Posted May 20, 2012 Author Posted May 20, 2012 Final stretches now. Undercarrige fitted Then I realised that i needed to fix the front guns before the canopy so cut around the canopy and duly drilled two small hole into it so the guns can fit snugly. Canopy recemented, tires sprayed, props sprayed & aerials also added at this point ready for a good old coat of klear. She is now ready for decals and the fiddily antennae.
Hardtarget Posted May 28, 2012 Author Posted May 28, 2012 Getting closer to the finish with the assembly of the torpedo. The PE is a bit fidely but I prevailed and it doesnt look too bad.
dogsbody Posted May 28, 2012 Posted May 28, 2012 Before you put the props on, the engines gear casings should be painted black. Either a flat or a semi-gloss will do. Chris
maltadefender Posted May 30, 2012 Posted May 30, 2012 Really nice and rugged HT - like this one a lot.
Hardtarget Posted June 24, 2012 Author Posted June 24, 2012 (edited) Took a bit of time to complete her, with getting the decals on, adding aerial wire and weathering/exhaust stains but im declaring her finished. Kit: Special Hobby 72083 Scale: 1/72 Scheme: Beaufort Mk.Ia DD959 (Q) 217Sqd, RAF Luka, Malta 1942, She was shot down by a Ju88 on the 20th June 1942. Edited June 24, 2012 by Hardtarget 1
