seadog Posted August 2, 2014 Posted August 2, 2014 I started this build waay back when we were still living in Prague, 2005, I think... Then we moved here and it languished, unloved, on a shelf getting dusty. Having Just bought two more Coastal boats, I thought I really ought to finish it. Of course, in the intervening years Coastal Craft have come out with a Vosper....well that always seems to happen when you scratchbuild, eh? Anyway, I've started in with trying to finish off the torpedo tubes etc. thinking I'll wrap this up in a week or so...HA! Lots and lots of tiny bits to fabricate, this is going to take a while, methinks. I managed to alter a GLS Oerlikon bandstand for the twin mounting aft of the bridge, cut some new supports to fit the layout Some photos from the original start are on page 2... 3
longshanks Posted August 2, 2014 Posted August 2, 2014 Will be watching this with interest . . . Some impressive scratch building! Cheers Kev
foxy Posted August 3, 2014 Posted August 3, 2014 Nice work seadog. Very impressive work mate. Cheers foxy
seadog Posted August 3, 2014 Author Posted August 3, 2014 Thank you. It's dawning on me how many parts still need fabricating, and this includes a couple of ventilator cowls....joy. Meanwhile, i have to sort out which paintings of mine I'm going to stick in what will be my last exhibition here in Portugal. Gonna be a bit of a 'massive reductions!' sort of effort. We'll see. 8 1
seadog Posted August 5, 2014 Author Posted August 5, 2014 More pondering. It always seems that with a scratch build the majority of your time is spent researching bits and pieces. The boat I'm aiming to reproduce is 355, like the one in my painting she had a full kit of oerlikons. It also has the later style of larger ventilator cowls. Which I'm going to have to fabricate. In the photo of 355 in Lambert's book it appears that they moved them forward from their normal position on the series. I think you'd have to as the bandstand seems to be placed right where they'd normally be with a .50cal. gun tub. Unless the bandstand was a smaller version? Whatever, the amidships deck was pretty crowded! Here's where I'm at. tubes etc. not glued on, just there for a look see at what needs to happen next. Think I need to make a list so I don't forget some damn cleat I can't then get to! 5
davetwin Posted August 6, 2014 Posted August 6, 2014 Lovely looking build Seadog, I always enjoy watching people scratchbuild so will be watching with great interest
longshanks Posted August 8, 2014 Posted August 8, 2014 Hi Seadog, Keep looking at your wonderful painting ! What size is it and how much would you hope to get for it? Cheers Kev 1
seadog Posted August 8, 2014 Author Posted August 8, 2014 Cheers Kev, It's 50cm x 75cm (IIRC) and it sold it for £500, a few years back. I'm hoping to do more - gives an excuse to my model building! Admittedly not as much fun as other models I drew in my time *sigh*. But there y'go. Meanwhile, using my trusty Proxxon DB250 dinky wood lathe, I've been doing ventilator cowls, big and small... Did the three large ones are in wood, Beech, nice and tough. the littlies are turned from plastic rod... Turning plastic is, um, interesting, bit fast and it melts, mind you, wood burns... plastic doesn't half leave a mess especially if the only plastic rod you have is 7mm and you need to turn it down to 4.5 ish.... Bit of filler and they'll be good enough for rock and roll.... Ta for looking! 4
foxy Posted August 9, 2014 Posted August 9, 2014 Just ordered one of those from Axminster. Need for smaller items. Nice work seadog. Cheers foxy
seadog Posted August 10, 2014 Author Posted August 10, 2014 Foxy, You'll find there's a bit of movement in the headstock due to the plastic casing. I eliminated the movement by opening up the case and gluing in a 20x2mm peice of alloy across the front of the case. Tightened things up nicely. The three jaw chuck is worth having too, as is a set of Axminster's mini woodturning tools.
foxy Posted August 10, 2014 Posted August 10, 2014 Cheers seadog , have the chuck on order with the lathe, not the wood turning tools. Will get a set, thanks for the info on the movement. Cheers foxy 1
seadog Posted August 15, 2014 Author Posted August 15, 2014 A bit more progress...re-did the ventilator cowls for the third or fourth time. Rather happier with the current lot. turned the bits out of Degame, which comes up really smooth. I really must lay in a stock of Evergreen stuff... The vents are rather further forward than the drawings in Lambert's book of 347, but that one had the machine gun tub. 355 had an Oerlikon bandstand and looking at the photo it looks to me... as though they moved the ventilators a few feet forward. So this is my best guess! I've put a rail round the bandstand. Thin copper wire, silver soldered. The uprights are brass to which the rail is superglued. Whole thing now needs a bit of fettling and some paint...
Murdo Posted August 15, 2014 Posted August 15, 2014 Beautiful work seadog. I could have done with a lathe when I converted the Revell North sea Trawler into a South Atlantic Whaler. The vent cowls are still a serious niggle and annoyance to me.
seadog Posted August 19, 2014 Author Posted August 19, 2014 The Captain stopped by today to check on progress...There's been a lot, even if it doesn't look like it. I've made the second flag locker (must add a pic of that) - a right pain to do, lots of strips of plastic and no jig. Ventilators, bull ring and Samson posts are now in place and painted. Neither the guns nor the tubes are fixed yet. The guns will go on about last - bit fragile, don'tcherknow. The tubes and torpedo supports will get glued on when I'm absolutely sure of their positions. Need to make a few fairleads and a couple of bollards as well.
longshanks Posted August 19, 2014 Posted August 19, 2014 Looking good the 1st Lieutenant is doing a 'proper' job, back to the pub Skipper ;o) Kev
seadog Posted August 24, 2014 Author Posted August 24, 2014 Funny old business, scratch-building. There's always some vital bit of info you didn't have, or overlooked...just at the wrong time. I've been working from the Drawings in Coastal Forces v. I of boat 347, being as she' was in the same contract as 355. So I've been building the mast to conform.... Then I was catching up on Kev's type one build and thought that the IFF lookked familiar. So I went back to the book and looked at the photo of 355...oh poo. Lambert's books are utterly invaluable.Unfortunately,also very expensive now....check Amazon...nuts. I'm lucky I bought them when I did. In Volume 1, Fairmile boats there's a lot of general Coastal forces reference. The pic below, f'r instance is really going to help sort the horribly complex radar for me, I hope. A couple of good things to have when building this stuff are a mini blow torch, some paste silver solder and paste soft solder This stuff from Palmer metals is brilliantly easy to use. I now await general rudeness about the syringe... F
longshanks Posted August 24, 2014 Posted August 24, 2014 " oh poo" Know that feeling only too well! I'm sure you've already spotted that the 291U yagi points forward I'm currently working on the 291 & 242 arrays I've got to agree with you that John Lamberts books are invaluable for any one interested in Coastal Forces. I wish the promised Vol 3 would appear. Keep up the great work Cheers Kev
seadog Posted August 24, 2014 Author Posted August 24, 2014 " oh poo" Know that feeling only too well! I'm sure you've already spotted that the 291U yagi points forward Keep up the great work Cheers Kev Yes...*sigh* time for a redo I guess. I'm trying to think of a way to keep the whole lot (of each section) together while attempting to solder. The array in the photos was glued, pretty unsatisfactory.
Jockster Posted August 24, 2014 Posted August 24, 2014 What I hate is that feeling you get when you make something perfectly acceptable but deep down you know your still going to strip it apart and start again! Beautiful painting Seadog and excellent build. For the lathe I find 100rpm for styrene and 200rpm for acrylic slow enough for a good cut without the melt! Look forward to the next installment! :-) :-) :-)
seadog Posted August 28, 2014 Author Posted August 28, 2014 After far more attempts than I want to think about, I gave up trying to solder an IFF aerial and made this jig out of scrap acrylic sheet: For the wires I used the last of my ceramic wire, soldered a couple of rings and the spar that attaches it to the mast glued it all together and it sort of worked. Not doing it again, anyway. It's now mounted on the mast which I'm calling done, though I suspect the proportions of the drawing I used... I reckon it's done and will look OK when it's painted. There were a lot of variations, things were changing rapidly in '43...well, that's my excuse! 5
seadog Posted August 28, 2014 Author Posted August 28, 2014 P.S. I have a good source for copper and brass wire, should you need it for fiddly bits. Wires.co.uk they do tinned copper, stainless steel, bronze, silver and even gold wire....They also have metal mesh in various sizes too, Useful company. 1
longshanks Posted August 28, 2014 Posted August 28, 2014 Ingenious jig there mate, turned out very well Cheers Kev
foxy Posted August 28, 2014 Posted August 28, 2014 Yep second that, nice work. That site you mentioned looks good, thanks seadog shipmate. foxy
seadog Posted August 29, 2014 Author Posted August 29, 2014 Ta, chaps...I'm taking a short break from the Vosper to catch up with the BPBco boat.... So I thought I'd post some pics of the process I went through to build the hull of this 'un... Looong time between start and today! 2
