My model will be of the DaKP 'Dampf angetriebene Kanone Plattform' (steam powered gun platform) VII, commonly called the Steam Tiger (Must work on this back story a little more me thinks)
_________________________________
Plan is to build this one of these quick assembly Tigers, add some pipes and other subtle details to produce the steam powered variant finished in brass\bronze\copper
Watch this space .....
Will you be adding the "Dampfsperre" steam baffles to your land cruiser sir?. I believe that you would be, as they were certainly evident on the electrodaguerres of the only 2 of these noble land leviathans that were captured after the battle?
Jonners
Of course, and the "Lochkarte" (punched card) controlled aiming mechanism, clearly a copy of the Babbage-Lovelace device used on British Behemoths
Started work, "Dampf-Trichter" funnels added to the rear with weaponry and other updates in progress, the plastic card additions behind the turret (work in progress) are to represent the "Kohle-Eimer" coal basket which provided fuel to the firebox via an ingenious mechanism to allow for turret rotation
Edited by cjhm
Think that's all of assembly, just need to clean up tracks a bit (they are only push fit at the moment) and then painting can start after a good wash to clear up swarf and grease from my grubby fingers
Coming along, 2 coats of matt black primer then 2 coats of Citadel Dwarf Bronze with flow improver (needs a third), both by brush
i am really liking the all bronze look and have you tried to dry brush the paint on i fine you get better coverage on
large areas if you are using a hairy stick
Thanks for that, gave it a go and it does cover better like that; think I was slopping on too much ....
More pics soon, nearly done
Nearly there
Thought I better post up the reference shots I used, these were of course taken from 'Dampf War Machines der Weltmächte 1937-1946' (Steam War Machines of World Powers 1937-1946), the authoritative work on these behemoths
Aha - those all important references - looks like you're project is bang on accuracy wise! :)
Iain
All done, model railway coal as finishing touch to bunker
More pics in gallery
Edited by cjhm
great job mate i really like the coal hopper i am all most tempted to bust out
a tank and have a go at making one(might do if time permits)
  • 3 months later...
