pockets Posted December 29, 2021 Author Share Posted December 29, 2021 On 08/12/2021 at 16:54, Aku said: I believe I still have the instructions somewhere, and I traced some of the parts like the "bands" that wraps around the shoulder. I should be able to scan those if needed. Will need a slight correction as I traced it, so it some plans will be a pencil width thicker And if it all goes wrong, you can always fall back to making one of the SEvans Exterminated models Hi Aku , think I may take you up on the offer of the scanned collar templates as the instructions I was kindly given arrived minus the collar and mesh templates . 1 Link to comment Share on other sites More sharing options...
pockets Posted January 7 Author Share Posted January 7 (edited) Made a new disc for the dome from 2mm abs sheet, also made some new collars from .75mm abs and slat mesh from Isopon mesh with the aid of some templates Aku a fellow Britmodeller kindly sent me links for . Have also prepped the body, had to fettle quite a bit as the previous builder hadnt removed a lot of the risidual material from the initial cut out of parts and then filled with the use of Mr surfacer 500 and 1000 ready to lay some primer down before more prep and filler primer . Edited January 8 by pockets 9 Link to comment Share on other sites More sharing options...
Galligraphics Posted January 18 Share Posted January 18 Looking forward to seeing this one progress - it's already looking a lot tidier than the state it arrived in. I have two - one purchased back in 198X and half started at the time, which then lived in a box in the loft until I found it and finally finished it off about 6/7 years ago, and a second one which was obtained via eBygum in a rather dilapidated state with bits missing and which needed restoration, much like this one. They are very impressive when finished! Just wish I'd had the forethought to buy more back in the day - have you seen what a Davros fetches these days?! 3 Link to comment Share on other sites More sharing options...
pockets Posted January 19 Author Share Posted January 19 (edited) Thanks Galligraphics, yes the last Davros sold went for around £170 . Bit more progress, have scratch built a gun from abs plastic tube for the barrel and collars and some 0.8mm brass rod for the cage, gunna add some petg clear for the 3 hex parts of the early type mark1 gun later .Also fabricated a plunger arm from ally and abs tube . Edited January 19 by pockets 6 Link to comment Share on other sites More sharing options...
pockets Posted January 24 Author Share Posted January 24 Have made some extra slats from ally to make them up to 17 as a few missing , also fabricated 6 eyestalk discs from 1mm plasticard as there were only 3 usable and want to make the mk1 version . Primed the main body. Also discovered the previous builder had put the resin domelights inside the old yellowed larger later lights so broke the outer away and am going to utilize them with a few mods . Also made the octagon parts for the early gun from 1mm PETG . 11 Link to comment Share on other sites More sharing options...
Kallisti Posted January 30 Share Posted January 30 What a stunning transformation! I've never built a Sevans Dalek kit but have done a couple of Comet Miniatures and building the skirt to me is always the trickiest part of the job and especially with what you were dealing with, you've done a fantastic job! 1 Link to comment Share on other sites More sharing options...
pockets Posted January 30 Author Share Posted January 30 Thanks Kalista. Link to comment Share on other sites More sharing options...
Pete F Posted January 30 Share Posted January 30 This is looking good. I have a half built kit from the 80's that has moved around the universe with me (more than the Daleks themselves) and needs a lot of TLC - Perhaps a complete disassembly like yours is in order. The plunger is long gone and I have been struggling with an idea for a replacement. What did you use? 2 Link to comment Share on other sites More sharing options...
pockets Posted January 30 Author Share Posted January 30 (edited) Thanks Pete F . Do you mean the plunger itself or the telescopic arm? if the plunger itself then someone kindly donated me one from of 1 of his Sevans Movie Dalek kits as they come with both the claw and sink plunger. Id'e deffo go for a rebuild but if the skirt is still in good order Id'e leave intact and just prep it for a respray , do you have some pics of it as is ? Edited January 30 by pockets 1 Link to comment Share on other sites More sharing options...
Pete F Posted January 31 Share Posted January 31 Thanks pockets. These are pictures of the skirt. The main problem is that it has seen a few attempts to fill the gaps over the years and now the glue is failing in places and in others it is proving stubborn to get the parts free. The plunger is proving harder that I thought to source. I think I might try and get one printed (new tech since I last thought about it). This work was done in 1985 - it represents my deep shelf of doom. It is stored in a box from a coffee maker that has been gone so long it has been replaced about five times since. 6 Link to comment Share on other sites More sharing options...
pockets Posted January 31 Author Share Posted January 31 (edited) What type of glue did you use ?, some recommend putting in freezer overnight , I just gently teased the more stubborn joints apart, getting blade gradually into the seam and letting time and the force gradually prize the joint apart , the glue that the original builder used on mine may have been uhu or bostick perhaps. Patience is key , just do a bit and leave for a while . Edited January 31 by pockets 1 2 Link to comment Share on other sites More sharing options...
Pete F Posted January 31 Share Posted January 31 1 hour ago, pockets said: some recommend putting in freezer overnight Thanks pockets - I hadn't heard of the freezer trick. I shall give it a go. 1 Link to comment Share on other sites More sharing options...
pockets Posted January 31 Author Share Posted January 31 what type of glue did you use if you recall? Link to comment Share on other sites More sharing options...
Pete F Posted February 1 Share Posted February 1 It was poly cement but the old school style in tubes. As we speak it is starting to come apart quite nicely so it looks like a skirt rebuild is in order. The main problem is that where I have filled and sanded over the years some of the pieces have thinned edges. I am currently thinking of rebuilding them with some home made liquid poly mix, applied then sanded to match the original width. I can't see another way to do it. BTW what did you use to remove the paint in the end. Mine is enamel - mixture of gloss black and matt grey - probably Humbrol 1970s/80s vintage. Does your other site mention potential classic Dalek plunger replacements? If it is the site I sometimes frequent they tended to concentrate on the full size versions (something else on my list). 1 Link to comment Share on other sites More sharing options...
pockets Posted February 1 Author Share Posted February 1 (edited) Id'e reinforce from the back of panel with some plasticard glued as the instructions recommend , and then filler in the panel seams , I used some Vallejo acrylic plastic putty as a gap filler [works a bit like decorators caulking] and then mr hobby 1000 brushed to fine tune and then sanded. If u read the thread it mentions what I used to remove paint. Just be carefull using to much glue as the vacformed panels tend to melt , i wouldnt use a polly putty to fill as it may cause more problems . its difficult to sand between the hemis , I used home made sanding tools made from wooden clothing pegs and lolly sticks with wetndry of various grades superglued on and sanded wet , and lots of patience . Printing maybe the answer for the plunger , maybe somone on here or project dalek will help u out , maybe do a build diary on PD. Edited February 1 by pockets 3 1 Link to comment Share on other sites More sharing options...
Pete F Posted February 1 Share Posted February 1 1 hour ago, pockets said: thread it mentions what I used to remove paint Sorry, I had read the part where you had ordered some but missed the bit where you said you had used it. I shall get some. Thanks for all the good advice, it is much appreciated and has spurred me on to get mine finally finished. 1 Link to comment Share on other sites More sharing options...
pockets Posted February 1 Author Share Posted February 1 (edited) Your welcome , hope to see your WIP in the near future . Like i say it may be worth asking on project dalek for a plunger as the movie dalek kits have one in them that people dont use as they utilize the claw . Or people do scale scratch builds at 1/5 and print them . Edited February 1 by pockets Link to comment Share on other sites More sharing options...
pockets Posted February 2 Author Share Posted February 2 Made an eyeball extension amendment from a greeble to make it more MK1 styley, thinking about creating a chamfered stalk by adding some milliput and shaping. 6 Link to comment Share on other sites More sharing options...
metadyne Posted February 2 Share Posted February 2 excellent project, these kits are getting rarer and harder to obtain, I understand there was a copyright issue with Terry Nation's estate, shame about that or they may have made more, I built the Michael Wisher Davros in 1993, the original and best Davros, they never managed to capture the original look again after Michael was unable to reprise the role, wish I hadn't sold it on now, I would have an LED set in it now. Watching this with interest. 2 Link to comment Share on other sites More sharing options...
pockets Posted February 2 Author Share Posted February 2 Thanks chap , Mooncrest do a resin davros kit at a pretty reasonable price , they look to be well made and of a similar scale to the sevans. 1 Link to comment Share on other sites More sharing options...
pockets Posted February 9 Author Share Posted February 9 (edited) Havent made much progress , waiting on some paint , decided to replace all the slats with aluminium . Edited February 9 by pockets 7 Link to comment Share on other sites More sharing options...
metadyne Posted February 11 Share Posted February 11 Nice Collection of VW Bugs you have there, is the paint worn one an original 60's Dinky? Your work on the Dalek is an inspiration, thanks for sharing it with us. It's gonna be a stunner. 1 Link to comment Share on other sites More sharing options...
pockets Posted February 12 Author Share Posted February 12 Thanks yes it's an old corgi one , I have a VW 64 splitty singlecab pick up , its been off the rd for a couple of years . 2 Link to comment Share on other sites More sharing options...
The Spadgent Posted February 21 Share Posted February 21 Fantastic project. I have a few Sevans kits I have collected over the years. Dalek, Davros, cyber man and an ice warrior that was part of the longleat collection. Picked it up for a bargain on eBay. Mint too. Almost scared to make them considering the price these days. I have a Dalek that I made when I picked a kit up from the NEC at a memorabilia show in the 90s. I wasn’t that great at modelling then and although it’s made it through many a house move he’s looking a little tired. I’ll tag along if I may and get some tips. Sounds like a good way to scratch that Dalek itch without using a boxed one. you’re doing a stellar job by the way. Bravo. Johnny. 4 Link to comment Share on other sites More sharing options...
metadyne Posted March 6 Share Posted March 6 Hi Pockets, slight thread deviation, share your interest in VW, a couple in the display, planning to add more. also have a full size one slowly returning to the road. I have a mint Sevans Dalek I'm going to start soon, I'm going for the colour Scheme from my all time favourite Dalek episode, Genesis of the Daleks. That should be interesting. So your thread on it is very helpful and informative. 4 Link to comment Share on other sites More sharing options...
