halfwit Posted April 8, 2023 Posted April 8, 2023 Modelling Railways Illustrated Vol.1 No.2 has a very good 7mm scale Austerity drawing. I'll try and scan it later (or at least sometime in the next 24 hours) if you send me your e-mail address. 1
bootneck Posted April 8, 2023 Author Posted April 8, 2023 Thanks Paul, pm with email on the way. Mike
Paul821 Posted April 8, 2023 Posted April 8, 2023 Mike these links might be of use to you https://m.yeggi.com/q/austerity+tank/ Both as a result of searching J94 3d print I do have access to a couple of 1:1 scale ex Army austerity locos if you need detailed pictures or measurements. 1
dcrfan Posted April 11, 2023 Posted April 11, 2023 (edited) On 4/9/2023 at 6:09 AM, Paul821 said: Mike these links might be of use to you https://m.yeggi.com/q/austerity+tank/ Both as a result of searching J94 3d print I do have access to a couple of 1:1 scale ex Army austerity locos if you need detailed pictures or measurements. Oh no not one of those 1:1 scale models. I had access to one when I was building my Rhodesian Garratt. It was wrong in so many details according to the Rhodesian Railways official (tiny) scale drawing I had. Unfortunately I had already made significant progress on the chassis etc before I had access to the real thing (which luckily was only 30 minutes from where I live in New Zealand) so compromises had to be made to enable me to maintain my sanity and progress my already flawed components. You do need to understand 'as designed' versus 'as built' versus 'as modified in service' then 'as restored' changes in a steam locomotives lifespan. Edited April 11, 2023 by dcrfan
bootneck Posted April 11, 2023 Author Posted April 11, 2023 On 08/04/2023 at 19:09, Paul821 said: I do have access to a couple of 1:1 scale ex Army austerity locos if you need detailed pictures or measurements. Hi Paul, thanks for the links. I would be grateful if you could send any details of the runnng gear. Scratchbuilding locomotives is not my normal subject, so I shall need to interpret much of any data I can get hold of. cheers, Mike
Rumblestripe Posted April 12, 2023 Posted April 12, 2023 On 4/8/2023 at 3:42 PM, bootneck said: I have just received this kit of a Russian gauge railway track set. The gauge is 5 foot but I shouldn't have any problem resizing the gap to 4ft 8½ in. Up to you, but the difference at 1/35 is about 1mm, visually I doubt you are going to notice. Good luck with the project it sounds interesting. 1 1
Dave Swindell Posted April 13, 2023 Posted April 13, 2023 19 hours ago, Rumblestripe said: the difference at 1/35 is about 1mm, Difference is 2.54mm or 6.2% 1 1
Paul821 Posted April 13, 2023 Posted April 13, 2023 Mike sent you a message with a link to a dozen photo's. Hope these are useful. Regards Paul821
