Hi All
So now we come to the one we've all been waiting for, the LAST course in this feast of mediocrity and inaccuracy :yahoo:
First impressions are good, with sturdy sprues, several optional parts, and a two part canopy that could be set open through choice and not despair.
But before I begin, I'd just like some confirmation that this IS a GR7?
The nose section called for is the second one, but which of these are needed, 69 and 70 or (74+75) and (76+77)?
I'm off to wander through the Walkaround pages
Comments and suggestions welcome
Steve
Edited by ProfSparks
Usually the strakes parts # 69 & 70 were carried in non combat area's. The other parts make up the gun packs. Im just finishing a USMC Harrier and thats what my research shows. I would think it would be similar with RAF/RN Harriers.
Hi All
The good news is, as it looks like it's bag of A04039, we get a cockpit!
The alternative good news is that it's not particularly representative of the aircraft in question <_<
Is that a Martin Baker Mk12?
Anyhoo, as I'd like to have it with the canopy open, and as it's the last hurrah, I'd like to do a bit more than just bang it together, perhaps indulge in some detailing.
Out with the saw (I love that saw now :wub:)
And it's starting to look better already
I think I might have the start of a Cunning Plan! ('though we all know how the last one with the Lynx panned out :violin:)
I figure I can get the fuselage together without any internal fittings, then insert them all after
It's not got the best location guides for the cockpit, and the gaps between the cockpit tub and the side walls will be covered by the side control panels (or whatever they're called?)
Any thoughts on this foolhardy venture?
I'm away for a couple of days to dwell on the potential repercussions...
Steve
Hi All
Starting with the seat
Hopefully won't be examined too closely from an arms length away.
Steve
Hi All
Moving on, the intake ducting is a relaxed fit
And has a pronounced lip
Also, the intakes could do with some work too.
A bit of file action does the ducting (one half done)
I'd like those flaps flusher, so I sanded down the backing ring
From photos of parked up aircraft, it looks like the top three or four flaps are regularly depressed, so out with the saw again
I'm going to fit small squares to represent the open vents
But it looked odd with the molded ones, so off they came again
And I soon had a pair of these
Fettling, filling, distance and distraction should make them blend right in.
Steve
The intake flaps that you have so carefully cut out are like that due to gravity. Nice work on that ejector seat as well.
Gondor
Hi All
Been doing significant cleaning up of mould lines, and a couple of prep assemblies before taking the plunge to glue the halfs together.
The required nose is slightly off-putting, but fortunately the kit includes four nose options, one of which I'm hoping to modify with some thin rod
They're still a bit long, but I don't want to fix them until I can have the nose on and see how they look.
If it does all go South, at least I'll still have the original.
Another area I want to work on (there are quite a few) are the jet nozzles
It's a bit blurry, but the interior vanes are pants, and I'll never be able to smooth them.
So, off they come and I'll try to replace them with some thin card
Thso, on with glueing the main body
It's going to have to be in stages, but there's plenty of other parts to fix while it sets.
Steve
Nice job so far especially like the work you've done on the intakes.
Hi All
Been quite sporadic here with just bits and pieces.
Got the wings together
The outriggers looked a bit clunky with the wheels moulded solid, so I'm going to cut them off and cut them out.
Not wanting to potentially ruin the legs, I'm going to cut the wheels from the legs that are supplied in the stowed position
A couple of minutes with a Stanley blade and it's getting close
A touch of sanding, and they're not too bad at all
With the body set, I gave it and the intake parts a coat of white undercoat (yes Vallejo again, but about a gallon came with a large lot of mixed Model Air that I'm itching to try)
Plenty of filler for the plenty gaps, and here it is with some of the multitude of bombs, rockets, tanks and pylons that I have been wading through with a sanding stick and Micro Sol
Back to the nose, the spikes got shortened and fitted
I've run in some liquid cement round the join to see if it will blend in the curve a bit. I'll give it a bead of filler next opportunity.
Speaking of filler, this Plastic Putty looks and acts a bit like Cottage Cheese, never getting the smooth surface even after repeated applications and wiping / wet sanding / dry sanding etc etc.
I'm going to have to start experimenting with other types.
Steve
Hi All
So, postimage.
What's one to do?
Anyhoo, I've eventually got some paint on the big bits
Let's see how long the .CC site lasts.
Comments and suggestions on regaining the will to link
Steve
Hi All
Continuing on with the jet nozzles, the vanes were replaced with thin card and they were given a couple of coats of Silver 11, mixed with Black 33 and that Antique Bronze 117!
I also started on the outriggers and removed the wheels
I got the upper surfaces covered too
It doesn't look as grainy in real life, and will be matt coated.
Steve
Looks like you've been experiencing the same image problems as myself with Postimage and like you, I've been busy remaking links this evening.
Of what I can see, it's looking good but you'll have to forgive me as I don't know what kit it is, I think it's 1/72?
Hi All
Got the links reset for this thread.
Yay.
Thanks, yes it's 1/72. I'm on the final labour from the "100 Years Of Naval Aviation Collection" using the supplied paint pots with the cheapest airbrush from eBay.
It all started as a way of experimenting without too much cost, and has turned into a bit of a quest.
Not far to go now!
Steve
Hi All
Got the stickers on, just waiting for a matt coat
Those outrigger wheels came out ok, a bit gnarley, but acceptable at this stage, along with the main gear
I'm hoping to get it all together this week and move on :hobbyhorse:
Steve
Hi All
In order to get all the wheels touching the ground, I fitted the nose and outriggers, then shaved a touch off the main strut to get them sitting flush
Then came the fitting of all those hanging down parts, starting with the centre line and working outwards
Those exhaust vents turned out ok!
Pity they mostly will be hidden within the forest of pylons and bombs etc
Never mind, that's where she's staying until I pluck up the courage to turn her over and see what drops off...
Steve
Hi All
Nothing fell off!
I got the seat in, and the display that I lined with black marker pen
I coiled a bit of wire round a pin
Dipped it in black paint
And it became that little tube/vane thing on the nose
Tails on
And I'm calling it DONE :elephant:
Feels like I've been on this set for 100 Years :clif:
Anyhoo, I'll try for some outside shots when it stops blowing a gale.
Thanks to everyone for putting up with my ineptitude, plenty more where that came from!
Steve
