Reini78 Posted June 17, 2023 Share Posted June 17, 2023 After all the yellow wing subjects, it´s time for some more modern USN stuff. Gonna do a Hasegawa A-7 with TwoBobs decals, representing the XO aircraft of VA-22 in the second half of the 80ies, which received a special livery like the CO. DSC_0001 by grimreaper110, auf Flickr lower scheme DSC_0002 by grimreaper110, auf Flickr 5 Link to comment Share on other sites More sharing options...
heloman1 Posted June 17, 2023 Share Posted June 17, 2023 Wow, nice colour scheme choice. I took part in the Crusader-Corsair GB elsewhere on BM. The Hasegawa kit is a beauty, I'll follow your build with interest. Colin 1 Link to comment Share on other sites More sharing options...
Reini78 Posted June 27, 2023 Author Share Posted June 27, 2023 so, let´s get this thing started DSC_0001 by grimreaper110, auf Flickr left the kit seat, right the Aires seat with PE parts most probably gonna use the kit seat with the PE stuff btw, the kit comes with an the early and the late seat, as far as I could identify on the only pic I found online, this aircraft had the late seat DSC_0002 by grimreaper110, auf Flickr 4 Link to comment Share on other sites More sharing options...
Reini78 Posted June 29, 2023 Author Share Posted June 29, 2023 started to add some paint DSC_0004 by grimreaper110, auf Flickr well, ended up with the Aires seat DSC_0006 by grimreaper110, auf Flickr the long airintake, sadly ejector markings and long seams DSC_0005 by grimreaper110, auf Flickr 4 Link to comment Share on other sites More sharing options...
Reini78 Posted July 5, 2023 Author Share Posted July 5, 2023 already some build up progress DSC_0003 by grimreaper110, auf Flickr DSC_0004 by grimreaper110, auf Flickr DSC_0005 by grimreaper110, auf Flickr Hasegawa provided two PE parts that should be mounted between the "rods" on each fuselage side and the main body, but kept them off DSC_0006 by grimreaper110, auf Flickr DSC_0007 by grimreaper110, auf Flickr 9 Link to comment Share on other sites More sharing options...
heloman1 Posted July 6, 2023 Share Posted July 6, 2023 Coming together nicely Reini. Colin 1 Link to comment Share on other sites More sharing options...
Reini78 Posted July 8, 2023 Author Share Posted July 8, 2023 no good fit of the front "shoulder" part to the fuselage, the shape of the outer corners is slightly different to the fuselage, so there´s a step DSC_0005 by grimreaper110, auf Flickr DSC_0006 by grimreaper110, auf Flickr DSC_0007 by grimreaper110, auf Flickr 5 Link to comment Share on other sites More sharing options...
Reini78 Posted July 12, 2023 Author Share Posted July 12, 2023 problem area sanded down and rescribed DSC_0002 by grimreaper110, auf Flickr 7 Link to comment Share on other sites More sharing options...
SouthViper Posted July 12, 2023 Share Posted July 12, 2023 On 29/06/2023 at 05:12, Reini78 said: started to add some paint DSC_0004 by grimreaper110, auf Flickr well, ended up with the Aires seat DSC_0006 by grimreaper110, auf Flickr the long airintake, sadly ejector markings and long seams DSC_0005 by grimreaper110, auf Flickr Good job...How did you worked in the interior intake trunk joints ? SouthViper Link to comment Share on other sites More sharing options...
Reini78 Posted July 13, 2023 Author Share Posted July 13, 2023 12 hours ago, SouthViper said: Good job...How did you worked in the interior intake trunk joints ? SouthViper only sanded and filled the mold ejector areas, did nothing with the seams between the intake halves, hard to correct/fill these long ones depending on how visible they are in the end, bought the two part self adhesive vinyl intake cover from Steel Beach accessoires 1 Link to comment Share on other sites More sharing options...
Reini78 Posted July 17, 2023 Author Share Posted July 17, 2023 applied some primer DSC_0003 by grimreaper110, auf Flickr 7 Link to comment Share on other sites More sharing options...
Reini78 Posted July 21, 2023 Author Share Posted July 21, 2023 first camo paint with Gunze H311 FS36622 DSC_0004 by grimreaper110, auf Flickr 3 Link to comment Share on other sites More sharing options...
Reini78 Posted July 26, 2023 Author Share Posted July 26, 2023 started with the second camo paint using Gunze FS30219 DSC_0004 by grimreaper110, auf Flickr 6 Link to comment Share on other sites More sharing options...
Reini78 Posted July 27, 2023 Author Share Posted July 27, 2023 and fuselage painted with the third camo colour, using Tamiya Nato Black DSC_0003 by grimreaper110, auf Flickr DSC_0004 by grimreaper110, auf Flickr 11 Link to comment Share on other sites More sharing options...
heloman1 Posted July 28, 2023 Share Posted July 28, 2023 Reini, that camo scheme is looking great... Colin 1 Link to comment Share on other sites More sharing options...
Serkan Sen Posted July 28, 2023 Share Posted July 28, 2023 Very eye catching camo Reini. Serkan 2 Link to comment Share on other sites More sharing options...
Reini78 Posted July 29, 2023 Author Share Posted July 29, 2023 and some more camo DSC_0004 by grimreaper110, auf Flickr 6 Link to comment Share on other sites More sharing options...
Reini78 Posted July 31, 2023 Author Share Posted July 31, 2023 so, camo basically finished on to all the little corrections.. DSC_0006 by grimreaper110, auf Flickr 5 Link to comment Share on other sites More sharing options...
Reini78 Posted August 5, 2023 Author Share Posted August 5, 2023 aircraft had some unusual looking slat leading edges DSC_0006 by grimreaper110, auf Flickr 5 Link to comment Share on other sites More sharing options...
heloman1 Posted August 5, 2023 Share Posted August 5, 2023 Looking good... Colin 1 Link to comment Share on other sites More sharing options...
Reini78 Posted August 10, 2023 Author Share Posted August 10, 2023 so, finallly time for the decals DSC_0004 by grimreaper110, auf Flickr 7 Link to comment Share on other sites More sharing options...
exdraken Posted August 10, 2023 Share Posted August 10, 2023 Great paint work!! 1 Link to comment Share on other sites More sharing options...
Reini78 Posted August 11, 2023 Author Share Posted August 11, 2023 some more decal progress the decals are very thin and tend to wrap or tear during applying, had to puzzle together the red cock on both sides Besides that, although my good old dad has lots of experience, sometimes he doesn´t pay attention. The tail code for the left side was printed upside down on the decal sheet. My dad applied it that way.....but four eyes see more than two. When I realized his mistake and told him, luckily he could turn the decal into the correct position because he hadn´t treated it yet with Mikro Sol. DSC_0001 by grimreaper110, auf Flickr 3 Link to comment Share on other sites More sharing options...
Reini78 Posted August 12, 2023 Author Share Posted August 12, 2023 and finally decals done DSC_0001 by grimreaper110, auf Flickr 4 Link to comment Share on other sites More sharing options...
heloman1 Posted August 13, 2023 Share Posted August 13, 2023 Looking good... Colin 1 Link to comment Share on other sites More sharing options...
