For this GB I'll be building Směr (ex-Heller) kit with PH Model conversion; I'm starting off with the general introduction of the kit and conversion parts.
Hmmm - now this looks like an interesting project!
Was tempted to have a go in 1:32 - so will be following with interest... :)
Iain
Edited by 32SIG
Thanks chaps! Yes, there is lot of clean up to do, but this is only prelude to the surgery that's coming on...
Anyway, I primed the resin parts and cut off the front part of radiator body, because the air bubbles completely destroyed its edges. This will be later on replaced with plasticards.
Despite original thoughts I'm going to use Part etched set inteded for the Hasegawa MS-406. I seems that it can be very useable with only little modifications.
Eventually, I reworked the rear cockpit compartment and attached most of the etched fiddly bits. Now onto the painting...
  • 4 weeks later...
Finally, some progress down here - filled the fuselage, cut out the flaps and the aperture for the radiator in the wing and added the wheel well inserts.
That resin looks a bit rough... you're doing a fine job so far though :)
That interior is looking the business mate. :gobsmacked:
Deacon
