Thom216    750
I decided I wanted to do a little something sci fi, while still doing the Do335. So, I pulled out one of the SBY Dreadnought kits from Bandai. A lovely kit too. If I was doing this OOB, I think I would be in paint already. But as I'm not...
Taking some inspiration from Do-Do, I decided to give her a little stretch in the hull. As well as that, I'll be building up the lower belly scoop, to make it larger and more angular like the forward scoop under the bow. I also have the exhaust nozzle from a 1/48 SR-71 that may serve as a new engine for the ship. It's only slightly larger in diameter than the hull.
First up, the lovely box art!
The pile of sprues.
Firs to go are the little knobs here that protrude from under the upper bulges.
I found a nice bit of rod to replace them with.
Took a little detour and cut the hull sides.:o
Then it was back to cutting interior plastic for clearance for the metal rods. Just in case.
And how she looks right now, with a planned length of the stretch.
Wish me luck. Model on!
Thom216    750
Update time!
While waiting for the CA to dry on a nagging seam on the Do335, I brought out my new drill bit set and drilled those holes where the 'knobby' things were.
Rolling the metal rod under the sharp edge of a hobby knife got me eight of these.
Which were then pushed into the holes and secured with a tiny bit of CA.
Here's with the fore deck in place.
And here is my snafu produced by the dremel.
And my second, produced by my inattention while snipping the dorsal bow fin off the sprue... As you can see, out came the scrap styrene and CA.
And finally, the new 'floor' for whatever detail I decide to place into the hole. I could have fixed it, but I've decided some detail would be nicer.
Al for now, have a good night and model on!
Will Vale    3,157
This is a really cool design, I think I like it more than the Andromeda (and I suspect others feel the same as it sold out so fast first time around). Is the extra length just for looks, or to match a different "prototype" ship?
Will
Thom216    750
Will
Just my own preference. I prefer my ships to have some length to them.:D
Thom216    750
A little more work done on the Nauty. Not much, but some...
The spacers are in space for the bow stretch. They are just scrap pieces from another kit.
The bow deck is going to be changed. I'm either going to do a smooth deck, filling in those lines, or use clapboard styrene with far finer and thinner lines for a more scale look.
The box in the middle is the battery box, which I won't be using because it won't be lit. But it makes it easy to slide the two halves together, which makes it easier for the rear stretch as well. And the distance for that was dictated by the tamper proof ring from a juice bottle that I'll be using. It'll bend nicely around the side engine nacelle.
And that's it do far. Have a good night. Model on!
